Hello everyone,
I bought a SAITOR 1080P Webcam from Amazon recently, and this is my first time using a Webcam on Linux.
I think the fact that I’m using Manjaro-i3 doesn’t help either, but the Webcam is supposed to also have a built-in microphone, but it doesn’t seem to work for me.
I tried researching a lot, but I couldn’t solve the issue.
From one of the links I found, I tried installing guvcview
, and when I capture video in there, a bar appears on the top left, implying that there’s sound, but when I save the video and play with VLC and MPV, I don’t hear any sound.
I try to list a few outputs I saw people asked for in the other posts, please let me know if there’s any other information I can provide:
Output of arecord --list-devices
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1150 Analog [ALC1150 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 2: ALC1150 Alt Analog [ALC1150 Alt Analog]
Subdevices: 1/1
card 2: gadget [USB Webcam gadget], device 0: USB Audio [USB Audio]
Subdevices: 1/1
Output of pacmd list-source-outputs
0 source output(s) available.
I also saw a question about how to hear yourself with a mic, and when I do pactl load-module module-loopback latency_msec=1
, I can hear myself, so I think that confirms that the Webcam has a microphone, and it’s somehow working, but when I try to use it in Zoom, the other party doesn’t hear me
Any help is appreciated, thank you
UPDATE: a couple of more outputs:
output of pacmd list-sources
6 source(s) available.
* index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9040
volume: mono: 65536 / 100% / 0.00 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max rewind: 0 KiB
sample spec: s16le 1ch 16000Hz
channel map: mono
Mono
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
card: 0 <alsa_card.usb-Linux_Foundation_USB_Webcam_gadget-02>
module: 6
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "2"
alsa.card_name = "USB Webcam gadget"
alsa.long_card_name = "Linux Foundation USB Webcam gadget at usb-0000:0d:00.0-2, high speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:0d:00.0-usb-0:2:1.2"
sysfs.path = "/devices/pci0000:00/0000:00:1c.4/0000:0d:00.0/usb5/5-2/5-2:1.2/sound/card2"
udev.id = "usb-Linux_Foundation_USB_Webcam_gadget-02"
device.bus = "usb"
device.vendor.id = "1d6b"
device.vendor.name = "Linux Foundation"
device.product.id = "0102"
device.product.name = "EEM Gadget"
device.serial = "Linux_Foundation_USB_Webcam_gadget"
device.form_factor = "webcam"
device.string = "hw:2"
device.buffering.buffer_size = "64000"
device.buffering.fragment_size = "32000"
device.access_mode = "mmap+timer"
device.profile.name = "multichannel-input"
device.profile.description = "Multichannel"
device.description = "EEM Gadget Multichannel"
module-udev-detect.discovered = "1"
device.icon_name = "camera-web-usb"
ports:
multichannel-input: Multichannel Input (priority 0, latency offset 0 usec, available: unknown)
properties:
active port: <multichannel-input>
index: 1
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 1030
volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
sample spec: s16le 2ch 44100Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
monitor_of: 0
card: 1 <alsa_card.pci-0000_00_1f.3>
module: 7
properties:
device.description = "Monitor of Built-in Audio Digital Stereo (IEC958)"
device.class = "monitor"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xdfb40000 irq 168"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a170"
device.product.name = "100 Series/C230 Series Chipset Family HD Audio Controller"
device.string = "0"
device.icon_name = "audio-card-pci"
index: 2
state: SUSPENDED
suspend cause: IDLE
priority: 1030
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 1999.82 ms
monitor_of: 1
card: 2 <alsa_card.pci-0000_01_00.1>
module: 24
properties:
