hello guys, i using dual graphics card with driver(video hybrid amd nvidia prime) but my nvidia is not working, i can set nvidia in nvidia x server setting but when i check on setting just have amdgpu is work
link screenshot
https://drive.google.com/file/d/1CEz-97zbgJ9xZEFzcNPpdAOcO3LUedrT/view?usp=sharing
https://drive.google.com/file/d/1P73ChOjkIwVolV6RK_WaYalfjdXv5zlC/view?usp=sharing
The NVIDIA driver is installed correctly,the first screenshot that program only shows the first GPU it sees.
Normally programs are able to automatically detect the NVIDIA card and use it,but in case is not working or if you want to force it you can use prime-run command before the name of the program.
For example
Try running the command
glxinfo | grep vendor
It should output something with AMD,now if you type
prime-run glxinfo | grep vendor
It should output something with NVIDIA,that means the NVIDIA card is working,with prime-run you force glxinfo to run with the NVIDIA card.
but why i don’t have “run application with graphics card”, and when i check nvidia with nvtop, gpu memory is always only 4 mb, i tried running some apps that use graphics, but it still doesn’t change
You can also use the Main Menu app that is included with Manjaro and search for the application and type prime-run at the start of the command,so you can start the app with the NVIDIA card straight at the GNOME menu.
If you want the “Launch with dedicated GPU” option,according to this, its the package switcheroo-control from the AUR that enables that functionality and Manjaro doesn’t have that preinstalled.
If you really want it,then try installing that package with
pamac build switcheroo-control-git
then reboot the system and check if you have the “Launch with dedicated graphic card”.
