Ok, thank you for your time and patience.
For anyone reading it later here’re the results of trying the lastly mentioned command in my terminal:
[sudo] password for wejj:
Oct 19 15:42:02 wejj-aspirea31523 systemd[1]: Shutting down.
Oct 19 15:42:02 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-TERMINATING
Oct 19 15:42:02 wejj-aspirea31523 wpa_supplicant[878]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Oct 19 15:42:02 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Oct 19 15:42:02 wejj-aspirea31523 NetworkManager[555]: <warn> [1666186922.4167] dispatcher: (8) failed (after 0.001 sec): Refusing activation, D-Bus is shutting down.
Oct 19 15:42:02 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=ce:25:ea:26:2a:ae reason=3 locally_generated=1
Oct 19 15:42:02 wejj-aspirea31523 wpa_supplicant[878]: p2p-dev-wlp2s0: CTRL-EVENT-TERMINATING
Oct 19 15:42:02 wejj-aspirea31523 wpa_supplicant[878]: nl80211: deinit ifname=p2p-dev-wlp2s0 disabled_11b_rates=0
Oct 19 15:42:02 wejj-aspirea31523 wpa_supplicant[878]: p2p-dev-wlp2s0: CTRL-EVENT-DSCP-POLICY clear_all
Oct 19 15:42:02 wejj-aspirea31523 systemd[939]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[wejj] ruser=[<unknown>] rhost=[<unknown>]
Oct 19 15:42:01 wejj-aspirea31523 systemd[938]: xdg-document-portal.service: Failed with result 'exit-code'.
Oct 19 15:42:01 wejj-aspirea31523 systemd[938]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
Oct 19 15:42:01 wejj-aspirea31523 kernel: audit: type=1131 audit(1666186921.793:206): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 15:42:01 wejj-aspirea31523 systemd[938]: obex.service: Failed with result 'exit-code'.
Oct 19 15:42:01 wejj-aspirea31523 systemd[938]: obex.service: Main process exited, code=exited, status=1/FAILURE
Oct 19 15:42:01 wejj-aspirea31523 systemd[938]: xdg-permission-store.service: Failed with result 'exit-code'.
Oct 19 15:42:01 wejj-aspirea31523 systemd[938]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
Oct 19 15:42:01 wejj-aspirea31523 kernel: audit: type=1131 audit(1666186921.763:205): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Oct 19 15:42:01 wejj-aspirea31523 systemd[1]: udisks2.service: Failed with result 'core-dump'.
Oct 19 15:42:01 wejj-aspirea31523 systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
Oct 19 15:42:01 wejj-aspirea31523 pulseaudio[1046]: Error opening PCM device front:1: No such file or directory
Oct 19 15:42:01 wejj-aspirea31523 xfconfd[1005]: Name org.xfce.Xfconf lost on the message dbus, exiting.
Oct 19 15:42:01 wejj-aspirea31523 kernel: audit: type=1131 audit(1666186921.740:204): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 15:42:01 wejj-aspirea31523 kernel: audit: type=1131 audit(1666186921.740:203): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 15:42:01 wejj-aspirea31523 kernel: audit: type=1131 audit(1666186921.737:202): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 15:42:01 wejj-aspirea31523 systemd-coredump[1670]: Failed to connect to coredump service: Connection refused
Oct 19 15:42:01 wejj-aspirea31523 kernel: audit: type=1131 audit(1666186921.733:201): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 15:42:01 wejj-aspirea31523 kernel: audit: type=1131 audit(1666186921.733:200): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 15:42:01 wejj-aspirea31523 kernel: audit: type=1131 audit(1666186921.730:199): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 15:42:01 wejj-aspirea31523 kernel: audit: type=1701 audit(1666186921.730:198): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=unconfined pid=1162 comm="udisksd" exe="/usr/lib/udisks2/udisksd" sig=6 res=1
Oct 19 15:42:01 wejj-aspirea31523 systemd[938]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
Oct 19 15:42:01 wejj-aspirea31523 systemd[938]: xdg-desktop-portal-gtk.service: Main process exited, code=exited, status=1/FAILURE
Oct 19 15:42:01 wejj-aspirea31523 udisksd[1162]: udisks daemon version 2.9.4 exiting
Oct 19 15:42:01 wejj-aspirea31523 systemd[938]: xdg-desktop-portal-gnome.service: Failed with result 'exit-code'.
