Problem with wireless connection
There is another topic with this problem but it did not help, I was wondering if anyone has already solved this problem. I checked trying with modprobe rt2800pci, no logs, just got logs with NetworkManager that should be causing the problem.
ice (enp0s26u1u4): Activation: starting connection 'Conexão cabeada 2' (2d55c812-f904-32ce-92c0-68132be84059)
jun 08 20:46:11 manjaro-pc NetworkManager[490]: <info>  [1560037571.1597] device (enp0s26u1u4): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
jun 08 20:46:11 manjaro-pc NetworkManager[490]: <info>  [1560037571.1611] manager: NetworkManager state is now CONNECTING
jun 08 20:46:11 manjaro-pc NetworkManager[490]: <info>  [1560037571.1702] device (enp0s26u1u4): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
jun 08 20:46:11 manjaro-pc NetworkManager[490]: <info>  [1560037571.1716] device (enp0s26u1u4): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
jun 08 20:46:11 manjaro-pc NetworkManager[490]: <info>  [1560037571.1728] dhcp4 (enp0s26u1u4): activation: beginning transaction (timeout in 45 seconds)
jun 08 20:46:11 manjaro-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 20:46:11 manjaro-pc kernel: audit: type=1130 audit(1560037571.471:89): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.7985] dhcp4 (enp0s26u1u4):   address 192.168.42.62
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.7986] dhcp4 (enp0s26u1u4):   plen 24
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.7986] dhcp4 (enp0s26u1u4):   expires in 3600 seconds (at 1560041173)
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.7987] dhcp4 (enp0s26u1u4):   nameserver '192.168.42.129'
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.7987] dhcp4 (enp0s26u1u4):   hostname 'manjaro-pc'
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.7988] dhcp4 (enp0s26u1u4):   router 192.168.42.129
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.7992] dhcp4 (enp0s26u1u4): state changed unknown -> bound
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.8014] device (enp0s26u1u4): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.8029] device (enp0s26u1u4): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.8036] device (enp0s26u1u4): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.8046] manager: NetworkManager state is now CONNECTED_LOCAL
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.8553] manager: NetworkManager state is now CONNECTED_SITE
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.8556] policy: set 'Conexão cabeada 2' (enp0s26u1u4) as default for IPv4 routing and DNS
jun 08 20:46:13 manjaro-pc NetworkManager[490]: <info>  [1560037573.9093] device (enp0s26u1u4): Activation: successful, device activated.
jun 08 20:46:15 manjaro-pc NetworkManager[490]: <info>  [1560037575.1034] manager: NetworkManager state is now CONNECTED_GLOBAL
jun 08 20:46:18 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 20:46:18 manjaro-pc NetworkManager[490]: <info>  [1560037578.8098] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 20:46:18 manjaro-pc kernel: audit: type=1111 audit(1560037578.804:90): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 20:46:19 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 20:46:19 manjaro-pc NetworkManager[490]: <info>  [1560037579.3672] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 20:46:19 manjaro-pc kernel: audit: type=1111 audit(1560037579.364:91): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 20:46:21 manjaro-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
jun 08 20:46:21 manjaro-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 20:46:21 manjaro-pc kernel: audit: type=1131 audit(1560037581.684:92): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.2593] device (enp0s26u1u4): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.2597] dhcp4 (enp0s26u1u4): canceled DHCP transaction
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.2597] dhcp4 (enp0s26u1u4): state changed bound -> done
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.3569] manager: NetworkManager state is now DISCONNECTED
jun 08 20:55:55 manjaro-pc dbus-daemon[489]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=490 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 20:55:55 manjaro-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 20:55:55 manjaro-pc kernel: audit: type=1130 audit(1560038155.448:93): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 20:55:55 manjaro-pc kdeinit5[835]: networkmanager-qt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "Filename"
jun 08 20:55:55 manjaro-pc kdeinit5[835]: networkmanager-qt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "Flags"
jun 08 20:55:55 manjaro-pc kdeinit5[835]: plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings/16"
jun 08 20:55:55 manjaro-pc plasmashell[881]: networkmanager-qt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "Filename"
jun 08 20:55:55 manjaro-pc plasmashell[881]: networkmanager-qt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "Flags"
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.5777] manager: (usb0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/21)
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6222] device (usb0): interface index 24 renamed iface from 'usb0' to 'enp0s26u1u4'
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6325] device (enp0s26u1u4): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6337] device (enp0s26u1u4): carrier: link connected
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6369] keyfile: add connection /var/run/NetworkManager/system-connections/Conexão cabeada 2.nmconnection (2d55c812-f904-32ce-92c0-68132be84059,"Conexão cabeada 2")
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6378] settings: (enp0s26u1u4): created default wired connection 'Conexão cabeada 2'
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6501] device (enp0s26u1u4): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6513] policy: auto-activating connection 'Conexão cabeada 2' (2d55c812-f904-32ce-92c0-68132be84059)
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6526] device (enp0s26u1u4): Activation: starting connection 'Conexão cabeada 2' (2d55c812-f904-32ce-92c0-68132be84059)
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6531] device (enp0s26u1u4): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6536] manager: NetworkManager state is now CONNECTING
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6540] device (enp0s26u1u4): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6547] device (enp0s26u1u4): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.6586] dhcp4 (enp0s26u1u4): activation: beginning transaction (timeout in 45 seconds)
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8587] dhcp4 (enp0s26u1u4):   address 192.168.42.62
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8588] dhcp4 (enp0s26u1u4):   plen 24
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8588] dhcp4 (enp0s26u1u4):   expires in 3600 seconds (at 1560041755)
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8589] dhcp4 (enp0s26u1u4):   nameserver '192.168.42.129'
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8589] dhcp4 (enp0s26u1u4):   hostname 'manjaro-pc'
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8590] dhcp4 (enp0s26u1u4):   router 192.168.42.129
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8594] dhcp4 (enp0s26u1u4): state changed unknown -> bound
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8613] device (enp0s26u1u4): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8624] device (enp0s26u1u4): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8627] device (enp0s26u1u4): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.8635] manager: NetworkManager state is now CONNECTED_LOCAL
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.9288] manager: NetworkManager state is now CONNECTED_SITE
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.9290] policy: set 'Conexão cabeada 2' (enp0s26u1u4) as default for IPv4 routing and DNS
jun 08 20:55:55 manjaro-pc NetworkManager[490]: <info>  [1560038155.9631] device (enp0s26u1u4): Activation: successful, device activated.
