Hello everyone, I just installed Manjaro ARM on my rpi4 and was wondering how I would go about just launching a cli on login, rather than starting all of xfce. In doing this I want to just decrease the load the pi has, while still maintaining the ability to start xfce/xorg when I want.
I thought maybe lightdm was handling this somewhere, but could not find anything. I did this on arch with my laptop years ago with my .bash_profile and .xinitrc but can’t figure out where the relevant config files live on this new install. Any help is appreciated!
Take a gander at the thread I mentioned above (the OP was gdm). On a systemd-system, which Manjaro is, If you reference display-manager.service you don’t need to know if the display manager is lightdm or gdm. Your answer will most likely be in systemd/systemctl.
# Should show you what display manager was started
grep -i execstart /etc/systemd/system/display-manager.service
# Should show that display-manager.service is a symlink to your specific display manager
stat /etc/systemd/system/display-manager.service
