problemi alla schermata di inizio
buongiorno, ho appena istallato manjaro gnome, ho notato che e molto lungo a far aprire la schermata di inizio
, mi dice sempre
0.003954] do_IRQ: 1.55 No irq handler for vector
0.003954] do_IRQ: 2.55 No irq handler for vector
0.003954] do_IRQ: 3.55 No irq handler for vector
[FAILED] Failed to start Load/Save Screen Backlight Brightness of backlight
qualcuno può aiutarmi perfavore
poi non mi vede la stampante cannon TR4550, ho provato a scaricare i driver da Cannon
ma non socosa fare con loro
grazie
Può fornirci, per favore, i seguenti dati
da terminale
inxi -Fxxxza
iuseppef@giuseppe-hpnotebook ~]$ inxi -Fxxxza
Host: giuseppe-hpnotebook Kernel: 5.6.15-1-MANJARO x86_64 bits: 64
compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.6-x86_64
root=UUID=b28a0af4-4026-480a-91f0-03dadc536881 rw quiet apparmor=1
Desktop: Gnome 3.36.2 wm: gnome-shell dm: GDM 3.34.1 Distro: Manjaro Linux
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
serial: Chassis: type: 10 serial:
Mobo: HP model: 80CB v: 99.52 serial: UEFI: Insyde v: F.27
date: 12/07/2018
ID-1: BAT1 charge: 28.3 Wh condition: 29.5/29.5 Wh (100%) volts: 16.2/14.8
model: 111-83-72 HS04041 type: Unknown serial:
status: Discharging
Topology: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics
bits: 64 type: MCP arch: Puma family: 16 (22) model-id: 30 (48)
stepping: 1 microcode: 7030106 L2 cache: 2048 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 17575
Speed: 998 MHz min/max: 1000/2200 MHz boost: enabled Core speeds (MHz):
1: 998 2: 998 3: 998 4: 998
disabled, RSB filling
Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
driver: radeon v: kernel bus ID: 00:01.0 chip ID: 1002:9851
Display: x11 server: X.org 1.20.8 driver: radeon compositor: gnome-shell
resolution:
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.6.15-1-MANJARO LLVM 10.0.0)
v: 4.5 Mesa 20.0.7 direct render: Yes
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:01.1 chip ID: 1002:9840
Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus ID: 00:14.2 chip ID: 1022:780d
Sound Server: ALSA v: k5.6.15-1-MANJARO
Device-1: Broadcom and subsidiaries BCM43142 802.11b/g/n
vendor: Hewlett-Packard driver: wl v: kernel port: 3100 bus ID: 02:00.0
chip ID: 14e4:4365
IF: wlo1 state: up mac:
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel port: 2000 bus ID: 03:00.0
chip ID: 10ec:8136
IF: enp3s0 state: down mac:
Local Storage: total: 465.76 GiB used: 45.25 GiB (9.7%)
ID-1: /dev/sda vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: rev: YAM1 scheme: GPT
ID-1: / raw size: 465.46 GiB size: 457.16 GiB (98.22%)
used: 45.24 GiB (9.9%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 30.0 C mobo: 20.0 C gpu: radeon temp: 29 C
Processes: 190 Uptime: 6m Memory: 3.30 GiB used: 1.10 GiB (33.2%)
Init: systemd v: 245 Compilers: gcc: N/A Shell: bash v: 5.0.17
running in: gnome-terminal inxi: 3.0.37
[giuseppef@giuseppe-hpnotebook ~]$
x-special/nautilus-clipboard
copy
file:///home/giuseppef/Scrivania/Schermata%20del%202020-06-11%2000-05-04.png
ho provato come mi avete detto, pero facendo ul copia e incolla dal terminale non riporta tutti i dati
ho provato con lo screen shot ma questo e il risultato
Buongiorno Faso,
la cosa migliore per farti aiutare é avere il risultato del comando
inxi -Fxxxza
fai copia da terminale:
seleziona la prima riga, poi fai scorrere fino alla fine, premi Shift e selezioni l´ultima parola. Ora avrai tutto selezionato, quindi click destro e copia.
Dopo incolla nella risposta come "preformatted text".
Questo puoi farlo in (almeno) due modi:
1- selezione il simbolo </> e poi incolla.
2- premi Ctrl+Shift+C e poi incolla.
Grazie pacop x il tuo interessamento
</>[giuseppef@giuseppe-hpnotebook ~]$ inxi -Fxxxza
Host: giuseppe-hpnotebook Kernel: 5.6.16-1-MANJARO x86_64 bits: 64
Desktop: Gnome 3.36.3 wm: gnome-shell dm: GDM 3.34.1 Distro: Manjaro Linux
date: 12/07/2018
ID-1: BAT1 charge: 22.1 Wh condition: 26.7/26.7 Wh (100%) volts: 15.6/14.8
status: Discharging
bogomips: 17573
Display: wayland server: X.org 1.20.8 driver: radeon
compositor: gnome-shell resolution:
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.6.16-1-MANJARO LLVM 10.0.0)
Sound Server: ALSA v: k5.6.16-1-MANJARO
chip ID: 14e4:4365
chip ID: 10ec:8136
Local Storage: total: 465.76 GiB used: 46.72 GiB (10.0%)
used: 46.72 GiB (10.2%) fs: ext4 dev: /dev/sda2
System Temperatures: cpu: 34.4 C mobo: 20.0 C gpu: radeon temp: 33 C
Processes: 188 Uptime: 19m Memory: 3.30 GiB used: 1.08 GiB (32.7%)
Init: systemd v: 245 Compilers: gcc: 10.1.0 Shell: bash v: 5.0.17