jun 08 20:55:56 manjaro-pc NetworkManager[490]: <info>  [1560038156.5650] manager: NetworkManager state is now CONNECTED_GLOBAL
jun 08 20:56:05 manjaro-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
jun 08 20:56:05 manjaro-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 20:56:05 manjaro-pc kernel: audit: type=1131 audit(1560038165.688:94): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:03:55 manjaro-pc NetworkManager[490]: <info>  [1560038635.6865] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 21:03:55 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:03:55 manjaro-pc kernel: audit: type=1111 audit(1560038635.682:95): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:03:57 manjaro-pc NetworkManager[490]: <info>  [1560038637.0066] audit: op="radio-control" arg="wireless-enabled" pid=881 uid=1000 result="success"
jun 08 21:03:57 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:03:57 manjaro-pc kernel: audit: type=1111 audit(1560038637.001:96): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:03:57 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:03:57 manjaro-pc NetworkManager[490]: <info>  [1560038637.8301] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 21:03:57 manjaro-pc kernel: audit: type=1111 audit(1560038637.825:97): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:03:59 manjaro-pc NetworkManager[490]: <info>  [1560038639.3836] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 21:03:59 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:03:59 manjaro-pc kernel: audit: type=1111 audit(1560038639.378:98): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:04:00 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:04:00 manjaro-pc kernel: audit: type=1111 audit(1560038640.611:99): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:04:00 manjaro-pc NetworkManager[490]: <info>  [1560038640.6179] audit: op="radio-control" arg="wireless-enabled" pid=881 uid=1000 result="success"
jun 08 21:04:00 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:04:00 manjaro-pc NetworkManager[490]: <info>  [1560038640.9372] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 21:04:00 manjaro-pc kernel: audit: type=1111 audit(1560038640.931:100): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:04:12 manjaro-pc NetworkManager[490]: <info>  [1560038652.2787] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 21:04:12 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:04:12 manjaro-pc kernel: audit: type=1111 audit(1560038652.274:101): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:04:13 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:04:13 manjaro-pc kernel: audit: type=1111 audit(1560038653.398:102): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:04:13 manjaro-pc NetworkManager[490]: <info>  [1560038653.4013] audit: op="radio-control" arg="wireless-enabled" pid=881 uid=1000 result="success"
jun 08 21:04:15 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:04:15 manjaro-pc NetworkManager[490]: <info>  [1560038655.4618] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 21:04:15 manjaro-pc kernel: audit: type=1111 audit(1560038655.461:103): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:06:52 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:06:52 manjaro-pc kernel: audit: type=1111 audit(1560038812.019:104): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:06:52 manjaro-pc NetworkManager[490]: <info>  [1560038812.0235] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 21:06:52 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:06:52 manjaro-pc NetworkManager[490]: <info>  [1560038812.9947] audit: op="radio-control" arg="wireless-enabled" pid=881 uid=1000 result="success"
jun 08 21:06:52 manjaro-pc kernel: audit: type=1111 audit(1560038812.989:105): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:06:53 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:06:53 manjaro-pc kernel: audit: type=1111 audit(1560038813.292:106): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:06:53 manjaro-pc NetworkManager[490]: <info>  [1560038813.2978] audit: op="radio-control" arg="wireless-enabled" pid=881 uid=1000 result="success"
jun 08 21:06:53 manjaro-pc NetworkManager[490]: <info>  [1560038813.4905] audit: op="radio-control" arg="wireless-enabled" pid=881 uid=1000 result="success"
jun 08 21:06:53 manjaro-pc kernel: audit: type=1111 audit(1560038813.485:107): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:06:55 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:06:55 manjaro-pc NetworkManager[490]: <info>  [1560038815.6201] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 21:06:55 manjaro-pc kernel: audit: type=1111 audit(1560038815.615:108): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:08:45 manjaro-pc NetworkManager[490]: <info>  [1560038925.2837] device (enp0s26u1u4): state change: activated -> unmanaged (reason 'removed', sys-iface-state: 'removed')
jun 08 21:08:45 manjaro-pc NetworkManager[490]: <info>  [1560038925.2841] dhcp4 (enp0s26u1u4): canceled DHCP transaction
jun 08 21:08:45 manjaro-pc NetworkManager[490]: <info>  [1560038925.2841] dhcp4 (enp0s26u1u4): state changed bound -> done
jun 08 21:08:45 manjaro-pc NetworkManager[490]: <info>  [1560038925.3272] manager: NetworkManager state is now DISCONNECTED
jun 08 21:08:45 manjaro-pc dbus-daemon[489]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=490 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:08:45 manjaro-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:08:45 manjaro-pc kernel: audit: type=1130 audit(1560038925.382:109): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:08:45 manjaro-pc kdeinit5[835]: networkmanager-qt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "Filename"
jun 08 21:08:45 manjaro-pc kdeinit5[835]: networkmanager-qt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "Flags"
jun 08 21:08:45 manjaro-pc kdeinit5[835]: plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings/17"
jun 08 21:08:45 manjaro-pc plasmashell[881]: networkmanager-qt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "Filename"
jun 08 21:08:45 manjaro-pc plasmashell[881]: networkmanager-qt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "Flags"
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0224] manager: (usb0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/22)
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0623] device (usb0): interface index 25 renamed iface from 'usb0' to 'enp0s26u1u4'
