Problema al instalar thinkfan
Cuando instalo thinkfan a traves de yay
ocurre el siguiente error.
-- The C compiler identification is GNU 9.2.0
-- The CXX compiler identification is GNU 9.2.0
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Could NOT find PkgConfig (missing: PKG_CONFIG_EXECUTABLE)
CMake Error at CMakeLists.txt:59 (message):
USE_YAML enabled but yaml-cpp not found. Please install yaml-cpp[-devel]!
Intale las depencia:
pacman -S yaml-cpp
pacman -S make
yay libatasmart