Oct 19 15:42:01 wejj-aspirea31523 systemd[938]: xdg-desktop-portal-gnome.service: Main process exited, code=exited, status=1/FAILURE
Oct 19 15:42:01 wejj-aspirea31523 kernel: audit: type=1113 audit(1666186921.713:197): pid=933 uid=0 auid=1000 ses=1 subj=unconfined msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=wejj-aspirea31523 addr=? terminal=/dev/tty7 res=success'
Oct 19 15:42:01 wejj-aspirea31523 dbus-daemon[539]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.26" (uid=1000 pid=1046 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error.UnknownMethod" requested_reply="0" destination=":1.27" (uid=0 pid=1066 comm="/usr/lib/bluetooth/bluetoothd")
Oct 19 15:42:01 wejj-aspirea31523 polkitd[540]: Unregistered Authentication Agent for unix-session:1 (system bus name :1.34, object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8) (disconnected from bus)
Oct 19 15:42:01 wejj-aspirea31523 systemd-logind[542]: System is powering down.
Oct 19 15:41:37 wejj-aspirea31523 kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Oct 19 15:41:37 wejj-aspirea31523 kernel: Not tainted 5.15.74-3-MANJARO #1
Oct 19 15:41:37 wejj-aspirea31523 kernel: INFO: task systemd-udevd:323 blocked for more than 122 seconds.
Oct 19 15:41:37 wejj-aspirea31523 kernel: INFO: task systemd-udevd:320 blocked for more than 122 seconds.
Oct 19 15:41:37 wejj-aspirea31523 kernel: INFO: task kworker/1:1:146 blocked for more than 122 seconds.
Oct 19 15:41:37 wejj-aspirea31523 kernel: INFO: task kworker/0:1:21 blocked for more than 122 seconds.
Oct 19 15:41:37 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-79 noise=9999 txrate=57800
Oct 19 15:41:26 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-67 noise=9999 txrate=57800
Oct 19 15:41:15 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-74 noise=9999 txrate=57800
Oct 19 15:40:43 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-69 noise=9999 txrate=57800
Oct 19 15:40:37 wejj-aspirea31523 systemd-udevd[292]: 1-4:1.0: Worker [320] processing SEQNUM=2586 killed
Oct 19 15:40:37 wejj-aspirea31523 systemd-udevd[292]: 1-1:1.0: Worker [323] processing SEQNUM=2583 killed
Oct 19 15:40:37 wejj-aspirea31523 systemd-udevd[292]: 1-4:1.1: Worker [318] processing SEQNUM=2587 killed
Oct 19 15:40:30 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-80 noise=9999 txrate=57800
Oct 19 15:39:33 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-69 noise=9999 txrate=28900
Oct 19 15:39:02 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186742.752:196): prog-id=0 op=UNLOAD
Oct 19 15:39:02 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186742.752:195): prog-id=0 op=UNLOAD
Oct 19 15:39:02 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186742.752:194): prog-id=0 op=UNLOAD
Oct 19 15:39:02 wejj-aspirea31523 kernel: audit: type=1131 audit(1666186742.722:193): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 15:39:02 wejj-aspirea31523 kernel: kauditd_printk_skb: 20 callbacks suppressed
Oct 19 15:38:41 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-72 noise=9999 txrate=43300
Oct 19 15:38:14 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186694.108:172): prog-id=27 op=LOAD
Oct 19 15:38:14 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186694.108:171): prog-id=26 op=LOAD
Oct 19 15:38:14 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186694.108:170): prog-id=0 op=UNLOAD
Oct 19 15:38:14 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186694.108:169): prog-id=25 op=LOAD
Oct 19 15:38:14 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186694.105:168): prog-id=0 op=UNLOAD
