I have a dual boot with Windows and I think I messed up my wifi. On Windows, it shows that my wifi device is disconnected so I tried a uninstall and reinstall the driver. But now the wifi device doesn’t even show up on both Windows and Manjaro. Could someone help me with this? Here is my inxi output:
Kernel: 5.10.181-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=1dc4645e-aa12-4f21-b6c7-be8204dfb3ec rw loglevel=3 quiet
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: GE65 Raider 9SF v: REV:1.0
Mobo: Micro-Star model: MS-16U1 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16U1IMS.103 date: 07/02/2019
ID-1: BAT1 charge: 8.9 Wh (25.6%) condition: 34.8/51.6 Wh (67.5%) volts: 10.9
min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A status: charging
System RAM: available: 31.2 GiB used: 3.83 GiB (12.3%)
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xF4
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: retbleed mitigation: Enhanced IBRS
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f10
class-ID: 0300
Device-3: Bison HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13:5 chip-ID: 5986:211c
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Sharp LQ156M1JW03 built: 2019 res: 1920x1080
hz: 240 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
API: ALSA v: k5.10.181-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
Device-1: Realtek vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:2600
class-ID: 0200
IF-ID-1: anbox0 state: down mac: <filter>
IF-ID-2: enp0s20f0u1 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: OPPO OnePlus 8T TMO driver: rndis_host v: kernel type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 22d9:276a
class-ID: 0a00 serial: <filter>
Device-2: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:6 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 953.87 GiB used: 141.1 GiB (14.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HALR-00000
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: EXA7301Q temp: 44.9 C
scheme: GPT
ID-1: / raw-size: 195.31 GiB size: 191.19 GiB (97.89%)
used: 141.01 GiB (73.8%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
label: N/A uuid: 1dc4645e-aa12-4f21-b6c7-be8204dfb3ec
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 86.9 MiB (29.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 6034-98E0
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 737.25 GiB fs: ntfs
label: Windows uuid: DE86527386524BE1
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 900 MiB fs: ntfs
label: WinRE tools uuid: 8A18372A18371523
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 20.01 GiB fs: ntfs
label: BIOS_RVY uuid: 68443A104439E20C
Device-1: 1-1:2 info: OPPO OnePlus 8T TMO type: bluetooth,CDC-data
driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 500mA chip-ID: 22d9:276a class-ID: 0a00
serial: <filter>
Device-2: 1-7:3 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Device-3: 1-9:4 info: SteelSeries ApS KLC type: HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:1122 class-ID: 0300
Device-4: 1-13:5 info: Bison HD Webcam type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:211c class-ID: 0e02
Device-5: 1-14:6 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 60.0 C pch: 60.0 C mobo: N/A
Processes: 284 Uptime: 25m wakeups: 398 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 alt: 11/8/9
clang: 15.0.7 Packages: 1841 pm: pacman pkgs: 1839 libs: 478 tools: pamac
pm: flatpak pkgs: 0 pm: snap pkgs: 2 Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.27
