Hi guys! i had a similar problem before but now nothing helps. I checked every topic about the microphone on the forum and none of the solutions helped me…
I have problem with my microphone, i can’t record my voice, no one can hear me on a call.
I have tried already:
downgrade alsa / reinstall alsa - it helps before but now not.
downgrade/upgrade kernel
change desktop environment to plasma or cinamon
Can You guys help me please? What can i do to better show the problem?
Best regards!
post formated output from: inxi -Fazy
Thanks for your answer!
Here is input you requested:
Kernel: 5.15.36-1-rt41-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-rt-x86_64
root=UUID=1688d81b-6f18-440d-989b-04e1d872c2a1 rw quiet apparmor=1
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 2 dm: 1: GDM v: 41.3 2: LightDM v: 1.30.0 note: stopped
Type: Laptop System: LENOVO product: 81YM v: IdeaPad 5 14ARE05
serial: <superuser required> Chassis: type: 10 v: IdeaPad 5 14ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: DTCN23WW(V1.09)
date: 10/26/2020
ID-1: BAT1 charge: 14.2 Wh (33.6%) condition: 42.2/44.5 Wh (94.8%)
volts: 10.9 min: 11.1 model: 0x53 0x4D 0x50 0x00 0x32 0x30 0x 0x4C 0x31
0x39 0x4D 0x33 0x50 0x4450
type: Li-ion serial: <filter> status: discharging cycles: 237
Info: model: AMD Ryzen 7 4800U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1398 high: 1655 min/max: 1400/1800 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1419 2: 1655
3: 1388 4: 1397 5: 1366 6: 1397 7: 1490 8: 1397 9: 1301 10: 1397 11: 1373
12: 1397 13: 1337 14: 1271 15: 1444 16: 1345 bogomips: 57487
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1,eDP-1 empty: DP-1
bus-ID: 04:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 04f2:b6c2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 with: Xwayland v: 22.1.1
compositor: xfwm v: 4.16.1 driver: X: loaded: amdgpu
unloaded: modesetting,radeon alternate: fbdev,vesa gpu: amdgpu
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.00x11.22")
s-diag: 1055mm (41.54")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left
model: Idek Iiyama PL2280H serial: <filter> built: 2014 res: 1920x1080
hz: 60 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55")
diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: right model: ChiMei InnoLux 0x140a
built: 2019 res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 04:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.36-1-rt41-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:c822
class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 176.81 GiB (37.1%)
model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
rev: AL2QFXV7 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 475.69 GiB size: 467.16 GiB (98.21%)
used: 176.78 GiB (37.8%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 28.6 MiB (11.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 46.0 C mobo: N/A gpu: amdgpu temp: 45.0 C
Processes: 412 Uptime: 17m wakeups: 2 Memory: 15.07 GiB
used: 2.41 GiB (16.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1557 pacman: 1541 lib: 365 flatpak: 0
snap: 16 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.15
first, there was a stable update, did you already updated?
It was a big update. I did it, but it not fixed my problem
I recorded a clip where you can see wierd microphone behawior. Also i can record sound from system, but cant record my voice.
https://youtu.be/O8OB1NTI0Hw
brahma
May 13, 2022, 10:19am
6
ok, so try to install pipewire with this package: manjaro-pipewire
if you get any dependencies issues, uninstall them first, then install pipewire and reboot and check
i had to uinstiall some pulseaudio dependencies, i did it and i installed manjaro-pipewire
Preparing...
Warning: manjaro-pipewire-20220217-2 is up to date -- skipping
Nothing to do.
then rebooted system and still the same
brahma
May 13, 2022, 10:37am
8
try installing sof-firmaware
if doesnt work install the latest kernel 5.17, reboot, boot with the 5.17 kernel and check
Ok so, sof-firmware was allready installed:
Warning: sof-firmware-2.1.1-1 is up to date -- skipping
Nothing to do.
i istalled and run kernel 5.17, reboot my system unfortunately it did not bring any effect
Kernel: 5.17.1-1-rt17-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
brahma
May 13, 2022, 5:31pm
10
you could try command in this link , then reboot and check
I’m sorry for the late response. I tried this command as one of the first, unfortunately it did not help.
brahma
May 16, 2022, 7:33am
12
so you could try to boot into manjaro xfce usb and in the live session try the microphone
