Problem with notifications widget after the update from 2019-12-29
Hi everyone,
I got this problem after the update from 2019-12-29... I hoped that it is going to get fixed after the latest update (2020-01-16), but it did not... Do you know how can I fix this?
I think that the problem occured because of removing the pyqt5 and pyqt5-common packages and/or installing python-pyqtwebengine .
Thanks in advance!
notifications
Install the package python-pyqt5 if you have removed it by accident.
You can check the pacman.log to decide what to do next.
python-pyqt5 is already installed.
I have found these two lines in the pacman.log file...
[2019-12-31T22:45:10+0100] [ALPM] removed pyqt5-common (5.13.2-3)
[2019-12-31T22:45:10+0100] [ALPM] removed libdmx (1.1.4-1)
Both packages are not available/listed to install... Any other suggestions on how to fix this bug?
python-pyqt5 5.14.1-1
libdmx 1.1.4-2
In Konflikt mit          : pyqt5-common
In conflict with : pyqt5-common
Would you suggest me to install the libdmx package from AUR?
I have installed the libdmx package from AUR, but I still encounter the same error...
