Problema durante l'avvio del sistema.
Buongiorno, dopo gli ultimi aggiornamenti, durante l'avvio del sistema mi ritrovo questa scritta: "error resume no device specified for hibernation". Come mai? non ho mai utilizzato questa funzione e cercando soluzioni su internet, mi sono accorto che la scritta esce solo ha chi elimina la partizione di swap, cosa che non ho fatto.
Grazie in anticipo!
Hello, after the latest updates, during the system startup I find this writing: "error resume no device specified for hibernation". Why? I have never used this function and looking for solutions on the internet, I realized that the writing comes out only has those who delete the swap partition, which I did not do.
Thanks in advance!
  Host: gianfilippo-pc Kernel: 4.19.62-1-MANJARO x86_64 bits: 64
  compiler: gcc v: 9.1.0 Desktop: Xfce 4.13.6 tk: Gtk 3.24.10
  info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
  serial: <filter> Chassis: Hewlett-Packard type: 10 serial: <filter>
  Mobo: HP model: 81F1 v: 64.66 serial: <filter> UEFI: Insyde v: F.46
  date: 11/16/2018
  ID-1: BAT1 charge: 11.6 Wh condition: 39.8/41.6 Wh (96%) volts: 15.1/14.6
  model: COMPAL PABAS0241231 type: Li-ion serial: <filter> status: Charging
  Topology: Quad Core model: Intel Pentium N3710 bits: 64 type: MCP
  arch: Airmont rev: 4 L2 cache: 1024 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12805
  Speed: 480 MHz min/max: 480/2560 MHz Core speeds (MHz): 1: 480 2: 480
  3: 528 4: 555
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx
  Integrated Graphics
  vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
  chip ID: 8086:22b1
  Display: x11 server: X.Org 1.20.5 driver: intel resolution: 1366x768~60Hz
  OpenGL: renderer: Mesa DRI Intel HD Graphics 405 (Braswell)
  v: 4.5 Mesa 19.1.3 compat-v: 3.0 direct render: Yes
  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
  High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:2284
  Sound Server: ALSA v: k4.19.62-1-MANJARO
  Device-1: Realtek RTL8723BE PCIe Wireless Network Adapter
  vendor: Hewlett-Packard driver: rtl8723be v: kernel port: 2000
  bus ID: 02:00.0 chip ID: 10ec:b723
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 1000 bus ID: 03:00.0
  chip ID: 10ec:8136
  Local Storage: total: 931.51 GiB used: 11.07 GiB (1.2%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
  speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 4C scheme: GPT
  ID-1: / size: 907.59 GiB used: 11.07 GiB (1.2%) fs: ext4 dev: /dev/sda2
  ID-2: swap-1 size: 8.14 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda3
  System Temperatures: cpu: 44.0 C mobo: 27.8 C
  Processes: 173 Uptime: 9m Memory: 3.70 GiB used: 947.6 MiB (25.0%)
  Init: systemd v: 242 Compilers: gcc: 9.1.0 Shell: bash v: 5.0.7
  running in: xfce4-terminal inxi: 3.0.35
Ciao,
posta
lsblk -f
e
cat /etc/default/grub
lsblk -f
NAME FSTYPE LABEL UUID                                 FSAVAIL FSUSE% MOUNTPOINT
sda
├─sda1
│    vfat         6F12-BD62                             299,1M     0% /boot/efi
├─sda2
│    ext4         2857642f-9d2a-4b37-a8b8-3038a027bab6  851,6G     1% /
└─sda3
     swap         49fa9649-fd7b-4c1a-8840-1aaa1191bf3f                [SWAP]
sr0
GRUB_DEFAULT=saved
GRUB_TIMEOUT=5
GRUB_TIMEOUT_STYLE=menu
GRUB_DISTRIBUTOR="Manjaro"
GRUB_CMDLINE_LINUX_DEFAULT="quiet udev.log_priority=3 audit=0"
GRUB_CMDLINE_LINUX=""
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
#GRUB_ENABLE_CRYPTODISK=y
GRUB_TERMINAL_INPUT=console
#GRUB_TERMINAL_OUTPUT=console
GRUB_GFXMODE=auto
GRUB_GFXPAYLOAD_LINUX=keep
#GRUB_DISABLE_LINUX_UUID=true
GRUB_DISABLE_RECOVERY=true
# Uncomment and set to the desired menu colors.  Used by normal and wallpaper
# modes only.  Entries specified as foreground/background.
#GRUB_THEME="/path/to/gfxtheme"
#GRUB_INIT_TUNE="480 440 1"
prova questo:
sudo update-grub
sudo mkinitcpio -P
sudo reboot
provato, grazie, ma il messaggio di errore persiste
grep "^HOOKS" /etc/mkinitcpio.conf
cat /etc/fstab
HOOKS="base udev autodetect modconf block keyboard keymap resume filesystems"
cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=6F12-BD62                            /boot/efi      vfat    defaults,noatime 0 2
UUID=2857642f-9d2a-4b37-a8b8-3038a027bab6 /              ext4    defaults,noatime 0 1
UUID=49fa9649-fd7b-4c1a-8840-1aaa1191bf3f swap           swap    defaults,noatime 0 2
togli "resume"
poi
sudo mkinitcpio -P
sudo reboot
grazie mille per il tuo tempo, ha funzionato!
con piacere :grinning: !
