Hi,
I’m currently using Linux Mint but I would like to try Manjaro (I’ve been using Debian based distros for more than 10 years, maybe it’s time to move on…)
I tried the USB live version (manjaro-kde-21.0.1-210410-linux510). I have a strange problem with the video driver. The screen on my laptop looks like this: look at those horizontal lines on my monitor (in fact they are horizontal, but I took the photo with my phone a little tilted)
Using Mint the video card works very well with both the video cards (nVidia and Intel), I can also play some 3d games on Steam without any problem.
I also tried another Arch based distro (Garuda) and I have the same problem (it’s not a problem with my graphic card, with Linux Mint it is all right).
Can you help me to solve the problem?
I would like to see at least the nVidia video card properly working (possibly both, nVidia and Intel) before installing Manjaro on my hard drive.
Thank you very much for your time
Francesco
Some more info
Running inxi with MINT I see:
~$ inxi -Fxxxza
System: Kernel: 5.4.0-72-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
parameters: BOOT_IMAGE=/vmlinuz-5.4.0-72-generic root=/dev/mapper/vgmint-root ro quiet splash
Desktop: Cinnamon 4.8.6 wm: muffin 4.8.1 dm: LightDM 1.30.0 Distro: Linux Mint 20.1 Ulyssa
base: Ubuntu 20.04 focal
Machine: Type: Laptop System: HUAWEI product: MACH-WX9 v: M19 serial: <filter>
Mobo: HUAWEI model: MACH-WX9-PCB v: M19 serial: <filter> UEFI: HUAWEI v: 1.28 date: 03/15/2019
Battery: ID-1: BAT0 charge: 55.8 Wh condition: 56.4/56.3 Wh (100%) volts: 8.6/7.6 model: DYNAPACK HB4593R1ECW
type: Li-ion serial: <filter> status: Unknown cycles: 23
CPU: Topology: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 8E (142) stepping: A (10) microcode: E0 L2 cache: 8192 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31999
Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 801 5: 800 6: 800
7: 800 8: 800
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 620 vendor: Huawei driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:5917
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Huawei driver: nvidia v: 460.56 bus ID: 01:00.0
chip ID: 10de:1d12
Display: x11 server: X.Org 1.20.9 driver: modesetting,nvidia unloaded: fbdev,nouveau,vesa
resolution: 3000x2000~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.2.6 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Huawei driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:9d71
Sound Server: ALSA v: k5.4.0-72-generic
Network: Device-1: Intel Wireless 8265 / 8275 vendor: Huawei driver: iwlwifi v: kernel port: 3000
bus ID: 3c:00.0 chip ID: 8086:24fd
IF: wlp60s0 state: up mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: virbr0-nic state: down mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 61.41 GiB (12.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HAJQ-00000 size: 476.94 GiB block size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: EXA7301Q scheme: GPT
Partition: ID-1: / raw size: 474.75 GiB size: 466.30 GiB (98.22%) used: 61.00 GiB (13.1%) fs: ext4
dev: /dev/dm-1
ID-2: /boot raw size: 732.0 MiB size: 704.5 MiB (96.24%) used: 403.4 MiB (57.3%) fs: ext4
dev: /dev/nvme0n1p2
ID-3: swap-1 size: 980.0 MiB used: 0 KiB (0.0%) fs: swap swappiness: 60 (default)
cache pressure: 100 (default) dev: /dev/dm-2
Sensors: System Temperatures: cpu: 50.5 C mobo: N/A
Info: Processes: 297 Uptime: 7m Memory: 7.53 GiB used: 1.91 GiB (25.4%) Init: systemd v: 245 runlevel: 5
Compilers: gcc: 9.3.0 alt: 9 Shell: bash v: 5.0.17 running in: gnome-terminal inxi: 3.0.38
Running inxi with Manjaro line USB key I see:
[manjaro@manjaro ~]$ inxi -Fxxxza
System: Kernel: 5.10.26-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDE_2101 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1
i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Battery: ID-1: BAT0 charge: 55.6 Wh (98.8%) condition: 56.3/56.3 Wh (100.0%) volts: 8.6 min: 7.6 model: DYNAPACK HB4593R1ECW
CPU: Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: A (10) microcode: E0 cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 32012
Speed: 900 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 900 2: 901 3: 900 4: 900 5: 901 6: 900 7: 900 8: 900
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 620 vendor: Huawei driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Huawei driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1d12
class-ID: 0302
Device-3: Cheng Uei Precision Industry (Foxlink) HD Camera type: USB driver: uvcvideo bus-ID: 1-7:6
chip-ID: 05c8:03c0 class-ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3000x2000 s-dpi: 96 s-size: 793x529mm (31.2x20.8") s-diag: 953mm (37.5")
Monitor-1: eDP1 res: 3000x2000 hz: 60 dpi: 263 size: 290x200mm (11.4x7.9") diag: 352mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.1 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Huawei driver: snd_hda_intel v: kernel alternate: snd_soc_skl
bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.26-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
Network: Device-1: Intel Wireless 8265 / 8275 vendor: Huawei driver: iwlwifi v: kernel port: 3000 bus-ID: 3c:00.0
chip-ID: 8086:24fd class-ID: 0280
IF: wlp60s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-5:5 chip-ID: 8087:0a2b
class-ID: e001
Drives: Local Storage: total: 513.42 GiB used: 128 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: EXA7301Q temp: 41.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Edge size: 7.23 GiB block-size: physical: 512 B
logical: 512 B serial: <filter> rev: 1.27 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk model: Cruzer Glide size: 29.25 GiB block-size:
physical: 512 B logical: 512 B serial: <filter> rev: 1.00 scheme: MBR
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 43.5 C mobo: N/A gpu: nouveau temp: 44.0 C
Info: Processes: 251 Uptime: 4m wakeups: 1 Memory: 7.53 GiB used: 1.74 GiB (23.1%) Init: systemd v: 247 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1217 lib: 326 flatpak: 0 Shell: Bash v: 5.1.0 running-in: konsole
inxi: 3.3.03
