inxi -Fz
Kernel: 6.5.0-1-MANJARO arch: x86_64 bits: 64 Desktop: Xfce v: 4.18.1
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: G750JS v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G750JS v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G750JS.208 date: 07/17/2014
ID-1: BAT0 charge: 48.4 Wh (98.6%) condition: 49.1/77.0 Wh (63.8%)
volts: 14.8 min: 14.8
Info: quad core model: Intel Core i7-4700HQ bits: 64 type: MT MCP cache:
L2: 1024 KiB
Speed (MHz): avg: 871 min/max: 800/3400 cores: 1: 1200 2: 800 3: 970
4: 800 5: 800 6: 800 7: 800 8: 800
Device-1: Intel 4th Gen Core Processor Integrated Graphics driver: i915
v: kernel
Device-2: NVIDIA GK104M [GeForce GTX 870M] driver: N/A
Device-3: Chicony USB2.0 HD UVC WebCam driver: uvcvideo type: USB
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0 driver: X:
loaded: intel unloaded: nvidia dri: i965 gpu: i915 resolution: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.6-2 renderer: Mesa Intel HD Graphics 4600
(HSW GT2)
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
driver: snd_hda_intel
Device-2: Intel 8 Series/C220 Series High Definition Audio
API: ALSA v: k6.5.0-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
Device-1: Broadcom BCM4352 802.11ac Wireless Network Adapter driver: N/A
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet driver: alx
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: IMC Networks BCM20702A0 driver: btusb type: USB
Local Storage: total: 1.6 TiB used: 909.06 GiB (55.6%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS541515A9E630
ID-2: /dev/sdb vendor: SanDisk model: SD5SE2256G1002E size: 238.47 GiB
ID-1: / size: 233.38 GiB used: 123.3 GiB (52.8%) fs: ext4 dev: /dev/sdb2
ID-2: /boot/efi size: 299.4 MiB used: 300 KiB (0.1%) fs: vfat
dev: /dev/sdb1
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (rpm): cpu: 2500
Processes: 276 Uptime: 1m Memory: total: 32 GiB note: est.
available: 30.8 GiB used: 3.16 GiB (10.3%) Shell: Bash inxi: 3.3.29
Moin,
wenn ich mittels xfce4-display-settings --minimal
zwischen Zwei-Monitor-Betrieb und nur Notebook-Betrieb umschalte, dann ist mein Desktop komplett leer und reagiert auf nichts mehr. Es hilft nur ein gewaltsames Abschalten und Wiedereinschalten des Notebooks. Jahrelang war das kein Problem. Es scheint durch irgendein Update oder eine App zu diesem Problem zu kommen. Wie kann ich die Ursache finden?
Gruß Heiko
X-Post from: https://manjaro-forum.de/posting.php?mode=edit&p=32513
