sudo smartctl -t short /dev/sdb
[sudo] Passwort für ralf:
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.10.79-1-MANJARO] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Short self-test routine immediately in off-line mode".
Command "Execute SMART Short self-test routine immediately in off-line mode" failed: Connection timed out
Die lange Version kommt noch.
Es ging schneller als gedacht:
sudo smartctl -t long /dev/sdb
Sending command: "Execute SMART Extended self-test routine immediately in off-line mode".
Command "Execute SMART Extended self-test routine immediately in off-line mode" failed: Connection timed out
Tja es ging schnell, da es fehlgeschlagen ist. Im USB Modus funktioniert es anscheinen nicht.
Jetzt noch mal, der Kurztest, mit Gsmart Control:
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Green
Device Model: WDC WD10EARX-00N0YB0
Serial Number: WD-WMC0T0131641
LU WWN Device Id: 5 0014ee 207360118
Firmware Version: 51.0AB51
User Capacity: 1.000.204.886.016 bytes [1,00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 1.5 Gb/s)
Local Time is: Sat Nov 27 14:03:02 2021 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
=== START OF READ SMART DATA SECTION ===
SMART Status command failed: Connection timed out
SMART overall-health self-assessment test result: PASSED
Warning: This result is based on an Attribute check.
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
Total time to complete Offline
data collection: (18300) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
recommended polling time: ( 2) minutes.
recommended polling time: ( 179) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x30b5) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 1
3 Spin_Up_Time POS--K 127 102 021 - 6625
4 Start_Stop_Count -O--CK 096 096 000 - 4116
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 072 072 000 - 20552
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 100 000 - 0
12 Power_Cycle_Count -O--CK 096 096 000 - 4110
192 Power-Off_Retract_Count -O--CK 200 200 000 - 482
193 Load_Cycle_Count -O--CK 152 152 000 - 145635
194 Temperature_Celsius -O---K 110 089 000 - 37
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 200 200 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 20552 -
# 2 Short offline Completed without error 00% 20550 -
# 3 Short offline Completed without error 00% 20550 -
# 4 Conveyance offline Interrupted (host reset) 90% 20313 -
# 5 Short offline Completed without error 00% 20300 -
# 6 Short offline Completed without error 00% 18662 -
# 7 Short offline Completed without error 00% 13538 -
# 8 Short offline Completed without error 00% 13143 -
# 9 Short offline Completed without error 00% 13102 -
#10 Short offline Completed without error 00% 12967 -
#11 Short offline Completed without error 00% 12637 -
#12 Short offline Completed without error 00% 12512 -
#13 Short offline Completed without error 00% 12490 -
#14 Short offline Completed without error 00% 11670 -
#15 Short offline Completed without error 00% 11197 -
#16 Short offline Completed without error 00% 10981 -
#17 Short offline Completed without error 00% 8794 -
#18 Short offline Completed without error 00% 8767 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: DST executing in background (3)
Current Temperature: 37 Celsius
Power Cycle Min/Max Temperature: 33/37 Celsius
Lifetime Min/Max Temperature: 0/58 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (72)
Index Estimated Time Temperature Celsius
73 2021-11-27 06:07 39 ********************
74 2021-11-27 06:08 39 ********************
75 2021-11-27 06:09 40 *********************
... ..(125 skipped). .. *********************
201 2021-11-27 08:15 40 *********************
202 2021-11-27 08:16 39 ********************
... ..( 3 skipped). .. ********************
206 2021-11-27 08:20 39 ********************
207 2021-11-27 08:21 40 *********************
... ..( 3 skipped). .. *********************
211 2021-11-27 08:25 40 *********************
