Hello,
since an update this June I’ve had the following problem: First booting didn’t work because the kernel image file could not be found. First I suspected a corrupted filesystem, but fsck didn’t find anything. After some time I found out that I can start with the kernel 5.15.60-1(current LTS) when choosing in the grub menu. So I can still get into the system. But when trying to install new kernels with the Manjaro settings manager (Einstellungsmanager in German) or with update-grub
in the shell it fails with /usr/bin/grub-probe: error: unknown filesystem.
/home/jens LANG=C 1 ✘ root@gram
/home/jens update-grub ✔ root@gram
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-rt-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-rt-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-rt-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.14-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.14-x86_64.img
Found initrd fallback image: /boot/initramfs-5.14-x86_64-fallback.img
For the Manjaro main partition I have chosen F2FS. The output of fdisk -l
is:
/home/jens fdisk -l 1 ✘ root@gram
Disk /dev/nvme0n1: 953,87 GiB, 1024209543168 bytes, 2000409264 sectors
Disk model: HFS001TD9TNG-L2A0A
Disklabel type: gpt
Disk identifier: DB836526-8B6F-8248-A795-FB43C8D7011C
Device Start End Sectors Size Type
/dev/nvme0n1p1 4096 618495 614400 300M EFI System
/dev/nvme0n1p2 618496 1964959702 1964341207 936,7G Linux filesystem
/dev/nvme0n1p3 1964959703 2000397734 35438032 16,9G Linux filesystem
Disk /dev/mapper/luks-dccc69d8-69ae-4728-8806-1a950897c316: 936,67 GiB, 1005740600832 bytes, 1964337111 sectors
Disk /dev/mapper/luks-b1fc9740-a686-47a4-b370-b07d695b9794: 16,9 GiB, 18142175232 bytes, 35433936 sectors
Disk /dev/loop1: 55,56 MiB, 58261504 bytes, 113792 sectors
[… until /dev/loop14]
I have been using this laptop (LG gram) since last summer with Manjaro, and never had a problem with kernel updates or booting before.
So how can I repair it?