Oct 19 15:38:14 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186694.105:167): prog-id=0 op=UNLOAD
Oct 19 15:38:14 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186694.105:166): prog-id=24 op=LOAD
Oct 19 15:38:14 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186694.105:165): prog-id=23 op=LOAD
Oct 19 15:38:14 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186694.105:164): prog-id=0 op=UNLOAD
Oct 19 15:38:14 wejj-aspirea31523 kernel: audit: type=1334 audit(1666186694.105:163): prog-id=22 op=LOAD
Oct 19 13:38:15 wejj-aspirea31523 polkitd[540]: Operator of unix-session:1 successfully authenticated as unix-user:wejj to gain TEMPORARY authorization for action org.freedesktop.timedate1.set-time for system-bus-name::1.52 [manjaro-settings-manager] (owned by unix-user:wejj)
Oct 19 13:38:15 wejj-aspirea31523 kernel: audit: type=1101 audit(1666179495.009:162): pid=1496 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="wejj" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Oct 19 13:38:15 wejj-aspirea31523 kernel: audit: type=1100 audit(1666179495.009:161): pid=1496 uid=1000 auid=1000 ses=1 subj=unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="wejj" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Oct 19 13:38:12 wejj-aspirea31523 kernel: audit: type=1131 audit(1666179492.685:160): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 13:38:09 wejj-aspirea31523 kernel: audit: type=1334 audit(1666179489.835:159): prog-id=0 op=UNLOAD
Oct 19 13:38:09 wejj-aspirea31523 kernel: audit: type=1334 audit(1666179489.835:158): prog-id=0 op=UNLOAD
Oct 19 13:38:09 wejj-aspirea31523 kernel: audit: type=1334 audit(1666179489.835:157): prog-id=0 op=UNLOAD
Oct 19 13:38:09 wejj-aspirea31523 kernel: audit: type=1131 audit(1666179489.682:156): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 13:37:48 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-79 noise=9999 txrate=43300
Oct 19 13:37:46 wejj-aspirea31523 kernel: audit: type=1131 audit(1666179466.189:155): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 13:37:46 wejj-aspirea31523 kernel: kauditd_printk_skb: 24 callbacks suppressed
Oct 19 13:37:41 wejj-aspirea31523 pkexec[1369]: wejj: Executing command [USER=root] [TTY=unknown] [CWD=/home/wejj] [COMMAND=/usr/bin/xfpm-power-backlight-helper --set-brightness-switch 0]
Oct 19 13:37:41 wejj-aspirea31523 pipewire[1366]: mod.rt: found session bus but no portal
Oct 19 13:37:41 wejj-aspirea31523 pipewire[1366]: mod.rt: Can't find xdg-portal: (null)
Oct 19 13:37:41 wejj-aspirea31523 pkexec[1361]: wejj: Executing command [USER=root] [TTY=unknown] [CWD=/home/wejj] [COMMAND=/usr/bin/xfpm-power-backlight-helper --set-brightness-switch 0]
Oct 19 13:37:40 wejj-aspirea31523 xdg-desktop-por[1207]: Theme parser error: gtk.css:6196:3-37: No property named "-GraniteWidgetsPopOver-shadow-size"
Oct 19 13:37:40 wejj-aspirea31523 xdg-desktop-por[1207]: Theme parser error: gtk.css:6195:3-38: No property named "-GraniteWidgetsPopOver-border-width"
Oct 19 13:37:40 wejj-aspirea31523 xdg-desktop-por[1207]: Theme parser error: gtk.css:6194:3-39: No property named "-GraniteWidgetsPopOver-border-radius"
Oct 19 13:37:40 wejj-aspirea31523 xdg-desktop-por[1207]: Theme parser error: gtk.css:6193:3-38: No property named "-GraniteWidgetsPopOver-arrow-height"
Oct 19 13:37:40 wejj-aspirea31523 xdg-desktop-por[1207]: Theme parser error: gtk.css:6192:3-37: No property named "-GraniteWidgetsPopOver-arrow-width"
