Canon MF6590 Drivers missing / Python2 not installing correctly
I try to install my Canon Mf590 Drivers on Manjaro KDE. But I couldn’t find any.
I check on the forum and try this option: [/quote]
When I try to install
python2 2.7.18
I got this error
bsdtar: Removing leading '/' from member names
/var/tmp/pamac-build-user/python2/PKGBUILD: line 40: patch: order not found
==> ERROR: A failure occurred in prepare().
When I try to install python2 with pyenv it freezes.
If anyone can help me with this problem or another alternative to install the printer driver it will be good.
You’re missing the base-devel meta package which is required for using the AUR (Arch User Repository).
Understandable, I need to install the package right? I will keep this update in a few hours.
After some wait, It succesfully installed the packege cnrdrvcups-lib. I was able to print and use all the functions of it. Thanks @Yochanan for your help and excuse my ignorence. I’m still a newbie in this world.
