I was try to update my graphics card drivers to latest release and to do so I uninstalled the already installed drivers ( nvidia drivers ) . Now it did not install the newer drivers after some struggle so I decided to reinstall the previous drivers but now I cant do it . I know I need to use mhwd to install it via some scripts but its not working even then , its throwing errors left right centre.
Error -
Installing video-nvidia…
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core downloading…
extra downloading…
community downloading…
multilib downloading…
error: target not found: linux511-nvidia
error: target not found: linux512-nvidia
Error: pacman failed!
Error: script failed!
These are my system specs -
CPU: Intel i5-4460 (4) @ 3.
GPU: NVIDIA GeForce GTX 750
Memory: 4077MiB / 15951MiB
OS: Manjaro Linux x86_64
Kernel: 5.12.19-1-MANJARO
I ran - sudo mhwd -i pci video-nvidia
If anyone could help out that would be great !!