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0706] device (enp0s26u1u4): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0715] device (enp0s26u1u4): carrier: link connected
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0738] keyfile: add connection /var/run/NetworkManager/system-connections/Conexão cabeada 2.nmconnection (2d55c812-f904-32ce-92c0-68132be84059,"Conexão cabeada 2")
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0744] settings: (enp0s26u1u4): created default wired connection 'Conexão cabeada 2'
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0898] device (enp0s26u1u4): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0910] policy: auto-activating connection 'Conexão cabeada 2' (2d55c812-f904-32ce-92c0-68132be84059)
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0920] device (enp0s26u1u4): Activation: starting connection 'Conexão cabeada 2' (2d55c812-f904-32ce-92c0-68132be84059)
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0924] device (enp0s26u1u4): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0930] manager: NetworkManager state is now CONNECTING
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0933] device (enp0s26u1u4): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0939] device (enp0s26u1u4): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.0942] dhcp4 (enp0s26u1u4): activation: beginning transaction (timeout in 45 seconds)
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4694] dhcp4 (enp0s26u1u4):   address 192.168.42.62
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4695] dhcp4 (enp0s26u1u4):   plen 24
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4695] dhcp4 (enp0s26u1u4):   expires in 3600 seconds (at 1560042526)
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4696] dhcp4 (enp0s26u1u4):   nameserver '192.168.42.129'
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4696] dhcp4 (enp0s26u1u4):   hostname 'manjaro-pc'
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4696] dhcp4 (enp0s26u1u4):   router 192.168.42.129
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4700] dhcp4 (enp0s26u1u4): state changed unknown -> bound
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4716] device (enp0s26u1u4): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4727] device (enp0s26u1u4): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4730] device (enp0s26u1u4): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.4739] manager: NetworkManager state is now CONNECTED_LOCAL
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.5066] manager: NetworkManager state is now CONNECTED_SITE
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.5069] policy: set 'Conexão cabeada 2' (enp0s26u1u4) as default for IPv4 routing and DNS
jun 08 21:08:46 manjaro-pc NetworkManager[490]: <info>  [1560038926.5408] device (enp0s26u1u4): Activation: successful, device activated.
jun 08 21:08:47 manjaro-pc NetworkManager[490]: <info>  [1560038927.0553] manager: NetworkManager state is now CONNECTED_GLOBAL
jun 08 21:08:55 manjaro-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
jun 08 21:08:55 manjaro-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:08:55 manjaro-pc kernel: audit: type=1131 audit(1560038935.685:110): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:27:44 manjaro-pc NetworkManager[490]: <info>  [1560040064.0282] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 21:27:44 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:27:44 manjaro-pc kernel: audit: type=1111 audit(1560040064.026:111): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:27:45 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:27:45 manjaro-pc NetworkManager[490]: <info>  [1560040065.4500] audit: op="radio-control" arg="wireless-enabled" pid=881 uid=1000 result="success"
jun 08 21:27:45 manjaro-pc kernel: audit: type=1111 audit(1560040065.446:112): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:27:47 manjaro-pc audit[490]: USYS_CONFIG pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:27:47 manjaro-pc kernel: audit: type=1111 audit(1560040067.026:113): pid=490 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=881 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 21:27:47 manjaro-pc NetworkManager[490]: <info>  [1560040067.0305] audit: op="statistics" arg="refresh-rate-ms" pid=881 uid=1000 result="success"
jun 08 21:28:31 manjaro-pc dbus-daemon[489]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.4' (uid=0 pid=490 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:28:34 manjaro-pc NetworkManager[490]: <info>  [1560040114.4790] modem-manager: ModemManager no longer available
jun 08 21:28:37 manjaro-pc NetworkManager[490]: <info>  [1560040117.5633] caught SIGTERM, shutting down normally.
jun 08 21:28:37 manjaro-pc NetworkManager[490]: <info>  [1560040117.5669] dhcp4 (enp0s26u1u4): canceled DHCP transaction
jun 08 21:28:37 manjaro-pc NetworkManager[490]: <info>  [1560040117.5669] dhcp4 (enp0s26u1u4): state changed bound -> done
jun 08 21:28:37 manjaro-pc NetworkManager[490]: <info>  [1560040117.5670] device (enp0s26u1u4): DHCPv4: 480 seconds grace period started
jun 08 21:28:37 manjaro-pc NetworkManager[490]: <info>  [1560040117.5680] manager: NetworkManager state is now CONNECTED_SITE
jun 08 21:28:37 manjaro-pc dbus-daemon[489]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=490 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:28:37 manjaro-pc NetworkManager[490]: <info>  [1560040117.6016] exiting (success)
jun 08 21:28:37 manjaro-pc systemd[1]: NetworkManager.service: Succeeded.
jun 08 21:28:37 manjaro-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:28:37 manjaro-pc kernel: audit: type=1131 audit(1560040117.751:130): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:29:17 manjaro-pc NetworkManager[474]: <info>  [1560040157.7110] NetworkManager (version 1.18.0-1) is starting... (for the first time)
jun 08 21:29:17 manjaro-pc NetworkManager[474]: <info>  [1560040157.7112] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
jun 08 21:29:17 manjaro-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:29:17 manjaro-pc NetworkManager[474]: <info>  [1560040157.9179] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
jun 08 21:29:17 manjaro-pc NetworkManager[474]: <info>  [1560040157.9186] manager[0x55ea3fe700a0]: monitoring kernel firmware directory '/lib/firmware'.
