Problem with update multilib
#1
Hello,
I’ve a problem with these packages:
lib32-libelf lib32-libva-mesa-driver lib32-libxshmfence lib32-libxxf86vm lib32-llvm-libs lib32-lm_sensors lib32-mesa lib32-mesa-vdpau lib32-vulkan-intel lib32-vulkan-radeon
I receive this answer:
file conflict:
lib32-mesa : /usr/lib32/libOSMesa.so is already present in the file system
lib32-mesa : /usr/lib32/libOSMesa.so.8 is already present in the file system
lib32-mesa : /usr/lib32/libOSMesa.so.8.0.0.0 is already present in the file system
lib32-mesa : /usr/lib32/libgbm.so is already present in the file system
lib32-mesa : /usr/lib32/libgbm.so.1 is already present in the file system
lib32-mesa : /usr/lib32/libgbm.so.1.0.0.0 is already present in the file system
lib32-mesa : /usr/lib32/libglapi.so is already present in the file system
lib32-mesa : /usr/lib32/libglapi.so.0 is already present in the file system
lib32-mesa : /usr/lib32/libglapi.so.0.0.0.0 is already present in the file system
lib32-mesa : /usr/lib32/libxatracker.so is already present in the file system
lib32-mesa : /usr/lib32/libxatracker.so.2 is already present in the file system
lib32-mesa : /usr/lib32/libxatracker.so.2.4.0 is already present in the file system
lib32-mesa : /usr/lib32/pkgconfig/d3d.pc is already present in the file system
lib32-mesa : /usr/lib32/pkgconfig/dri.pc is already present in the file system
lib32-mesa : /usr/lib32/pkgconfig/egl.pc is already present in the file system
lib32-mesa : /usr/lib32/pkgconfig/gbm.pc is already present in the file system
lib32-mesa : /usr/lib32/pkgconfig/gl.pc is already present in the file system
lib32-mesa : /usr/lib32/pkgconfig/glesv1_cm.pc is already present in the file system
lib32-mesa : /usr/lib32/pkgconfig/glesv2.pc is already present in the file system
lib32-mesa : /usr/lib32/pkgconfig/osmesa.pc is already present in the file system
lib32-mesa : /usr/lib32/pkgconfig/xatracker.pc is already present in the file system
lib32-mesa : /usr/share/licenses/lib32-mesa/LICENSE is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_nouveau.so is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_nouveau.so.1 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_nouveau.so.1.0 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_nouveau.so.1.0.0.0 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_r300.so is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_r300.so.1 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_r300.so.1.0 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_r300.so.1.0.0.0 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_r600.so is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_r600.so.1 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_r600.so.1.0 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_r600.so.1.0.0.0 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_radeonsi.so is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_radeonsi.so.1 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_radeonsi.so.1.0 is already present in the file system
lib32-mesa-vdpau : /usr/lib32/vdpau/libvdpau_radeonsi.so.1.0.0.0 is already present in the file system
lib32-mesa-vdpau : /usr/share/licenses/lib32-mesa-vdpau/LICENSE is already present in the file system
lib32-vulkan-intel : /usr/lib32/libvulkan_intel.so is already present in the file system
lib32-vulkan-intel: /usr/share/licenses/lib32-vulkan-intel/LICENSE is already present in the file system
You can read all the discussion on Manjaro-fr here : Erreurs mises à jour lib32
Have you an idea to resolve my problem?
Thanks all.
#2
This should help
#3
I solved the problem.
I deleted all the files from the lib32 concerned.
Since then, pamac has continued to inform me of these updates.
I searched for a long time, then restarted the computer.
At that time, the lib32 updates have disappeared.
Thanks to all of you.
