Games not performing well in Wine
Hi :grinning_face_with_smiling_eyes: , i don’t know if i’m allowed to ask this question here :grin: .
Forgive me if i’m not allowed to ask this question. So my doubt is that how to run cracked games on linux. I tried Call Of Duty MW 1 , which is a pretty low end game. This game will give me 60fps if i run it on windows. But in linux if i run it through wine its lagging very much. I cant even play that game. The fps is just between 1 to 4 :hot_face: :tired_face:. I hope you guys can help me :pleading_face:
The inxi --admin --verbosity=7 --filter --no-host --width output
  Kernel: 5.4.144-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: ro root=UUID=481f629a-5acc-45f3-a562-faf631c437f8
  initrd=boot\initramfs-5.4-x86_64.img
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_wayland
  vt: 2 dm: SDDM Distro: Manjaro Linux base: Arch Linux
  Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: HP model: 80CB v: 99.53 serial: <filter> UEFI: Insyde v: F.28
  date: 05/17/2019
  ID-1: BAT1 charge: 34.9 Wh (100.0%) condition: 34.9/34.9 Wh (100.0%)
  volts: 16.7 min: 14.6 model: 131-42-6E HS04041 type: Unknown
  serial: <filter> status: Full
  RAM: total: 6.74 GiB used: 2.14 GiB (31.7%)
  Info: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64
  type: MCP arch: Puma family: 16 (22) model-id: 30 (48) stepping: 1
  microcode: 7030106 cache: L2: 2 MiB bogomips: 17572
  Speed: 998 MHz min/max: 1000/2200 MHz boost: enabled Core speeds (MHz):
  1: 998 2: 998 3: 998 4: 997
  Flags: 3dnowprefetch abm acc_power aes aperfmperf apic arat avx bmi1 bpext
  clflush cmov cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de
  decodeassists extapic extd_apicid f16c flushbyasid fpu fxsr fxsr_opt ht
  hw_pstate ibpb ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor
  movbe msr mtrr nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
  pausefilter pclmulqdq pdpe1gb perfctr_llc perfctr_nb pfthreshold pge pni
  popcnt pse pse36 ptsc rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
  sse4a ssse3 svm svm_lock syscall topoext tsc tsc_scale vme vmmcall wdt xsave
  xsaveopt
  disabled, RSB filling
  Device-1: AMD Mullins [Radeon R4/R5 Graphics] vendor: Hewlett-Packard
  driver: radeon v: kernel alternate: amdgpu bus-ID: 00:01.0
  chip-ID: 1002:9851 class-ID: 0300
  Device-2: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: USB
  driver: uvcvideo bus-ID: 3-1.1:3 chip-ID: 05c8:0382 class-ID: 0e02
  Display: wayland server: X.Org 1.21.1.2 compositor: kwin_wayland driver:
  loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
  display-ID: :1 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
  s-diag: 414mm (16.3")
  Monitor-1: XWAYLAND0 res: 1366x768 hz: 60 dpi: 102
  size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
  OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.4.144-1-MANJARO LLVM 12.0.1)
  v: 4.5 Mesa 21.2.1 direct render: Yes
  Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
  class-ID: 0403
  Device-2: AMD FCH Azalia vendor: Hewlett-Packard driver: snd_hda_intel
  v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
  Sound Server-1: ALSA v: k5.4.144-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.35 running: yes
  Device-1: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
  v: kernel modules: bcma port: 3100 bus-ID: 02:00.0 chip-ID: 14e4:4365
  class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
  driver: r8169 v: kernel port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8136
  class-ID: 0200
  Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
  bus-ID: 1-1.4:3 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
  Local Storage: total: 931.51 GiB used: 141.88 GiB (15.2%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
  type: HDD rpm: 5400 serial: <filter> rev: 2C scheme: GPT
  Optical-1: /dev/sr0 vendor: hp model: DVDRW GUB0N rev: UB00 dev-links: cdrom
  ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 11.98 GiB (24.5%)
  fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: 481f629a-5acc-45f3-a562-faf631c437f8
  ID-2: /boot/efi raw-size: 1 GiB size: 1022.6 MiB (99.80%)
  used: 6.3 MiB (0.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: LINUX_BOOT
  uuid: 26EB-9915
  ID-3: /home raw-size: 75 GiB size: 73.27 GiB (97.69%) used: 4.38 GiB (6.0%)
  fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
  uuid: a38ebde5-6d25-4daa-9ad6-b6dfc0336953
  ID-4: /run/media/shervin/Others raw-size: 273.9 GiB
  size: 273.9 GiB (100.00%) used: 125.51 GiB (45.8%) fs: ntfs dev: /dev/sda6
  maj-min: 8:6 label: Others uuid: B0CAF063CAF0276E
  ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 4e946f44-e3cf-4d65-a1a4-2ec872e6c4a4
  ID-1: /dev/sda5 maj-min: 8:5 size: 381 GiB fs: ntfs label: Gaming
  uuid: 6C38EEE738EEAEF0
  ID-2: /dev/sda7 maj-min: 8:7 size: 46 GiB fs: ext4 label: N/A
  uuid: 2bd326aa-b81e-4dde-985e-d897b73dac2a
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
  speed: 480 Mb/s power: 100mA chip-ID: 0438:7900 class-ID: 0900
  Device-1: 1-1.4:3 info: Broadcom BCM43142A0 Bluetooth 4.0 type: Bluetooth
  driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:216d
  Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Device-1: 2-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
  driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 98mA chip-ID: 046d:c534 class-ID: 0301
  Device-2: 2-2:3 info: China Resource Semico Keyboard type: Keyboard,HID
  power: 98mA chip-ID: 1a2c:2124 class-ID: 0300
  Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-5: 3-1:2 info: Advanced Micro Devices Root Hub ports: 4 rev: 2.0
  Device-1: 3-1.1:3
  info: Cheng Uei Precision Industry (Foxlink) HP Truevision HD type: Video
  Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 60.0 C mobo: 20.0 C gpu: radeon temp: 53.0 C
  Processes: 182 Uptime: 26m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1160 pacman: 1153 lib: 330 flatpak: 7
  Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.06 ```
Not to run cracked games.
Install games in Lutris so you have good support with WINE and other tool made to run Windows games.
Legality
Criminal solicitation is strictly forbidden. In this context, “criminal solicitation” shall mean, “To actively or passively inform about, facilitate, incite, move, or persuade others to some act of lawlessness or illegal activity.”
Therefore, do not post discussions about or link to criminal solicitation in any form. This includes, but is not limited to information or links to facilitate illegal drug use, theft, network intrusion, creation of code for malicious purposes, prohibited software copying, prohibited use of copyrighted/patented material, so-called “warez”, or sites which provide torrents or links to such content. Illegal content will be removed swiftly and dealt with in full accordance with known applicable law.
Beyond the above, please take note of the following very important information
As it is located in Germany, the Manjaro forum server is under German law. German law is quite strict when it comes to copyright protection. The relevant laws are complicated and change fast. We don’t endorse any illegal use of copyrighted material. Therefore, we reserve the right to delete any postings that include copyrighted material, links that make copyrighted material illegally available, and/or postings that advocate the use of software that is used to use copyrighted material in an illegal way. There are many pages on the internet that deal with copyright infringements.
forum.manjaro.org is not a site for copyright violations. - Forum rules - Legality