jun 08 21:29:17 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:29:18 manjaro-pc NetworkManager[474]: <info>  [1560040158.3882] hostname: hostname: using hostnamed
jun 08 21:29:18 manjaro-pc NetworkManager[474]: <info>  [1560040158.3883] hostname: hostname changed from (none) to "manjaro-pc"
jun 08 21:29:18 manjaro-pc NetworkManager[474]: <info>  [1560040158.3889] dns-mgr[0x55ea3fe53210]: init: dns=default,systemd-resolved rc-manager=symlink
jun 08 21:29:18 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:29:19 manjaro-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.1831] settings: Loaded settings plugin: NMSKeyfilePlugin (internal)
jun 08 21:29:19 manjaro-pc kernel: audit: type=1130 audit(1560040159.177:32): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.2038] settings: Loaded settings plugin: NMSIbftPlugin ("/usr/lib/NetworkManager/1.18.0-1/libnm-settings-plugin-ibft.so")
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.3016] manager: rfkill: Wi-Fi enabled by radio killswitch; enabled by state file
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.3018] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.3020] manager: Networking is enabled by state file
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.3114] dhcp-init: Using DHCP client 'internal'
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.3648] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-wifi.so)
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.4898] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-ovs.so)
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.7140] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-team.so)
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.9198] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-bluetooth.so)
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.9689] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-wwan.so)
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.9701] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-adsl.so)
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.9714] device (lo): carrier: link connected
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.9721] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
jun 08 21:29:19 manjaro-pc NetworkManager[474]: <info>  [1560040159.9744] manager: (enp3s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
jun 08 21:29:20 manjaro-pc NetworkManager[474]: <info>  [1560040160.1158] keyfile: add connection /var/run/NetworkManager/system-connections/Conexão cabeada 1.nmconnection (7b3d389f-0d62-354e-9d9c-a208372f4dca,"Conexão cabeada 1")
jun 08 21:29:20 manjaro-pc NetworkManager[474]: <info>  [1560040160.1751] settings: (enp3s0): created default wired connection 'Conexão cabeada 1'
jun 08 21:29:20 manjaro-pc NetworkManager[474]: <info>  [1560040160.1761] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jun 08 21:29:20 manjaro-pc NetworkManager[474]: <info>  [1560040160.3403] ovsdb: Não foi possível conectar: Arquivo ou diretório inexistente
jun 08 21:29:20 manjaro-pc NetworkManager[474]: <info>  [1560040160.8031] modem-manager: ModemManager not available
jun 08 21:29:20 manjaro-pc NetworkManager[474]: <info>  [1560040160.8442] modem-manager: ModemManager now available
jun 08 21:29:22 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:29:26 manjaro-pc NetworkManager[474]: <info>  [1560040166.2172] manager: startup complete
jun 08 21:29:26 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:29:29 manjaro-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
jun 08 21:29:29 manjaro-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:29:29 manjaro-pc kernel: audit: type=1131 audit(1560040169.793:39): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 21:29:34 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:29:50 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:30:22 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:30:23 manjaro-pc NetworkManager[474]: <info>  [1560040223.9247] agent-manager: req[0x55ea3ff25040, :1.67/org.kde.plasma.networkmanagement/1000]: agent registered
jun 08 21:30:23 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:31:28 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:31:33 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:31:34 manjaro-pc NetworkManager[474]: <info>  [1560040294.5066] modem-manager: ModemManager no longer available
jun 08 21:31:34 manjaro-pc NetworkManager[474]: <info>  [1560040294.5135] caught SIGTERM, shutting down normally.
jun 08 21:31:34 manjaro-pc dbus-daemon[473]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=474 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 21:31:34 manjaro-pc NetworkManager[474]: <info>  [1560040294.8542] exiting (success)
jun 08 21:31:34 manjaro-pc systemd[1]: NetworkManager.service: Succeeded.
jun 08 21:31:34 manjaro-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 22:26:25 manjaro-pc NetworkManager[497]: <info>  [1560043585.9794] NetworkManager (version 1.18.0-1) is starting... (for the first time)
jun 08 22:26:25 manjaro-pc NetworkManager[497]: <info>  [1560043585.9797] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
jun 08 22:26:26 manjaro-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 22:26:26 manjaro-pc NetworkManager[497]: <info>  [1560043586.2739] bus-manager: acquired D-Bus service "org.freedesktop.NetworkManager"
jun 08 22:26:26 manjaro-pc NetworkManager[497]: <info>  [1560043586.2744] manager[0x55bf36564010]: monitoring kernel firmware directory '/lib/firmware'.
