ok…
[ 9.160] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
[ 9.161] (EE) [drm] Failed to open DRM device for pci:0000:01:00.0: -19
errno sagt:
$ errno 19
ENODEV 19 Kein passendes Gerät gefunden
Ok jetzt haben wir schwarz auf weiß… Kernel 5.4 funktioniert mit deiner GPU und nouveau nicht. Aber Kernel 4.19 funktioniert laut /var/log/Xorg.1.log…
[ 78284.797] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 78285.216] (II) [drm] nouveau interface version: 1.3.1
[ 78285.216] (WW) Falling back to old probe method for modesetting
[ 78285.216] (II) Loading sub module "dri2"
[ 78285.216] (II) LoadModule: "dri2"
[ 78285.216] (II) Module "dri2" already built-in
[ 78285.216] (--) NOUVEAU(0): Chipset: "NVIDIA NVA8"
[ 78285.217] (II) NOUVEAU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 78285.217] (==) NOUVEAU(0): Depth 24, (--) framebuffer bpp 32
[ 78285.217] (==) NOUVEAU(0): RGB weight 888
[ 78285.217] (==) NOUVEAU(0): Default visual is TrueColor
[ 78285.217] (==) NOUVEAU(0): Using HW cursor
[ 78285.217] (==) NOUVEAU(0): Allowed maximum DRI level 2.
[ 78285.217] (==) NOUVEAU(0): GLX sync to VBlank enabled.
[ 78285.217] (==) NOUVEAU(0): Page flipping enabled
[ 78285.217] (==) NOUVEAU(0): Swap limit set to 1 [Max allowed 2]
[ 78285.217] (==) NOUVEAU(0): Page flipping synced to vblank by kernel.
[ 78285.217] (II) NOUVEAU(0): Initializing outputs ...
[ 78285.246] (II) NOUVEAU(0): Output DVI-I-1 has no monitor section
[ 78285.248] (II) NOUVEAU(0): Output HDMI-1 has no monitor section
[ 78285.258] (II) NOUVEAU(0): Output VGA-1 has no monitor section
[ 78285.258] (II) NOUVEAU(0): 3 crtcs needed for screen.
[ 78285.259] (II) NOUVEAU(0): Allocated crtc nr. 0 to this screen.
[ 78285.259] (II) NOUVEAU(0): Allocated crtc nr. 1 to this screen.
[ 78285.288] (II) NOUVEAU(0): EDID for output DVI-I-1
[ 78285.288] (II) NOUVEAU(0): Manufacturer: GSM Model: 564e Serial#: 4207
[ 78285.288] (II) NOUVEAU(0): Year: 2007 Week: 5
[ 78285.288] (II) NOUVEAU(0): EDID Version: 1.3
[ 78285.288] (II) NOUVEAU(0): Digital Display Input
[ 78285.288] (II) NOUVEAU(0): Max Image Size [cm]: horiz.: 49 vert.: 32
[ 78285.288] (II) NOUVEAU(0): Gamma: 2.20
[ 78285.288] (II) NOUVEAU(0): DPMS capabilities: StandBy Suspend Off
[ 78285.288] (II) NOUVEAU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 78285.288] (II) NOUVEAU(0): First detailed timing is preferred mode
[ 78285.288] (II) NOUVEAU(0): redX: 0.635 redY: 0.342 greenX: 0.292 greenY: 0.611
[ 78285.288] (II) NOUVEAU(0): blueX: 0.147 blueY: 0.070 whiteX: 0.313 whiteY: 0.329
[ 78285.288] (II) NOUVEAU(0): Supported established timings:
[ 78285.288] (II) NOUVEAU(0): 720x400@70Hz
[ 78285.288] (II) NOUVEAU(0): 640x480@60Hz
[ 78285.288] (II) NOUVEAU(0): 640x480@75Hz
[ 78285.288] (II) NOUVEAU(0): 800x600@56Hz
[ 78285.288] (II) NOUVEAU(0): 800x600@60Hz
[ 78285.288] (II) NOUVEAU(0): 800x600@75Hz
[ 78285.288] (II) NOUVEAU(0): 832x624@75Hz
[ 78285.288] (II) NOUVEAU(0): 1024x768@60Hz
[ 78285.288] (II) NOUVEAU(0): 1024x768@75Hz
[ 78285.288] (II) NOUVEAU(0): 1280x1024@75Hz
[ 78285.288] (II) NOUVEAU(0): 1152x864@75Hz
[ 78285.288] (II) NOUVEAU(0): Manufacturer's mask: 0
[ 78285.288] (II) NOUVEAU(0): Supported standard timings:
[ 78285.288] (II) NOUVEAU(0): #0: hsize: 1440 vsize 900 refresh: 75 vid: 3989
[ 78285.288] (II) NOUVEAU(0): #1: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 78285.288] (II) NOUVEAU(0): #2: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 78285.288] (II) NOUVEAU(0): #3: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 78285.288] (II) NOUVEAU(0): #4: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 78285.288] (II) NOUVEAU(0): Supported detailed timing:
[ 78285.288] (II) NOUVEAU(0): clock: 119.0 MHz Image Size: 474 x 296 mm
[ 78285.288] (II) NOUVEAU(0): h_active: 1680 h_sync: 1728 h_sync_end 1760 h_blank_end 1840 h_border: 0
[ 78285.288] (II) NOUVEAU(0): v_active: 1050 v_sync: 1053 v_sync_end 1059 v_blanking: 1080 v_border: 0
[ 78285.288] (II) NOUVEAU(0): clock: 146.2 MHz Image Size: 474 x 296 mm
[ 78285.288] (II) NOUVEAU(0): h_active: 1680 h_sync: 1784 h_sync_end 1960 h_blank_end 2240 h_border: 0
[ 78285.288] (II) NOUVEAU(0): v_active: 1050 v_sync: 1053 v_sync_end 1059 v_blanking: 1089 v_border: 0
[ 78285.288] (II) NOUVEAU(0): Ranges: V min: 56 V max: 75 Hz, H min: 28 H max: 83 kHz, PixClock max 155 MHz