device.description = "Monitor of GM200 High Definition Audio Digital Stereo (HDMI 2)"
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xdf080000 irq 17"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "0fb0"
device.product.name = "GM200 High Definition Audio"
device.string = "1"
index: 3
driver: <module-null-sink.c>
state: SUSPENDED
suspend cause: IDLE
priority: 1000
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 1
configured latency: 0.00 ms; range is 0.50 .. 50.00 ms
monitor_of: 2
module: 25
properties:
device.description = "Monitor of PulseEffects(apps)"
index: 4
state: SUSPENDED
suspend cause: IDLE
priority: 1000
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
monitor_of: 3
module: 26
properties:
device.description = "Monitor of PulseEffects(mic)"
index: 5
driver: <module-bluez5-device.c>
state: SUSPENDED
suspend cause: IDLE
priority: 1050
balance 0.00
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
fixed latency: 45.32 ms
monitor_of: 4
card: 3 <bluez_card.E8_07_BF_65_29_05>
module: 27
properties:
device.description = "Monitor of SoundBuds Curve"
device.string = "E8:07:BF:65:29:05"
device.api = "bluez"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_E8_07_BF_65_29_05"
bluez.class = "0x240404"
bluez.alias = "SoundBuds Curve"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
And output of pacmd dump | grep -v module
### Configuration dump generated at Fri Oct 30 09:12:32 2020
set-sink-volume alsa_output.pci-0000_00_1f.3.iec958-stereo 0x10000
set-sink-mute alsa_output.pci-0000_00_1f.3.iec958-stereo no
suspend-sink alsa_output.pci-0000_00_1f.3.iec958-stereo yes
set-sink-volume alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1 0x10000
set-sink-mute alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1 no
suspend-sink alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1 yes
set-sink-volume PulseEffects_apps 0x10000
set-sink-mute PulseEffects_apps no
suspend-sink PulseEffects_apps yes
set-sink-volume PulseEffects_mic 0x10000
set-sink-mute PulseEffects_mic no
suspend-sink PulseEffects_mic yes
set-sink-volume bluez_sink.E8_07_BF_65_29_05.a2dp_sink 0xe651
set-sink-mute bluez_sink.E8_07_BF_65_29_05.a2dp_sink no
suspend-sink bluez_sink.E8_07_BF_65_29_05.a2dp_sink yes
set-source-volume alsa_input.usb-Linux_Foundation_USB_Webcam_gadget-02.multichannel-input 0x10000
set-source-mute alsa_input.usb-Linux_Foundation_USB_Webcam_gadget-02.multichannel-input no
suspend-source alsa_input.usb-Linux_Foundation_USB_Webcam_gadget-02.multichannel-input yes
set-source-volume alsa_output.pci-0000_00_1f.3.iec958-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1f.3.iec958-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1f.3.iec958-stereo.monitor yes
set-source-volume alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor 0x10000
set-source-mute alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor no
suspend-source alsa_output.pci-0000_01_00.1.hdmi-stereo-extra1.monitor yes
set-source-volume PulseEffects_apps.monitor 0x10000
set-source-mute PulseEffects_apps.monitor no
suspend-source PulseEffects_apps.monitor yes
set-source-volume PulseEffects_mic.monitor 0x10000
set-source-mute PulseEffects_mic.monitor no
suspend-source PulseEffects_mic.monitor yes
set-source-volume bluez_sink.E8_07_BF_65_29_05.a2dp_sink.monitor 0x10000
set-source-mute bluez_sink.E8_07_BF_65_29_05.a2dp_sink.monitor no
suspend-source bluez_sink.E8_07_BF_65_29_05.a2dp_sink.monitor yes
set-card-profile alsa_card.usb-Linux_Foundation_USB_Webcam_gadget-02 input:multichannel-input
set-card-profile alsa_card.pci-0000_00_1f.3 output:iec958-stereo
set-card-profile alsa_card.pci-0000_01_00.1 output:hdmi-stereo-extra1
set-card-profile bluez_card.E8_07_BF_65_29_05 a2dp_sink
set-default-sink bluez_sink.E8_07_BF_65_29_05.a2dp_sink
set-default-source alsa_input.usb-Linux_Foundation_USB_Webcam_gadget-02.multichannel-input
### EOF