jun 08 22:26:26 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:26:26 manjaro-pc NetworkManager[497]: <info>  [1560043586.8459] hostname: hostname: using hostnamed
jun 08 22:26:26 manjaro-pc NetworkManager[497]: <info>  [1560043586.8459] hostname: hostname changed from (none) to "manjaro-pc"
jun 08 22:26:26 manjaro-pc NetworkManager[497]: <info>  [1560043586.8466] dns-mgr[0x55bf36543210]: init: dns=default,systemd-resolved rc-manager=symlink
jun 08 22:26:26 manjaro-pc NetworkManager[497]: <info>  [1560043586.8478] rfkill0: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0/ieee80211/phy0/rfkill0) (driver rt2800pci)
jun 08 22:26:26 manjaro-pc NetworkManager[497]: <info>  [1560043586.8481] manager[0x55bf36564010]: rfkill: Wi-Fi hardware radio set enabled
jun 08 22:26:26 manjaro-pc NetworkManager[497]: <info>  [1560043586.8481] manager[0x55bf36564010]: rfkill: WWAN hardware radio set enabled
jun 08 22:26:27 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:26:27 manjaro-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 22:26:27 manjaro-pc NetworkManager[497]: <info>  [1560043587.4868] settings: Loaded settings plugin: NMSKeyfilePlugin (internal)
jun 08 22:26:27 manjaro-pc kernel: audit: type=1130 audit(1560043587.481:36): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 22:26:27 manjaro-pc NetworkManager[497]: <info>  [1560043587.5055] settings: Loaded settings plugin: NMSIbftPlugin ("/usr/lib/NetworkManager/1.18.0-1/libnm-settings-plugin-ibft.so")
jun 08 22:26:27 manjaro-pc NetworkManager[497]: <info>  [1560043587.6032] manager: rfkill: Wi-Fi disabled by radio killswitch; enabled by state file
jun 08 22:26:27 manjaro-pc NetworkManager[497]: <info>  [1560043587.6034] manager: rfkill: WWAN enabled by radio killswitch; enabled by state file
jun 08 22:26:27 manjaro-pc NetworkManager[497]: <info>  [1560043587.6036] manager: Networking is enabled by state file
jun 08 22:26:27 manjaro-pc NetworkManager[497]: <info>  [1560043587.6463] dhcp-init: Using DHCP client 'internal'
jun 08 22:26:27 manjaro-pc NetworkManager[497]: <info>  [1560043587.6697] Loaded device plugin: NMWifiFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-wifi.so)
jun 08 22:26:27 manjaro-pc NetworkManager[497]: <info>  [1560043587.6914] Loaded device plugin: NMOvsFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-ovs.so)
jun 08 22:26:27 manjaro-pc NetworkManager[497]: <info>  [1560043587.9934] Loaded device plugin: NMTeamFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-team.so)
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.1436] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-bluetooth.so)
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.2038] Loaded device plugin: NMWwanFactory (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-wwan.so)
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.2164] Loaded device plugin: NMAtmManager (/usr/lib/NetworkManager/1.18.0-1/libnm-device-plugin-adsl.so)
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.2176] device (lo): carrier: link connected
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.2181] manager: (lo): new Generic device (/org/freedesktop/NetworkManager/Devices/1)
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.2201] manager: (enp3s0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/2)
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.2618] keyfile: add connection /var/run/NetworkManager/system-connections/Conexão cabeada 1.nmconnection (7b3d389f-0d62-354e-9d9c-a208372f4dca,"Conexão cabeada 1")
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.2767] settings: (enp3s0): created default wired connection 'Conexão cabeada 1'
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.2776] device (enp3s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.4904] device (wlp2s0): driver supports Access Point (AP) mode
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.4910] manager: (wlp2s0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.4925] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.4934] device (wlp2s0): set-hw-addr: set MAC address to B6:C6:E0:EC:DC:91 (scanning)
jun 08 22:26:28 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='fi.w1.wpa_supplicant1' unit='wpa_supplicant.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:26:28 manjaro-pc NetworkManager[497]: <info>  [1560043588.5999] ovsdb: Não foi possível conectar: Arquivo ou diretório inexistente
jun 08 22:26:29 manjaro-pc NetworkManager[497]: <info>  [1560043589.0178] supplicant: wpa_supplicant running
jun 08 22:26:29 manjaro-pc NetworkManager[497]: <info>  [1560043589.6690] modem-manager: ModemManager not available
jun 08 22:26:29 manjaro-pc NetworkManager[497]: <info>  [1560043589.7135] modem-manager: ModemManager now available
jun 08 22:26:30 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:26:34 manjaro-pc NetworkManager[497]: <info>  [1560043594.4929] manager: startup complete
jun 08 22:26:34 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:26:37 manjaro-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
jun 08 22:26:37 manjaro-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 22:26:37 manjaro-pc kernel: audit: type=1131 audit(1560043597.705:44): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 22:26:42 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:26:58 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:27:29 manjaro-pc NetworkManager[497]: <info>  [1560043649.9402] agent-manager: req[0x55bf3664a940, :1.78/org.kde.plasma.networkmanagement/1000]: agent registered
jun 08 22:27:30 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:28:02 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2233] manager: (usb0): new Ethernet device (/org/freedesktop/NetworkManager/Devices/4)
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2455] device (usb0): interface index 4 renamed iface from 'usb0' to 'enp0s26u1u4'
jun 08 22:28:09 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.resolve1' unit='dbus-org.freedesktop.resolve1.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2590] device (enp0s26u1u4): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2602] device (enp0s26u1u4): carrier: link connected
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2627] keyfile: add connection /var/run/NetworkManager/system-connections/Conexão cabeada 2.nmconnection (2d55c812-f904-32ce-92c0-68132be84059,"Conexão cabeada 2")
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2633] settings: (enp0s26u1u4): created default wired connection 'Conexão cabeada 2'
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2649] device (enp0s26u1u4): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2660] policy: auto-activating connection 'Conexão cabeada 2' (2d55c812-f904-32ce-92c0-68132be84059)
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2670] device (enp0s26u1u4): Activation: starting connection 'Conexão cabeada 2' (2d55c812-f904-32ce-92c0-68132be84059)
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2672] device (enp0s26u1u4): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2678] manager: NetworkManager state is now CONNECTING
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2682] device (enp0s26u1u4): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2696] device (enp0s26u1u4): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.2702] dhcp4 (enp0s26u1u4): activation: beginning transaction (timeout in 45 seconds)
jun 08 22:28:09 manjaro-pc dbus-daemon[495]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=497 comm="/usr/bin/NetworkManager --no-daemon ")
jun 08 22:28:09 manjaro-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 22:28:09 manjaro-pc kernel: audit: type=1130 audit(1560043689.361:56): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4885] dhcp4 (enp0s26u1u4):   address 192.168.42.62
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4885] dhcp4 (enp0s26u1u4):   plen 24
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4886] dhcp4 (enp0s26u1u4):   expires in 3600 seconds (at 1560047289)
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4886] dhcp4 (enp0s26u1u4):   nameserver '192.168.42.129'
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4886] dhcp4 (enp0s26u1u4):   hostname 'manjaro-pc'
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4886] dhcp4 (enp0s26u1u4):   router 192.168.42.129
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4890] dhcp4 (enp0s26u1u4): state changed unknown -> bound
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4911] device (enp0s26u1u4): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4927] device (enp0s26u1u4): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4933] device (enp0s26u1u4): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.4944] manager: NetworkManager state is now CONNECTED_LOCAL
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.5574] manager: NetworkManager state is now CONNECTED_SITE
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.5578] policy: set 'Conexão cabeada 2' (enp0s26u1u4) as default for IPv4 routing and DNS
jun 08 22:28:09 manjaro-pc NetworkManager[497]: <info>  [1560043689.6440] device (enp0s26u1u4): Activation: successful, device activated.