Oct 19 13:37:40 wejj-aspirea31523 xdg-desktop-por[1207]: Theme parser error: gtk.css:6159:3-29: No property named "-GtkTreeView-expander-size"
Oct 19 13:37:40 wejj-aspirea31523 xdg-desktop-por[1207]: Theme parser error: gtk.css:6101:3-34: No property named "-GtkTreeView-vertical-separator"
Oct 19 13:37:40 wejj-aspirea31523 xdg-desktop-por[1207]: Theme parser error: gtk.css:6100:3-36: No property named "-GtkTreeView-horizontal-separator"
Oct 19 13:37:40 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-62 noise=9999 txrate=1000
Oct 19 13:37:40 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to ce:25:ea:26:2a:ae completed [id=0 id_str=]
Oct 19 13:37:40 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: WPA: Key negotiation completed with ce:25:ea:26:2a:ae [PTK=CCMP GTK=CCMP]
Oct 19 13:37:40 wejj-aspirea31523 polkitd[540]: Registered Authentication Agent for unix-session:1 (system bus name :1.34 [/usr/lib/polkit-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale en_US.utf8)
Oct 19 13:37:40 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Oct 19 13:37:40 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: Associated with ce:25:ea:26:2a:ae
Oct 19 13:37:40 wejj-aspirea31523 udisksd[1162]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Oct 19 13:37:40 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: Trying to associate with ce:25:ea:26:2a:ae (SSID='Galaxy S20 FE 5G92A3' freq=2437 MHz)
Oct 19 13:37:40 wejj-aspirea31523 udisksd[1162]: udisks daemon version 2.9.4 starting
Oct 19 13:37:40 wejj-aspirea31523 tumblerd[1114]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.6.so.0: cannot open shared object file: No such file or directory
Oct 19 13:37:40 wejj-aspirea31523 wpa_supplicant[878]: wlp2s0: SME: Trying to authenticate with ce:25:ea:26:2a:ae (SSID='Galaxy S20 FE 5G92A3' freq=2437 MHz)
Oct 19 13:37:39 wejj-aspirea31523 pulseaudio[1046]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 19 13:37:39 wejj-aspirea31523 systemd[1066]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 19 13:37:38 wejj-aspirea31523 lightdm[933]: gkr-pam: couldn't unlock the login keyring.
Oct 19 13:37:38 wejj-aspirea31523 systemd-xdg-autostart-generator[944]: /home/wejj/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
Oct 19 13:37:38 wejj-aspirea31523 systemd-xdg-autostart-generator[944]: /home/wejj/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
Oct 19 13:37:38 wejj-aspirea31523 systemd-xdg-autostart-generator[944]: /home/wejj/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
Oct 19 13:37:38 wejj-aspirea31523 systemd-xdg-autostart-generator[944]: /home/wejj/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
Oct 19 13:37:38 wejj-aspirea31523 systemd-xdg-autostart-generator[944]: /home/wejj/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
Oct 19 13:37:38 wejj-aspirea31523 systemd-xdg-autostart-generator[944]: /home/wejj/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
Oct 19 13:37:38 wejj-aspirea31523 systemd-xdg-autostart-generator[944]: Configuration file /home/wejj/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 19 13:37:38 wejj-aspirea31523 systemd-xdg-autostart-generator[944]: /home/wejj/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
