I know I shouldn’t interrupt an update but I did not have a choice in the matter.
I had started a pacman update but was not able to finish it and just now had restarted the machine but now the sign in screen is a different sddm theme and is probably the default screen for kde plasma (I am guessing it was in the update and was not properly installed) all the buttons on the screen work and I can move my cursor around but when I go to sign in and type in the correct password nothing happens and the buttons on the screen stop working. I can no longer edit what I typed into the text bar but I can still move my cursor and the clock stops updating . it gives me an error message in red before I go to sign in: The current theme cannot be loaded due to the errors below, please select another theme.
file:///usr/share/sddm/themes/mountain-heights-11SDDM/Main.qml:26:1 plugin cannot be loaded for module “org.kde.plasma.core”: Cannot load library /usr/lib/qt/qml/org/kde/plasma/core/libcorebindingsplugin.so: (/usr/lib/libQtWaylandClient.so.5: undefined symbol: wl_proxy_marshal_flags)
thank you for your time