jun 08 22:28:10 manjaro-pc NetworkManager[497]: <info>  [1560043690.3222] manager: NetworkManager state is now CONNECTED_GLOBAL
jun 08 22:28:19 manjaro-pc systemd[1]: NetworkManager-dispatcher.service: Succeeded.
jun 08 22:28:19 manjaro-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 22:28:19 manjaro-pc kernel: audit: type=1131 audit(1560043699.685:57): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 08 22:40:44 manjaro-pc audit[497]: USYS_CONFIG pid=497 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=852 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 22:40:44 manjaro-pc NetworkManager[497]: <info>  [1560044444.0673] audit: op="statistics" arg="refresh-rate-ms" pid=852 uid=1000 result="success"
jun 08 22:40:44 manjaro-pc kernel: audit: type=1111 audit(1560044444.063:58): pid=497 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=852 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 22:40:45 manjaro-pc audit[497]: USYS_CONFIG pid=497 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=852 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 22:40:45 manjaro-pc NetworkManager[497]: <info>  [1560044445.2090] audit: op="radio-control" arg="wireless-enabled" pid=852 uid=1000 result="success"
jun 08 22:40:45 manjaro-pc kernel: audit: type=1111 audit(1560044445.206:59): pid=497 uid=0 auid=4294967295 ses=4294967295 msg='op=radio-control arg="wireless-enabled" pid=852 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 22:40:47 manjaro-pc audit[497]: USYS_CONFIG pid=497 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=852 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
jun 08 22:40:47 manjaro-pc NetworkManager[497]: <info>  [1560044447.5019] audit: op="statistics" arg="refresh-rate-ms" pid=852 uid=1000 result="success"
jun 08 22:40:47 manjaro-pc kernel: audit: type=1111 audit(1560044447.499:60): pid=497 uid=0 auid=4294967295 ses=4294967295 msg='op=statistics arg="refresh-rate-ms" pid=852 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[manjaro@manjaro-pc ~]$ journalctl -b -1 | grep wlan
[manjaro@manjaro-pc ~]$ journalctl -p 7 -xb | grep manager
-- Subject: User manager start-up is now complete
-- The user manager instance for user 969 has been started. All services queued
-- Startup of the manager took 673951 microseconds.
-- The user manager instance for user 1000 has been started. All services queued
-- Startup of the manager took 191248 microseconds.
jun 08 22:27:32 manjaro-pc plasmashell[852]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PopupDialog.qml:102:13: QML PropertyChanges: Cannot assign to non-existent property "tooltipText"
jun 08 22:30:06 manjaro-pc plasmashell[852]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:343: Unable to assign [undefined] to int
jun 08 22:30:06 manjaro-pc plasmashell[852]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:371: TypeError: Cannot read property 'length' of undefined
jun 08 22:30:07 manjaro-pc plasmashell[852]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:343: Unable to assign [undefined] to int
jun 08 22:30:07 manjaro-pc plasmashell[852]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:367: Unable to assign [undefined] to QString
We will need more information to assist you in resolving your issue.
How to provide your hardware specs:
When running the commands to detect your hardware, please ensure the following:
Do not have any USB WiFi adapter connected (except the adapter you are attempting to troubleshoot).
Do not have any USB to Ethernet adapter connected (except the adapter you are attempting to troubleshoot).
Do not have "phone tethering" operating while the hardware detection commands are run.
Reboot the computer with all other removable network devices disconnected first, then run the following commands:
Please post:
inxi -Fxxxz && ls /usr/share/xsessions/
hwinfo --netcard --bluetooth | grep -Ei "(hotplug|speed|model|status|cmd|file|detected|driver:)" | grep -v "Config S"
cat /etc/resolv.conf
WiFi troubleshooting tips:
  • Make sure you reboot both your router and computer before opening any help request.
  • Have you tried deleting, then recreating your connections profile in Network Manager.
  • Sometimes a hard power down is required. Disconnect/remove all power sources (including any battery) before restarting.
  • Ensure your system is fully up to date with:
    sudo pacman -Syyu
  • Check that your WiFi isn't blocked by rfkill:
    rfkill list all
  • If there are any "soft blocks" returned as "yes" then:
    sudo rfkill unblock all
  • If there are any "hard blocks" returned as "yes", then ensure that no function keys (airplane mode), or hidden switches are disabling your wireless.