Oct 19 13:37:38 wejj-aspirea31523 systemd-xdg-autostart-generator[944]: Configuration file /home/wejj/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Oct 19 13:37:38 wejj-aspirea31523 kernel: audit: type=1006 audit(1666179458.119:136): pid=938 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Oct 19 13:37:38 wejj-aspirea31523 kernel: audit: type=1103 audit(1666179458.119:135): pid=938 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=? acct="wejj" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Oct 19 13:37:38 wejj-aspirea31523 kernel: audit: type=1101 audit(1666179458.119:134): pid=938 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="wejj" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 13:37:38 wejj-aspirea31523 systemd[938]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[wejj] ruser=[<unknown>] rhost=[<unknown>]
Oct 19 13:37:38 wejj-aspirea31523 kernel: audit: type=1130 audit(1666179458.109:133): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 19 13:37:38 wejj-aspirea31523 kernel: audit: type=1327 audit(1666179458.082:132): proctitle=6C69676874646D002D2D73657373696F6E2D6368696C64003133003136
Oct 19 13:37:38 wejj-aspirea31523 kernel: audit: type=1300 audit(1666179458.082:132): arch=c000003e syscall=1 success=yes exit=4 a0=9 a1=7ffe1bb93530 a2=4 a3=7ffe1bb93244 items=0 ppid=588 pid=933 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="lightdm" exe="/usr/bin/lightdm" subj=unconfined key=(null)
Oct 19 13:37:38 wejj-aspirea31523 kernel: audit: type=1006 audit(1666179458.082:132): pid=933 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
Oct 19 13:37:38 wejj-aspirea31523 kernel: audit: type=1103 audit(1666179458.082:131): pid=933 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="wejj" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Oct 19 13:37:38 wejj-aspirea31523 kernel: audit: type=1101 audit(1666179458.069:130): pid=933 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="wejj" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Oct 19 13:37:38 wejj-aspirea31523 kernel: audit: type=1100 audit(1666179458.065:129): pid=933 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="wejj" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:0 res=success'
Oct 19 13:37:38 wejj-aspirea31523 kernel: kauditd_printk_skb: 264 callbacks suppressed
Oct 19 13:37:38 wejj-aspirea31523 lightdm[933]: gkr-pam: no password is available for user
Oct 19 13:37:36 wejj-aspirea31523 wpa_supplicant[878]: Successfully initialized wpa_supplicant
Oct 19 13:37:36 wejj-aspirea31523 kernel: amdgpu 0000:05:00.0: amdgpu: PSP runtime database doesn't exist
Oct 19 13:37:36 wejj-aspirea31523 kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
Oct 19 13:37:35 wejj-aspirea31523 kernel: random: 6 urandom warning(s) missed due to ratelimiting
Oct 19 13:37:35 wejj-aspirea31523 kernel: random: crng init done
Oct 19 13:37:35 wejj-aspirea31523 polkitd[540]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Oct 19 13:37:35 wejj-aspirea31523 polkitd[540]: Finished loading, compiling and executing 7 rules
Oct 19 13:37:35 wejj-aspirea31523 polkitd[540]: Loading rules from directory /usr/share/polkit-1/rules.d
Oct 19 13:37:35 wejj-aspirea31523 polkitd[540]: Loading rules from directory /etc/polkit-1/rules.d
Oct 19 13:37:35 wejj-aspirea31523 systemd[1]: System is tainted: local-hwclock
Oct 19 13:37:35 wejj-aspirea31523 kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Oct 19 13:37:35 wejj-aspirea31523 kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Oct 19 13:37:35 wejj-aspirea31523 kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read)
Oct 19 13:37:35 wejj-aspirea31523 kernel: ccp 0000:05:00.2: psp: unable to access the device: you might be running a broken BIOS.
Oct 19 13:37:35 wejj-aspirea31523 kernel: ccp 0000:05:00.2: ccp enabled
Oct 19 13:37:34 wejj-aspirea31523 systemd-random-seed[283]: Kernel entropy pool is not initialized yet, waiting until it is.