[ 78285.288] (II) NOUVEAU(0): Monitor name: L226WTQ
[ 78285.288] (II) NOUVEAU(0): EDID (in hex):
[ 78285.288] (II) NOUVEAU(0): 00ffffffffffff001e6d4e566f100000
[ 78285.288] (II) NOUVEAU(0): 05110103ea312078eaaec5a2574a9c25
[ 78285.288] (II) NOUVEAU(0): 125054a76b80950f950081808140714f
[ 78285.288] (II) NOUVEAU(0): 0101010101017c2e90a0601a1e403020
[ 78285.288] (II) NOUVEAU(0): 3600da281100001a21399030621a2740
[ 78285.288] (II) NOUVEAU(0): 68b03600da281100001c000000fd0038
[ 78285.288] (II) NOUVEAU(0): 4b1c530f000a202020202020000000fc
[ 78285.288] (II) NOUVEAU(0): 004c3232365754510a202020202000f2
[ 78285.288] (II) NOUVEAU(0): Printing probed modes for output DVI-I-1
[ 78285.288] (II) NOUVEAU(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz eP)
[ 78285.288] (II) NOUVEAU(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 78285.288] (II) NOUVEAU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 78285.289] (II) NOUVEAU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 78285.290] (II) NOUVEAU(0): EDID for output HDMI-1
[ 78285.300] (II) NOUVEAU(0): EDID for output VGA-1
[ 78285.300] (II) NOUVEAU(0): Output DVI-I-1 connected
[ 78285.300] (II) NOUVEAU(0): Output HDMI-1 disconnected
[ 78285.300] (II) NOUVEAU(0): Output VGA-1 disconnected
[ 78285.300] (II) NOUVEAU(0): Using exact sizes for initial modes
[ 78285.300] (II) NOUVEAU(0): Output DVI-I-1 using initial mode 1680x1050 +0+0
[ 78285.300] (==) NOUVEAU(0): Using gamma correction (1.0, 1.0, 1.0)
[ 78285.300] (II) NOUVEAU(0): Virtual size is 1680x1050 (pitch 0)
[ 78285.300] (**) NOUVEAU(0): Driver mode "1680x1050": 119.0 MHz (scaled from 0.0 MHz), 64.7 kHz, 59.9 Hz
[ 78285.300] (II) NOUVEAU(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz eP)
[ 78285.300] (**) NOUVEAU(0): Driver mode "1680x1050": 146.2 MHz (scaled from 0.0 MHz), 65.3 kHz, 60.0 Hz
[ 78285.300] (II) NOUVEAU(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 78285.300] (**) NOUVEAU(0): Driver mode "1280x1024": 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz
[ 78285.300] (II) NOUVEAU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 78285.300] (**) NOUVEAU(0): Driver mode "1280x1024": 108.0 MHz (scaled from 0.0 MHz), 64.0 kHz, 60.0 Hz
[ 78285.300] (II) NOUVEAU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 78285.300] (**) NOUVEAU(0): Driver mode "1440x900": 136.8 MHz (scaled from 0.0 MHz), 70.6 kHz, 75.0 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "1440x900"x75.0 136.75 1440 1536 1688 1936 900 903 909 942 -hsync +vsync (70.6 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "1440x900": 88.8 MHz (scaled from 0.0 MHz), 55.5 kHz, 59.9 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "1280x960": 108.0 MHz (scaled from 0.0 MHz), 60.0 kHz, 60.0 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "1152x864": 108.0 MHz (scaled from 0.0 MHz), 67.5 kHz, 75.0 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.0 kHz, 75.0 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "832x624": 57.3 MHz (scaled from 0.0 MHz), 49.7 kHz, 74.6 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "800x600": 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.3 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.2 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 59.9 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 78285.301] (**) NOUVEAU(0): Driver mode "720x400": 28.3 MHz (scaled from 0.0 MHz), 31.5 kHz, 70.1 Hz
[ 78285.301] (II) NOUVEAU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 78285.301] (==) NOUVEAU(0): DPI set to (96, 96)
[ 78285.301] (II) Loading sub module "fb"
[ 78285.301] (II) LoadModule: "fb"
[ 78285.301] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 78285.301] (II) Module fb: vendor="X.Org Foundation"
[ 78285.301] compiled for 1.20.8, module version = 1.0.0
[ 78285.301] ABI class: X.Org ANSI C Emulation, version 0.4
[ 78285.301] (II) Loading sub module "shadowfb"
[ 78285.301] (II) LoadModule: "shadowfb"
[ 78285.301] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[ 78285.302] (II) Module shadowfb: vendor="X.Org Foundation"
[ 78285.302] compiled for 1.20.8, module version = 1.0.0
[ 78285.302] ABI class: X.Org ANSI C Emulation, version 0.4
[ 78285.302] (II) UnloadModule: "modesetting"
[ 78285.302] (II) Unloading modesetting
[ 78285.303] (II) NOUVEAU(0): Channel setup complete.