  • Resetting your bios to default can be also be helpful if an adapter is undetected/hard blocked/not working properly.
  • Consider resetting your router back to the factory default settings as well.
  • If your installed driver came from the AUR (or gitub) and it stopped working after an update, you may simply need to rebuild your driver.
  • If your WiFi broke after an update (and rebuilding the driver didn't help), then try testing different kernels.
  • Use Manjaro Settings Manager to install and test both older and newer kernel versions whenever experiencing issues.
  • Ensure that your network adapter is enabled in the bios.
  • Resetting your bios to default can solve many problems.
  • Install a bios update (if there is one available).
  • Install and test the newest firmware available for your WiFi adapter.
  • Install the newest firmware available for your router.
  • If you are having issues with your WiFi adapter being detected on a laptop, try putting the laptop into suspend, then resume and check your WiFi status.
  • Test out Manjaro live boot disks with different DE's, or with other distros. If your WiFi works on any other live media, take note of the kernel and driver in use.
  • Ensure there is no MAC address or IP filtering enabled in the router and all new devices are allowed.
  • Ensure no IP addresses or hostnames are duplicated and conflicting on your network.
  • Temporarily disable any firewall software to be sure that is not interfering with getting a connection.
  • Temporarily disable password authentication in your router as a troubleshooting test (do not leave it disabled).
  • Try disabling IPv6 in your router and (or) in Network Manager, (if it is already disabled try enabling it).
  • Ensure that your network connection is not hidden in your router's settings.
  • Try assigning your computer a static IP address via MAC address association through your router configuration settings.
  • Test your WiFi connection with a different router if possible.
  • If this is a laptop have you tested it on alternate networks such as at a friends or neighbors, internet cafe etc.
  • Ensure any USB WiFi adapter is attached directly to the computer, (not through a USB hub).
  • Do not use any USB extension cabling during troubleshooting as this can interfere with proper adapter operation.
  • Unplug any wired network LAN cable, USB phone tethering, or any other USB network adapter, then reboot before running any diagnostic commands.
Please review my router setup and troubleshooting tips:
Many thanks for the answer and some more information:
  Host: manjaro-pc Kernel: 4.19.45-1-MANJARO x86_64 bits: 64
  compiler: gcc v: 8.3.0 Desktop: KDE Plasma 5.15.5 tk: Qt 5.12.3
  wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
  Type: Kvm System: LG product: A410-K.BE47P1 v: TBD serial: <filter>
  Mobo: Intel model: N/A serial: <filter> BIOS: INSYDE v: QL7L3G11
  date: 05/25/2011
  ID-1: BAT0 charge: 32.7 Wh condition: 33.7/48.8 Wh (69%)
  volts: 12.4/11.1 model: SIMPLO MWL32b type: Li-ion serial: <filter>
  status: Unknown
  Topology: Dual Core model: Intel Core i5 M 480 bits: 64 type: MT MCP
  arch: Nehalem rev: 5 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21289
  Speed: 2053 MHz min/max: 1199/2667 MHz boost: enabled
  Core speeds (MHz): 1: 2053 2: 1508 3: 1396 4: 1385
  Device-1: NVIDIA GT218M [GeForce 310M] vendor: LG driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:0a70
  Display: x11 server: X.Org 1.20.4 driver: nouveau unloaded: modesetting
  alternate: fbdev,nv,vesa compositor: kwin_x11 resolution: 1366x768~60Hz
  OpenGL: renderer: NVA8 v: 3.3 Mesa 19.0.4 direct render: Yes
  Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: LG
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:3b56
  Device-2: NVIDIA High Definition Audio vendor: LG driver: snd_hda_intel
  v: kernel bus ID: 01:00.1 chip ID: 10de:0be3
  Sound Server: ALSA v: k4.19.45-1-MANJARO
  Device-1: Ralink RT3090 Wireless 802.11n 1T/1R PCIe vendor: AzureWave
  driver: rt2800pci v: 2.3.0 port: 4000 bus ID: 02:00.0
  chip ID: 1814:3090
  IF: wlp2s0 state: down mac: <filter>
  vendor: LG driver: r8168 v: 8.047.01-NAPI port: 2000 bus ID: 03:00.0
  chip ID: 10ec:8168
  IF-ID-1: enp0s26u1u4 state: unknown speed: N/A duplex: N/A
  mac: <filter>
  Local Storage: total: 465.76 GiB used: 9.05 GiB (1.9%)
  ID-1: /dev/sda vendor: Toshiba model: MK5059GSXP size: 465.76 GiB
  speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1L scheme: MBR
  ID-1: / size: 89.81 GiB used: 9.05 GiB (10.1%) fs: ext4 dev: /dev/sda6
  ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda5
  System Temperatures: cpu: 57.0 C mobo: N/A gpu: nouveau temp: 55 C
  Processes: 171 Uptime: 9m Memory: 3.72 GiB used: 752.1 MiB (19.8%)
  Init: systemd v: 242 Compilers: gcc: 8.3.0 Shell: bash v: 5.0.7
  running in: konsole inxi: 3.0.34
plasma.desktop
 Model: "Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller"
  Driver: "r8168"
  Device File: enp3s0
  Link detected: no
    Driver Status: r8169 is not active
    Driver Activation Cmd: "modprobe r8169"
    Driver Status: r8168 is active
    Driver Activation Cmd: "modprobe r8168"
  Model: "Ralink RT3090 Wireless 802.11n 1T/1R PCIe"
  Driver: "rt2800pci"
  Device File: wlp2s0
  Link detected: no
    Driver Status: rt2800pci is active
    Driver Activation Cmd: "modprobe rt2800pci"
  Model: "Samsung Electronics GT-I9500 [Galaxy S4] / GT-I9250 [Galaxy Nexus] (network tethering)"
  Hotplug: USB
  Driver: "rndis_host"
  Device File: enp0s26u1u4
  Speed: 480 Mbps
  Link detected: yes
    Driver Status: rndis_host is active
    Driver Activation Cmd: "modprobe rndis_host"
# Generated by NetworkManager
nameserver 192.168.42.129
Problem not solved.