Oct 19 13:37:35 wejj-aspirea31523 kernel: audit: type=1400 audit(1666179454.592:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=299 comm="apparmor_parser"
Oct 19 13:37:35 wejj-aspirea31523 kernel: audit: type=1325 audit(1666179454.592:9): table=filter family=10 entries=0 op=xt_register pid=293 subj=unconfined comm="ip6tables"
Oct 19 13:37:35 wejj-aspirea31523 kernel: audit: type=1400 audit(1666179454.589:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=280 comm="apparmor_parser"
Oct 19 13:37:35 wejj-aspirea31523 kernel: audit: type=1400 audit(1666179454.582:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd" pid=282 comm="apparmor_parser"
Oct 19 13:37:35 wejj-aspirea31523 kernel: audit: type=1400 audit(1666179454.549:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-dcerpcd" pid=281 comm="apparmor_parser"
Oct 19 13:37:35 wejj-aspirea31523 kernel: audit: type=1400 audit(1666179454.542:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=277 comm="apparmor_parser"
Oct 19 13:37:35 wejj-aspirea31523 kernel: audit: type=1400 audit(1666179454.542:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=278 comm="apparmor_parser"
Oct 19 13:37:35 wejj-aspirea31523 kernel: audit: type=1400 audit(1666179454.529:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=278 comm="apparmor_parser"
Oct 19 13:37:35 wejj-aspirea31523 kernel: audit: type=1400 audit(1666179454.525:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=275 comm="apparmor_parser"
Oct 19 13:37:35 wejj-aspirea31523 kernel: random: lvm: uninitialized urandom read (4 bytes read)
Oct 19 13:37:34 wejj-aspirea31523 kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Oct 19 13:37:34 wejj-aspirea31523 kernel: Key type fscrypt-provisioning registered
Oct 19 13:37:34 wejj-aspirea31523 kernel: Key type .fscrypt registered
Oct 19 13:37:34 wejj-aspirea31523 kernel: Key type ._fscrypt registered
Oct 19 13:37:34 wejj-aspirea31523 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: a726d2fcedec7de7f1bb21d56ff6b06afad1c930'
Oct 19 13:37:34 wejj-aspirea31523 kernel: Loading compiled-in X.509 certificates
Oct 19 13:37:34 wejj-aspirea31523 kernel: Asymmetric key parser 'x509' registered
Oct 19 13:37:34 wejj-aspirea31523 kernel: Key type asymmetric registered
Oct 19 13:37:34 wejj-aspirea31523 kernel: Key type blacklist registered
Oct 19 13:37:34 wejj-aspirea31523 kernel: Initialise system trusted keyrings
Oct 19 13:37:34 wejj-aspirea31523 kernel: pci 0000:00:00.2: PCI INT A: not connected
Oct 19 13:37:34 wejj-aspirea31523 kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Oct 19 13:37:34 wejj-aspirea31523 kernel: VFS: Disk quotas dquot_6.6.0
Oct 19 13:37:34 wejj-aspirea31523 kernel: SCSI subsystem initialized
Oct 19 13:37:34 wejj-aspirea31523 kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Oct 19 13:37:34 wejj-aspirea31523 kernel: audit: type=2000 audit(1666186651.159:1): state=initialized audit_enabled=0 res=1
Oct 19 13:37:34 wejj-aspirea31523 kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
Oct 19 13:37:34 wejj-aspirea31523 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=95abebb2-4fb9-42e4-8168-babc30a79c05 rw quiet apparmor=1 security=apparmor udev.log_priority=3
Oct 19 13:37:34 wejj-aspirea31523 kernel: Linux version 5.15.74-3-MANJARO (builduser@fv-az457-508) (gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0) #1 SMP PREEMPT Sat Oct 15 13:39:11 UTC 2022
[wejj@wejj-aspirea31523 ~]$
does it happen also with different kernels? try the 5.19 - but not the rt one
Ok, sorry for the fuss. I just installed the system again and everything seems to be working as intended.
I understand perfectly! I’m glad it works now!
