Since previous update my xserver stopped working, just before when sddm would start the screen “freezes” with blinking cursor. I am able to switch to terminal. For the past week I was browsing this and arch forums looking for solutions and nothing works for me.
I tried adding nvidia as kernel parameter, startx returns no usable screen found.
This is my Xorg.0.Log:
[ 11.013] (--) Log file renamed from "/var/log/Xorg.pid-1143.log" to "/var/log/Xorg.0.log"
[ 11.014]
X.Org X Server 1.20.11
[ 11.014] Build Operating System: Linux Manjaro Linux
[ 11.014] Current Operating System: Linux archer2 5.10.52-1-MANJARO #1 SMP PREEMPT Tue Jul 20 20:32:02 UTC 2021 x86_64
[ 11.014] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=578faf7e-dd97-4da1-b103-d60ee581be50 rw quiet apparmor=1 security=apparmor udev.log_priority=3
[ 11.014] Build Date: 13 April 2021 04:11:08PM
[ 11.014]
[ 11.014] Current version of pixman: 0.40.0
[ 11.014] Before reporting problems, check http://wiki.x.org
[ 11.014] Markers: (--) probed, (**) from config file, (==) default setting,
[ 11.014] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Jul 25 19:57:23 2021
[ 11.014] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 11.014] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 11.014] (==) ServerLayout "layout"
[ 11.014] (**) |-->Screen "Screen0" (0)
[ 11.014] (**) | |-->Monitor "Monitor0"
[ 11.014] (**) | |-->Device "Device0"
[ 11.014] (==) Automatically adding devices
[ 11.014] (==) Automatically enabling devices
[ 11.014] (==) Automatically adding GPU devices
[ 11.014] (==) Automatically binding GPU devices
[ 11.014] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 11.014] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 11.014] Entry deleted from font path.
[ 11.014] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 11.014] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 11.014] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 11.014] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 11.014] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 11.014] (**) Extension "COMPOSITE" is enabled
[ 11.014] (II) The server relies on udev to provide the list of input devices.
[ 11.014] (II) Module ABI versions:
[ 11.014] X.Org ANSI C Emulation: 0.4
[ 11.014] X.Org Video Driver: 24.1
[ 11.014] X.Org XInput driver : 24.1
[ 11.014] X.Org Server Extension : 10.0
[ 11.014] (++) using VT number 1
[ 11.014] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 11.014] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 11.016] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 11.016] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 11.016] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 11.018] (--) PCI:*(6@0:0:0) 10de:2191:1558:50f0 rev 161, Mem @ 0xf3000000/16777216, 0xe0000000/268435456, 0xf0000000/33554432, I/O @ 0x00002000/128, BIOS @ 0x????????/524288
[ 11.018] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 11.018] (II) LoadModule: "glx"
[ 11.018] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 11.019] (II) Module glx: vendor="X.Org Foundation"
[ 11.019] compiled for 1.20.11, module version = 1.0.0
[ 11.019] ABI class: X.Org Server Extension, version 10.0
[ 11.019] (II) LoadModule: "nvidia"
[ 11.019] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 11.019] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 11.019] compiled for 1.6.99.901, module version = 1.0.0
[ 11.019] Module class: X.Org Video Driver
[ 11.019] (II) NVIDIA dlloader X Driver 470.57.02 Tue Jul 13 16:13:51 UTC 2021
[ 11.019] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 11.020] (II) Loading sub module "fb"
[ 11.020] (II) LoadModule: "fb"
[ 11.020] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 11.020] (II) Module fb: vendor="X.Org Foundation"
[ 11.020] compiled for 1.20.11, module version = 1.0.0
[ 11.020] ABI class: X.Org ANSI C Emulation, version 0.4
[ 11.020] (II) Loading sub module "wfb"
[ 11.020] (II) LoadModule: "wfb"
[ 11.020] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 11.020] (II) Module wfb: vendor="X.Org Foundation"
[ 11.020] (II) Loading sub module "ramdac"
[ 11.020] (II) LoadModule: "ramdac"
[ 11.020] (II) Module "ramdac" already built-in
[ 11.020] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 11.020] (==) NVIDIA(0): RGB weight 888
[ 11.020] (==) NVIDIA(0): Default visual is TrueColor
[ 11.020] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 11.020] (**) Option "AllowNVIDIAGpuScreens"
[ 11.020] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 11.020] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 11.020] (**) NVIDIA(0): Enabling 2D acceleration
[ 11.020] (II) Loading sub module "glxserver_nvidia"
[ 11.020] (II) LoadModule: "glxserver_nvidia"
[ 11.020] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 11.024] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 11.024] compiled for 1.6.99.901, module version = 1.0.0
[ 11.024] Module class: X.Org Server Extension
[ 11.024] (II) NVIDIA GLX Module 470.57.02 Tue Jul 13 16:10:58 UTC 2021
[ 11.024] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 12.124] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA GPU at PCI:6:0:0. Please
[ 12.124] (EE) NVIDIA(GPU-0): check your system's kernel log for additional error
[ 12.124] (EE) NVIDIA(GPU-0): messages and refer to Chapter 8: Common Problems in the
[ 12.124] (EE) NVIDIA(GPU-0): README for additional information.