What did you test out? I gave you a pretty big list of potential fixes to try.
I tested it: WLAN is deactivated after every 2nd boot!? RT3090 Wireless driver rt2800pci v: 2.3.0 on lenovo ideapad s205
But it seems to be the firmware.
sudo dmesg | grep wlan
[   14.343475] rt2800pci 0000:02:00.0 wlp2s0: renamed from wlan0
[  519.384494] rt2800pci 0000:02:00.0 wlp2s0: renamed from wlan0
sudo ip link set wlp2s0 up
RTNETLINK answers: Operation not possible due to RF-kill.
lsmod | sort
rfkill list
lsmod | sort | grep rt2800
eeprom_93cx6           16384  1 rt2800pci
mac80211              925696  3 rt2x00pci,rt2x00lib,rt2800lib
rt2800lib             118784  2 rt2800mmio,rt2800pci
rt2800mmio             16384  1 rt2800pci
rt2800pci              16384  0
rt2x00lib              77824  5 rt2x00mmio,rt2x00pci,rt2800mmio,rt2800pci,rt2800lib
rt2x00mmio             16384  2 rt2800mmio,rt2800pci
rt2x00pci              16384  1 rt2800pci
rfkill list
1: phy0: Wireless LAN
        Soft blocked: no
        Hard blocked: yes
If I wanted a short list outputted from lsmod, I would have asked for that.
Either a hardware switch is blocking your wifi, or you have a manufacturers module blocking your Wifi. If you had output the lsmod I asked for I would know the answer.
Search for your hardware "wmi" modules and how to blacklist them. I don't have enough patience to wet nurse users who will not post requested outputs or provide information on which fixes the have tested. Especially when I went to the trouble of posting an entire check list for you.
Good luck getting your issue resolved, and just FYI empty bumps are against the forum rules.
I'm done here.
So far everything that has been quoted has been tested and I always study solutions to a problem, the return of lsmod is enormous and it would be interesting to post in a pastebin and I found the filtering of the output better. Other sites mention the same problem and with the same hardware. Anyway, thank you for your willingness to help.
Requested output: https://pastebin.com/UBuxmyGH
https://ubuntuforums.org/showthread.php?t=1592731
http://rt2x00.serialmonkey.com/phpBB-static/5/t-6255.html
https://wiki.archlinux.org/index.php/Wireless_network_configuration
https://bbs.archlinux.org/viewtopic.php?id=136607
Every one of these suggestions I gave could possibly resolve your issue. Did you test these fixes? Ive asked this before and got no response.
You have not confirmed if you performed the procedures I recommended above, you have also provided 0 background info.
Is this a new install? Nothing 0 background. Has this adapter worked in Linux before. Zero background, zero response when asked if you had performed the suggestions on my list.
In short having to pry information out of you, is just too trying for my patience. You are not being very helpful, and you get what you give (if you are starting to get my drift).
Did you test different kernels? This is one of the most likely fixes to your issue, but without background info I couldn't say how likely. Search the terms "hard power down". Change the pci slot on your motherboard your wifi is in.
I repeat, you provided no information when requested.
How many times do I have to ask this question before you provide an answer?
Do you seriously believe this? If so, you've got bigger issues than your wifi. Put on your big boy boots and do your own digging. I don't have the patience for users that provide no feedback to suggestions when requested. Remote troubleshooting cannot be performed this way.
Quit whining I dropped your help request like a hot potato for no reason on other threads, when you fully brought that on yourself by being uncooperative.
Done, and done again.
(edit) I now see you posted a solution and finally provided an answer (while I was writing this reply).
Your posted solution provides about as much clarity as the rest of your answers. Zero.
I already inserted the topic as resolved. And I thank you for your attention. I do not want to discuss something that off topic and generate discussions.
Your posted solution is 10 different links with possibly a half dozen recommendations (or more) on each thread. As all your other responses, you again leave everyone guessing as to what the answer is. Are you simply trolling the forum, because it seems you are being deliberately evasive to questions, and provide answers about as clear as mud (when you provide them at all).
What do you need to know? I tried to be objective. Report within the topic what still needs to know that I answer in the morning, it is dawn soon. I understand that may have lost some more information. Please be objective and avoid off topics.
But as far as I understand, you understanded the problem.
Problem solved by inserting the module that was causing problem in the blacklist:
blacklist rt2800pci
blacklist rt2800usb
blacklist rt2x00lib
blacklist rt2x00pci
blacklist rt2x00usb
There is an AUR package exactly to solve the problem with the Ralink 3090 driver chip, but this package was abandoned since of 2013 by Ivan Alexandrovich and since of 2011 by Markus Hebeling being extracted from his ppa and Ralink 3090 driver ppa and arachnid92 in AUR.
There is a report in the Arch forum that the AUR package solved the incompatibility problem.
https://forum.archlinux-br.org/viewtopic.php?id=3491
https://bugs.launchpad.net/ubuntu/+source/bluez/+bug/781556
https://wiki.archlinux.org/index.php/Wireless_network_configuration#rt3090
https://bbs.archlinux.org/viewtopic.php?id=161952
Thank you for providing a clarification on the solution to your issue for other users benefit who have a similar problem.
I will be following the topic until closing to clarify doubts.
