tengo un problema con el espaciado de Konsole, no afecta el funcionamiento pero si es engorroso y confuso
https://paste.pics/3808b51aa98968c5f70fa60861909a5e
dejo esto por asi acaso
Kernel: 6.1.12-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=57850b16-6248-4d84-862f-fc2d04fd57f6 rw quiet splash apparmor=1
security=apparmor resume=UUID=4f4d88d3-1c59-46a1-bf88-25d66cb186ad
udev.log_priority=3
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Hewlett-Packard product: 120-1150la v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: Quanta model: 2AE9 v: 011 serial: <superuser required> UEFI: AMI
v: AR2_700 date: 03/12/2012
RAM: total: 7.38 GiB used: 1.74 GiB (23.6%)
Info: model: AMD E2-1800 APU with Radeon HD Graphics bits: 64 type: MCP
arch: Bobcat level: v1 built: 2011-13 process: GF 40nm family: 0x14 (20)
model-id: 2 stepping: 0 microcode: 0x5000119
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
Speed (MHz): avg: 848 high: 849 min/max: 850/1700 boost: disabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 849 2: 848 bogomips: 6787
Flags: 3dnowprefetch abm aperfmperf apic arat clflush cmov cmp_legacy
constant_tsc cpuid cr8_legacy cx16 cx8 de extapic extd_apicid fpu fxsr
fxsr_opt ht hw_pstate ibs lahf_lm lbrv lm mca mce misalignsse mmx mmxext
monitor msr mtrr nonstop_tsc nopl npt nrip_save nx pae pat pausefilter
pdpe1gb pge pni popcnt pse pse36 rdtscp rep_good sep skinit sse sse2 sse4a
ssse3 svm svm_lock syscall tsc vme vmmcall wdt
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Wrestler [Radeon HD 7340] vendor: Hewlett-Packard
driver: radeon v: kernel alternate: amdgpu arch: TeraScale-2 code: Evergreen
process: TSMC 32-40nm built: 2009-15 ports: active: LVDS-1 empty: none
bus-ID: 00:01.0 chip-ID: 1002:9808 class-ID: 0300
Device-2: Chicony HP 0.3MP Webcam type: USB driver: uvcvideo bus-ID: 1-4:4
chip-ID: 04f2:b2ce class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: r600
gpu: radeon display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: LVDS-1 mapped: LVDS model: HP Omni / Pro serial: <filter>
built: 2009 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes:
max: 1600x900 min: 640x480
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: AMD SBx00 Azalia vendor: Hewlett-Packard driver: snd_hda_intel
v: kernel bus-ID: 00:14.2 chip-ID: 1002:4383 class-ID: 0403
Sound API: ALSA v: k6.1.12-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Ralink RT5390 Wireless 802.11n 1T/1R PCIe driver: rt2800pci
v: 2.3.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 1814:5390 class-ID: 0280
IP v4: <filter> type: secondary dynamic noprefixroute scope: global
Device-2: Realtek RTL810xE PCI Express Fast Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 4-5:4 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 945.95 GiB used: 43.36 GiB (4.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HDS721010CLA630
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: A41A scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston
model: DataTraveler 3.0 size: 14.44 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
Optical-1: /dev/sr0 vendor: hp model: CDDVDW SN-208BB rev: HD20
dev-links: cdrom
ID-1: / raw-size: 139.33 GiB size: 136.08 GiB (97.67%)
used: 43.36 GiB (31.9%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 57850b16-6248-4d84-862f-fc2d04fd57f6
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: BC9A-4F4F
ID-1: swap-1 type: partition size: 6.8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 4f4d88d3-1c59-46a1-bf88-25d66cb186ad
ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
uuid: 5E9E-144E
ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda3 maj-min: 8:3 size: 784.41 GiB fs: ntfs label: N/A
uuid: 30EEA2BBEEA2792C
ID-4: /dev/sda4 maj-min: 8:4 size: 518 MiB fs: ntfs label: N/A
uuid: B89C60C89C6082AC
ID-5: /dev/sdb1 maj-min: 8:17 size: 14.44 GiB fs: vfat label: IAN
uuid: F230-F081
Hub-1: 1-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4:4 info: Chicony HP 0.3MP Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b2ce
Hub-2: 2-0:1 info: Full speed or root hub ports: 5 rev: 2.0 speed: 480 Mb/s
Device-1: 2-5:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s
power: 300mA chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Full speed or root hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-4: 4-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Device-1: 4-1:2 info: Chicony USB Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 04f2:1060 class-ID: 0300
Device-2: 4-2:3 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 0000:3825 class-ID: 0301
Device-3: 4-5:4 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Hub-5: 5-0:1 info: Full speed or root hub ports: 5 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Full speed or root hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed or root hub ports: 4 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 67.5 C mobo: N/A gpu: radeon temp: 68.0 C
Processes: 189 Uptime: 47m wakeups: 0 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1326
pm: pacman pkgs: 1295 libs: 448 tools: pamac pm: flatpak pkgs: 20 pm: snap
pkgs: 11 Shell: Zsh v: 5.9 running-in: xfce4-terminal inxi: 3.3.25
