Hello Every one,
I recently updated my visual-studio-code-bin to (1.58.0-1 ) before it lagged a little but now it is lagging very much I tried disabling all extensions it was a little better but still lagged.
Please help me I am a noob so please explain me how to do the required things.
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=248c4f53-a1ec-45c8-bdbe-4126a41a50da rw quiet apparmor=1
security=apparmor resume=UUID=1335144a-2dc2-4e7a-96e0-7ef927a3b1fd
udev.log_priority=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: LENOVO product: 80UD v: Lenovo ideapad 110-15ISK
serial: <filter> Chassis: type: 10 v: Lenovo ideapad 110-15ISK
serial: <filter>
Mobo: LENOVO model: Lenovo ideapad 1 v: No DPK serial: <filter> UEFI: LENOVO
v: 1TCN23WW(V2.04) date: 03/06/2017
ID-1: BAT1 charge: 5.8 Wh (36.0%) condition: 16.1/30.1 Wh (53.6%)
volts: 15.2 min: 14.4 model: SANYO PABAS0241231 type: Li-ion
serial: <filter> status: Charging
RAM: total: 11.58 GiB used: 4.79 GiB (41.4%)
Info: Dual Core model: Intel Core i3-6006U bits: 64 type: MT MCP
arch: Skylake family: 6 model-id: 4E (78) stepping: 3 microcode: E2 cache:
L2: 3 MiB bogomips: 16006
Speed: 800 MHz min/max: 400/2000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Acer EasyCamera type: USB driver: uvcvideo bus-ID: 1-5:4
chip-ID: 5986:06b3 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.1.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 5000 bus-ID: 01:00.0 chip-ID: 10ec:8136
class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8821AE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtl8821ae v: kernel port: 4000 bus-ID: 02:00.0
chip-ID: 10ec:8821 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Device-1: Realtek RTL8821A Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-7:6 chip-ID: 0bda:0821 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 11 state: down bt-service: enabled,running
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 931.51 GiB used: 33.05 GiB (3.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10JPCX-24UE4T0
rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE0N rev: T.02
dev-links: cdrom
ID-1: / raw-size: 421.09 GiB size: 413.41 GiB (98.18%)
used: 33.03 GiB (8.0%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 248c4f53-a1ec-45c8-bdbe-4126a41a50da
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 1088-6921
ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 1335144a-2dc2-4e7a-96e0-7ef927a3b1fd
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 503.96 GiB fs: <superuser required>
label: N/A uuid: 46DE8A13DE89FC05
ID-3: /dev/sda4 maj-min: 8:4 size: 499 MiB fs: <superuser required>
label: N/A uuid: 06CE1323CE130A97
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-2:2 info: Holtek CB-GK-16 Firefly type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 04d9:a1cd class-ID: 0300
Device-2: 1-4:3 info: USB OPTICAL MOUSE type: Mouse,Keyboard
power: 100mA chip-ID: 4e53:5406 class-ID: 0301
Device-3: 1-5:4 info: Acer EasyCamera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:06b3
Device-4: 1-6:5 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-5: 1-7:6 info: Realtek RTL8821A Bluetooth type: Bluetooth
driver: btusb interfaces: 2 rev: 2.1 speed: 12 Mb/s power: 500mA
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 45.0 C mobo: N/A
Processes: 228 Uptime: 9h 38m wakeups: 27 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1302 lib: 356
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.05