[ 12.124] (EE) NVIDIA(GPU-0): Failed to initialize the NVIDIA graphics device!
[ 12.124] (EE) NVIDIA(0): Failing initialization of X screen
[ 12.124] (II) UnloadModule: "nvidia"
[ 12.124] (II) UnloadSubModule: "glxserver_nvidia"
[ 12.124] (II) Unloading glxserver_nvidia
[ 12.124] (II) UnloadSubModule: "wfb"
[ 12.124] (II) UnloadSubModule: "fb"
[ 12.124] (EE) Screen(s) found, but none have a usable configuration.
[ 12.124] (EE)
Fatal server error:
[ 12.124] (EE) no screens found(EE)
[ 12.124] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 12.124] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 12.124] (EE)
[ 12.124] (EE) Server terminated with error (1). Closing log file.
And my Inxi:
Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Console: tty 2 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Notebook product: NH5xAx v: N/A serial: <filter>
Chassis: type: 3 serial: <filter>
Mobo: Notebook model: NH5xAx serial: <filter> UEFI: Insyde v: 1.07.01
date: 02/25/2020
ID-1: BAT0 charge: 58.0 Wh (100.0%) condition: 58.0/62.1 Wh (93.3%)
volts: 12.6 min: 10.9 model: Notebook BAT type: Li-ion serial: <filter>
status: Full
RAM: total: 15.59 GiB used: 560.5 MiB (3.5%)
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: 0 microcode: 8701013 cache:
L2: 3 MiB bogomips: 86278
Speed: 2195 MHz min/max: 2200/3600 MHz boost: enabled Core speeds (MHz):
1: 2195 2: 2208 3: 2194 4: 2186 5: 2195 6: 2198 7: 2196 8: 2194 9: 2192
10: 2241 11: 2195 12: 2190
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload
vgif vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
conditional, RSB filling
Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 06:00.0
chip-ID: 10de:2191 class-ID: 0300
Device-2: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 5-4:2
chip-ID: 5986:9102 class-ID: 0e02
Display: server: X.org 1.20.11 driver: loaded: nvidia
note: n/a (using device driver) unloaded: nvidia tty: 240x67
Message: Advanced graphics data unavailable in console. Try -G --display
Device-1: NVIDIA TU116 High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 10de:1aeb
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus-ID: 08:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.32 running: no
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 8086:2723
class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:4 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 1.36 TiB used: 182.66 GiB (13.1%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate
model: BarraCuda 120 SSD ZA1000CM10003 size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: D013 scheme: GPT
ID-1: / raw-size: 46.57 GiB size: 45.58 GiB (97.89%) used: 20.2 GiB (44.3%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 578faf7e-dd97-4da1-b103-d60ee581be50
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 25.4 MiB (9.9%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
uuid: A899-7517
ID-3: /home raw-size: 219.37 GiB size: 214.92 GiB (97.97%)
used: 140.75 GiB (65.5%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 3a87529d-0570-412d-b391-e2807522750f
ID-4: /run/timeshift/backup raw-size: 117.19 GiB size: 114.85 GiB (98.00%)
used: 21.68 GiB (18.9%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: c67fdb8a-216e-4084-a584-f1af3626b1b8
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 153.25 GiB fs: ntfs
label: New Volume uuid: E66A4D566A4D24A1
ID-3: /dev/nvme0n1p5 maj-min: 259:5 size: 46.57 GiB fs: ext4 label: N/A
uuid: 5ba4da42-d18a-4d13-9dea-a5b656feee1a
ID-4: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
ID-5: /dev/sda3 maj-min: 8:3 size: 500 MiB fs: ntfs label: Recovery
uuid: 609E99DE9E99ACD2
ID-6: /dev/sda4 maj-min: 8:4 size: 637.68 GiB fs: ntfs label: Windows
uuid: F2F49C13F49BD865
ID-7: /dev/sda6 maj-min: 8:6 size: 175.78 GiB fs: ntfs label: backup
uuid: 80B0AF9AB0AF94E6
Device-1: 1-2:2 info: Sunplus Innovation Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 1bcf:0005 class-ID: 0301
Device-2: 1-7:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00a8
class-ID: ff00 serial: <filter>
Device-3: 1-10:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-4:2 info: Acer BisonCam NB Pro type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:9102
class-ID: 0e02
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 66.1 C mobo: 66.0 C
Processes: 258 Uptime: 17m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1380 lib: 394
flatpak: 0 Shell: Bash (login) v: 5.1.8 running-in: tty 2 inxi: 3.3.06
Just to clarify I am alternating between using free and nonfree drivers when I am trying to fix a problem, so it might take me a while to test any suggestion.
