Do I have a custom ALSA configuration? I seriously doubt it, I don’t know anything about sound, so I basically have the default Manjaro Cinnamon setup.
I tried aplay -D default /usr/share/sounds/purple/alert.wav
and that worked fine, played a sound and output:ed:
Playing WAVE '/usr/share/sounds/purple/alert.wav' : Signed 16 bit Little Endian, Rate 22050 Hz, Mono
The output of aplay -L
, which does contain a “default” device:
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=HDMI,DEV=0
HDA ATI HDMI, HDMI 0
HDMI Audio Output
hdmi:CARD=HDMI,DEV=1
HDA ATI HDMI, HDMI 1
HDMI Audio Output
hdmi:CARD=HDMI,DEV=2
HDA ATI HDMI, HDMI 2
HDMI Audio Output
hdmi:CARD=HDMI,DEV=3
HDA ATI HDMI, HDMI 3
HDMI Audio Output
hdmi:CARD=HDMI,DEV=4
HDA ATI HDMI, HDMI 4
HDMI Audio Output
hdmi:CARD=HDMI,DEV=5
HDA ATI HDMI, HDMI 5
HDMI Audio Output
usbstream:CARD=HDMI
HDA ATI HDMI
USB Stream Output
sysdefault:CARD=Generic
HD-Audio Generic, ALC887-VD Analog
Default Audio Device
front:CARD=Generic,DEV=0
Front output / input
surround21:CARD=Generic,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Generic,DEV=0
HD-Audio Generic, ALC887-VD Digital
IEC958 (S/PDIF) Digital Audio Output
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
usbstream:CARD=BRIO
Logitech BRIO
USB Stream Output