[ 78285.304] (II) NOUVEAU(0): [COPY] async initialised.
[ 78285.304] (II) NOUVEAU(0): Hardware support for Present enabled
[ 78285.304] (II) NOUVEAU(0): [DRI2] Setup complete
[ 78285.304] (II) NOUVEAU(0): [DRI2] DRI driver: nouveau
[ 78285.304] (II) NOUVEAU(0): [DRI2] VDPAU driver: nouveau
[ 78285.304] (II) Loading sub module "exa"
[ 78285.304] (II) LoadModule: "exa"
[ 78285.304] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 78285.304] (II) Module exa: vendor="X.Org Foundation"
[ 78285.304] compiled for 1.20.8, module version = 2.6.0
[ 78285.304] ABI class: X.Org Video Driver, version 24.1
[ 78285.304] (II) EXA(0): Driver allocated offscreen pixmaps
[ 78285.304] (II) EXA(0): Driver registered support for the following operations:
[ 78285.304] (II) Solid
[ 78285.304] (II) Copy
[ 78285.304] (II) Composite (RENDER acceleration)
[ 78285.304] (II) UploadToScreen
[ 78285.304] (II) DownloadFromScreen
[ 78285.304] (==) NOUVEAU(0): Backing store enabled
[ 78285.304] (==) NOUVEAU(0): Silken mouse disabled
[ 78285.305] (II) NOUVEAU(0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[ 78285.305] (II) NOUVEAU(0): [XvMC] Extension initialized.
[ 78285.305] (==) NOUVEAU(0): DPMS enabled
[ 78285.305] (II) Initializing extension Generic Event Extension
[ 78285.305] (II) Initializing extension SHAPE
[ 78285.305] (II) Initializing extension MIT-SHM
[ 78285.306] (II) Initializing extension XInputExtension
[ 78285.306] (II) Initializing extension XTEST
[ 78285.306] (II) Initializing extension BIG-REQUESTS
[ 78285.306] (II) Initializing extension SYNC
[ 78285.306] (II) Initializing extension XKEYBOARD
[ 78285.306] (II) Initializing extension XC-MISC
[ 78285.307] (II) Initializing extension SECURITY
[ 78285.307] (II) Initializing extension XFIXES
[ 78285.307] (II) Initializing extension RENDER
[ 78285.307] (II) Initializing extension RANDR
[ 78285.307] (II) Initializing extension COMPOSITE
[ 78285.308] (II) Initializing extension DAMAGE
[ 78285.308] (II) Initializing extension MIT-SCREEN-SAVER
[ 78285.308] (II) Initializing extension DOUBLE-BUFFER
[ 78285.308] (II) Initializing extension RECORD
[ 78285.308] (II) Initializing extension DPMS
[ 78285.308] (II) Initializing extension Present
[ 78285.309] (II) Initializing extension DRI3
[ 78285.309] (II) Initializing extension X-Resource
[ 78285.309] (II) Initializing extension XVideo
[ 78285.309] (II) Initializing extension XVideo-MotionCompensation
[ 78285.309] (II) Initializing extension GLX
[ 78285.416] (II) AIGLX: Loaded and initialized nouveau
[ 78285.416] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 78285.416] (II) Initializing extension XFree86-VidModeExtension
[ 78285.416] (II) Initializing extension XFree86-DGA
[ 78285.416] (II) Initializing extension XFree86-DRI
[ 78285.416] (II) Initializing extension DRI2
[ 78285.419] (II) NOUVEAU(0): NVEnterVT is called.
[ 78285.448] (II) NOUVEAU(0): Setting screen physical size to 444 x 277
[ 78285.448] resize called 1680 1050
Warum nicht bei Kernel 4.19 erstmal bleiben? Möglich wäre, dass deine GPU wegen veraltet und unvollständigen Hardware-Support fallen gelassen wurde in der 5er Version?
Ich weiß es jetzt gerade nicht, warum es da nicht läuft…
Und es ist eine NVA8 die zu NV50 gehört:
https://nouveau.freedesktop.org/CodeNames.html#NV50
Da sieht der Support schon bedeutend besser aus:
https://nouveau.freedesktop.org/FeatureMatrix.html
