Hello.
When I share my screen with discord
or zoom
I got system freeze. When I turn off sharing everything goes fine.
My system:
Kernel: 5.10.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=42aed776-442a-4993-ae9a-a3ed13777e0f ro
resume=UUID=1d1f179f-52f5-4554-ab28-838441dae9c9 quiet apparmor=1
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: UEFI: American Megatrends v: 3.70 date: 06/09/2020
Info: 8-Core model: AMD Ryzen 7 PRO 3700 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021 cache:
L2: 4 MiB
bogomips: 115245
Speed: 2677 MHz min/max: 2200/5224 MHz boost: enabled Core speeds (MHz):
1: 2677 2: 2604 3: 1951 4: 1929 5: 2198 6: 2199 7: 2206 8: 2196 9: 1942
10: 1948 11: 2203 12: 2205 13: 2204 14: 2206 15: 2670 16: 2374
conditional, RSB filling
Device-1: NVIDIA GK208B [GeForce GT 710] vendor: Gigabyte driver: nvidia
v: 460.56 alternate: nouveau,nvidia_drm bus-ID: 26:00.0 chip-ID: 10de:128b
class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 4480x1440 s-dpi: 94 s-size: 1210x389mm (47.6x15.3")
s-diag: 1271mm (50")
Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
Monitor-2: HDMI-0 res: 2560x1440 dpi: 109 size: 597x336mm (23.5x13.2")
diag: 685mm (27")
OpenGL: renderer: GeForce GT 710/PCIe/SSE2 v: 4.6.0 NVIDIA 460.56
direct render: Yes
Device-1: NVIDIA GK208 HDMI/DP Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 26:00.1 chip-ID: 10de:0e0f class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 28:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Plantronics Plantronics .Audio 478 USB type: USB
driver: plantronics,snd-usb-audio,usbhid bus-ID: 1-5:4 chip-ID: 047f:c011
class-ID: 0300
Sound Server-1: ALSA v: k5.10.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.22 running: no
Device-1: Realtek RTL8812AE 802.11ac PCIe Wireless Network Adapter
driver: rtl8821ae v: kernel port: e000 bus-ID: 21:00.0 chip-ID: 10ec:8812
class-ID: 0280
IF: wlo1 state: down mac:
vendor: Micro-Star MSI driver: r8168 v: 8.048.03-NAPI modules: r8169
port: d000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 100 Mbps duplex: full mac:
IF-ID-1: br-4ef831da16ae state: down mac:
IF-ID-2: docker0 state: down mac:
IF-ID-3: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 2.05 TiB used: 526.26 GiB (25.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX920 256GB
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: rev: SVN139B temp: 25.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
rotation: 7200 rpm serial: rev: 0001 scheme: GPT