212 2021-11-27 08:26 39 ********************
216 2021-11-27 08:30 39 ********************
217 2021-11-27 08:31 38 *******************
218 2021-11-27 08:32 38 *******************
219 2021-11-27 08:33 38 *******************
220 2021-11-27 08:34 37 ******************
... ..( 2 skipped). .. ******************
223 2021-11-27 08:37 37 ******************
224 2021-11-27 08:38 36 *****************
... ..( 8 skipped). .. *****************
233 2021-11-27 08:47 36 *****************
234 2021-11-27 08:48 35 ****************
... ..( 4 skipped). .. ****************
239 2021-11-27 08:53 35 ****************
240 2021-11-27 08:54 34 ***************
... ..( 7 skipped). .. ***************
248 2021-11-27 09:02 34 ***************
249 2021-11-27 09:03 33 **************
... ..( 33 skipped). .. **************
283 2021-11-27 09:37 33 **************
284 2021-11-27 09:38 32 *************
288 2021-11-27 09:42 32 *************
289 2021-11-27 09:43 ? -
290 2021-11-27 09:44 21 **
295 2021-11-27 09:49 21 **
296 2021-11-27 09:50 22 ***
299 2021-11-27 09:53 22 ***
300 2021-11-27 09:54 23 ****
301 2021-11-27 09:55 23 ****
302 2021-11-27 09:56 24 *****
303 2021-11-27 09:57 24 *****
304 2021-11-27 09:58 24 *****
305 2021-11-27 09:59 25 ******
308 2021-11-27 10:02 25 ******
309 2021-11-27 10:03 26 *******
... ..( 9 skipped). .. *******
319 2021-11-27 10:13 26 *******
320 2021-11-27 10:14 27 ********
324 2021-11-27 10:18 27 ********
325 2021-11-27 10:19 28 *********
330 2021-11-27 10:24 28 *********
331 2021-11-27 10:25 29 **********
... ..( 12 skipped). .. **********
344 2021-11-27 10:38 29 **********
345 2021-11-27 10:39 30 ***********
... ..( 14 skipped). .. ***********
360 2021-11-27 10:54 30 ***********
361 2021-11-27 10:55 31 ************
... ..( 11 skipped). .. ************
373 2021-11-27 11:07 31 ************
374 2021-11-27 11:08 32 *************
375 2021-11-27 11:09 32 *************
376 2021-11-27 11:10 33 **************
377 2021-11-27 11:11 33 **************
378 2021-11-27 11:12 32 *************
379 2021-11-27 11:13 33 **************
... ..( 45 skipped). .. **************
425 2021-11-27 11:59 33 **************
426 2021-11-27 12:00 32 *************
... ..( 40 skipped). .. *************
467 2021-11-27 12:41 32 *************
468 2021-11-27 12:42 33 **************
469 2021-11-27 12:43 33 **************
470 2021-11-27 12:44 33 **************
471 2021-11-27 12:45 ? -
472 2021-11-27 12:46 33 **************
473 2021-11-27 12:47 33 **************
474 2021-11-27 12:48 33 **************
475 2021-11-27 12:49 34 ***************
0 2021-11-27 12:52 34 ***************
1 2021-11-27 12:53 35 ****************
6 2021-11-27 12:58 35 ****************
7 2021-11-27 12:59 36 *****************
10 2021-11-27 13:02 36 *****************
11 2021-11-27 13:03 37 ******************
... ..( 18 skipped). .. ******************
30 2021-11-27 13:22 37 ******************
31 2021-11-27 13:23 38 *******************
... ..( 8 skipped). .. *******************
40 2021-11-27 13:32 38 *******************
41 2021-11-27 13:33 39 ********************
... ..( 10 skipped). .. ********************
52 2021-11-27 13:44 39 ********************
53 2021-11-27 13:45 40 *********************
57 2021-11-27 13:49 40 *********************
58 2021-11-27 13:50 39 ********************
59 2021-11-27 13:51 40 *********************
60 2021-11-27 13:52 40 *********************
61 2021-11-27 13:53 39 ********************
72 2021-11-27 14:04 39 ********************
SCT Error Recovery Control command not supported
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 3 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 2 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 1357 Vendor specific
und noch mal den Langtest mit GSmart Control :
Can not run Extendet Self-test
Sending command failed
Dies gilt für den “Extended Self-test” sowie für den “Conveyance Self-test”.
Warum funktioniert dann aber de rkurztest mit GSmart Control?
Sieht mir nicht danach aus:
Ich dachte mehr an Eintrag Nr. 24, dort wurden doch auch die Daten ausgelesen.
