Problem With KDE Plasma X11 and Wayland
Hello i have Problem With KDE Plasma Wayland and X11 When i start it up it Gives me Orginal KDE Logon and Not Manjaro and it also gives me blank screen When i Run plasmashell --replace the error is Qt.qpa Plugin Can Anyone Help Me?
You mean SDDM?
Is using breeze theme instead of breath? Dont worry … there are very few differences besides the breath fork of breeeze being from a much earlier breeze (aka - bugs).
This is configurable via the sddm kcm;
System Settings > Appearance & Style > Colors & Themes > Login Screen (SDDM)
Maybe a bad widget or old configs?
Why are you running plasmashell --replace in the first place?
The Splash Screen is The Breeze i cant Find The Breath and the Wallpaper is not Manjaro its The Mountain Wallpaper
Then you must have removed some things.
It would be provided by the plasma6-themes-breath package that is included with all plasma ISOs.
No default sddm theme (breath or breeze) shows a mountain. Well, I suppose the breath one (provided by sddm-breath-theme package) has one in the background, with a more prominent lighthouse in the foreground.
Regardless … the background is configurable.
Click the little ‘picture’ icon inside the theme tile in the SDDM kcm.
You may also be interested in the button along the top ‘Apply Plasma Settings…’
Imgur
Mod edit:- Unnecessary screenshot removed.
Can you help me with Splash Screen First
First, do you want a splash screen? You do not have to use one. I don’t. :slight_smile: You posted the most basic one. but why stop there?
What is the point of that screenshot?
I already noted
Do you need to know how to change the splash?
Its the system settings section right above sddm.
System Settings > Appearance & Style > Colors & Themes > Splash Screen
it comes With No Breath Theme But ill install it Manally Manjaro also Support AUR Right?
Yes it does.
manjaro/kde/Packages-Desktop · master · Profiles & Settings / iso-profiles · GitLab
How did you install manjaro?
Or maybe you added Plasma yourself and missed some things?
i install it from USB Drive
What usb? When? From what ISO?
As Iinked above … all ISOs would contain sddm-breath-theme.
Maybe share an inxi
inxi -Farz
On neither Arch nor Manjaro is the AUR supported.
But it will be accessible.
What does this matter? And dont you already have the system … so why need to ask?
No Worry I Just install Breath On Cmd ( i have to install it from yay -S plasma6-themes-breath
You make no sense.
You keep skipping parts of what I ask for … and then pose unrelated questions that shouldnt need asking.
… So you arent using manjaro?
That would make more sense.
Please share an inxi.
inxi -Farz
fatal: destination path ‘yay’ already exists and is not an empty directory
What does that mean?
What did you enter to receive that error?
Please try to give context to information.
the inxi -Farz
Hey also Why is Plasma X11 So laggy For Me So i have to use Wayland
Never seen such an error from inxi and cant find any other example online.
You cant run inxi (a system information tool) and your system is laggy and you are missing core packages …
I dont know what you did but your manjaro, if indeed it was ever manjaro, sounds rather broken.
And if you cant provide basic diagnostic information … then helping is going to be rather difficult.
I suppose we can try to tell you to sort mirrors, sync, upgrade, etc, and retry inxi …
sudo pacman-mirrors -c all
sudo pacman-mirrors -f
sudo pacman -Syu inxi
-Reboot-
inxi -Farz
Ok ill Try that.
it Worked!! thx.
