I was in the middle of performing the latest update to my manjaro installation and the pacman -Syu process hung up in the middle of applying application updates. I wanted for a long time, but noticed that my system had become completely unresponsive.
I knew upon rebooting that the boot would fail. Sure enough, no kernal could be located. I found a helpful article for using manjaro-chroot to attempt to complete the interrupted update, but I’m having a problem.
My configuration is that I use a ZFS formatted NVME drive with an encrypted root partition.
Here is the drive setup:
manjaro@manjaro ~]$ sudo fdisk -l
Disk /dev/nvme0n1: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: Sabrent Rocket Q
Disklabel type: gpt
Disk identifier: 0E732033-A74D-C54B-A391-F4164B04CCCE
Device Start End Sectors Size Type
/dev/nvme0n1p1 4096 618495 614400 300M EFI System
/dev/nvme0n1p2 618496 1953520064 1952901569 931.2G Linux filesystem
I downloaded the latest manjaro live USB and performed the following:
[manjaro@manjaro ~]$ su -
Password:
[manjaro ~]# cryptsetup luksOpen /dev/nvme0n1p2 crypt
[manjaro ~]# mount /dev/mapper/crypt /mnt
[manjaro ~]# mount /dev/nvme0n1p1 /mnt/boot/efi
[manjaro ~]# manjaro-chroot /mnt
chroot: failed to run command '/bin/sh': Exec format error
I have no idea why I’m getting this error. Can someone help me? I’ve been at this for a few hours now.
