Problemas ao instalar o mysql pelo AUR
aur
#1
Senhores, olá. Estou com o seguinte problema ao instalar o mysql pelo AUR.
[ 55%] Building CXX object plugin/x/protocol/CMakeFiles/mysqlxmessages.dir/__/generated/protobuf/mysqlx_crud.pb.cc.o
[ 55%] Building CXX object plugin/x/protocol/CMakeFiles/mysqlxmessages.dir/__/generated/protobuf/mysqlx_datatypes.pb.cc.o
[ 55%] Building CXX object plugin/x/protocol/CMakeFiles/mysqlxmessages.dir/__/generated/protobuf/mysqlx_expect.pb.cc.o
[ 55%] Building CXX object plugin/x/protocol/CMakeFiles/mysqlxmessages.dir/__/generated/protobuf/mysqlx_expr.pb.cc.o
[ 55%] Building CXX object plugin/x/protocol/CMakeFiles/mysqlxmessages.dir/__/generated/protobuf/mysqlx_notice.pb.cc.o
[ 55%] Building CXX object plugin/x/protocol/CMakeFiles/mysqlxmessages.dir/__/generated/protobuf/mysqlx_resultset.pb.cc.o
[ 55%] Building CXX object plugin/x/protocol/CMakeFiles/mysqlxmessages.dir/__/generated/protobuf/mysqlx_session.pb.cc.o
[ 55%] Building CXX object plugin/x/protocol/CMakeFiles/mysqlxmessages.dir/__/generated/protobuf/mysqlx_sql.pb.cc.o
[ 55%] Linking CXX static library ../../../archive_output_directory/libmysqlxmessages.a
[ 55%] Built target mysqlxmessages
Scanning dependencies of target xprotocol_plugin
[ 55%] Building CXX object plugin/x/protocol/plugin/CMakeFiles/xprotocol_plugin.dir/message_field_chain.cc.o
[ 55%] Building CXX object plugin/x/protocol/plugin/CMakeFiles/xprotocol_plugin.dir/xprotocol_plugin.cc.o
[ 55%] Linking CXX executable ../../../../runtime_output_directory/xprotocol_plugin
/usr/bin/ld.gold: fatal error: ../../../../runtime_output_directory/xprotocol_plugin: Não há espaço disponível no dispositivo
collect2: error: ld returned 1 exit status
make[2]: *** [plugin/x/protocol/plugin/CMakeFiles/xprotocol_plugin.dir/build.make:103: runtime_output_directory/xprotocol_plugin] Error 1
make[1]: *** [CMakeFiles/Makefile2:6128: plugin/x/protocol/plugin/CMakeFiles/xprotocol_plugin.dir/all] Error 2
make: *** [Makefile:163: all] Error 2
==> ERRO: Uma falha ocorreu em build().
    Abortando...
O que acham que eu deveria fazer? Desistir de instalar pelo aur do manjaro, e tentar baixar pelo próprio site do mysql?
#2
Unless you specifically need MySQL, try MariaDB from the repos. It’s (supposed to be) a drop-in replacement.
#3
What is the problem with mysql?
#4
https://www.archlinux.org/news/mariadb-replaces-mysql-in-repositories/
https://wiki.archlinux.org/index.php/MySQL
#5
