Problem when updating
When I try to update xorgproto 2019.2-2.0 I get this error
:: installing xorgproto (2019.2-2.0) breaks dependency 'presentproto' required by libxpresent
searching online I found a possible solution here
but I get another error
error: target not found: libdmx
error: target not found: libxxf86dga
error: target not found: libxxf86misc
What do I do? I'm using the 32 Bit version
You can check dependencies one by one. For example, see if libxpresent is required:
pacman -Qi libxpresent
If it isn't you can remove presentproto
sudo pacman -Rcsnu presentproto
And so on, so on, repeat the process until you can install xorgproto
Old bug. See this Archlinux announcement from december 2019:
https://www.archlinux.org/news/xorg-cleanup-requires-manual-intervention/
As I said, it gives me errors digiting pacman -Rdd libdmx libxxf86dga libxxf86misc && pacman -Syu
It seems that by removing libxpresent now I can upgrade xorgproto, thx
