Problem mounting SSD
I recently changed to Linux and everything seems to be doing fine except that i seem to be unable to properly mount a secondary SSD that i had installed when i was still using windows.
I have used Gparted to try and create a proper partition but it just doesnt work properly, i can get m file explorer to detect it but i am unable to create folders or move data inside the SSD i don`t know what to do
Hello and welcome to the Manjaro Community. :smiley:
When I first read your post I somehow skipped over the very obvious part where you said you’d tried to create a new partition.
I’d follow @cscs 's post below.
Just to add: have you taken ownership of the mountpoint you are using, or are you mounting it in a directory in your /home?
If the former:
sudo chown $USER:$USER <path-to-mountpoint>
(remove the trailing / if you use autocomplete).
On the other hand I think this might sound like @mmmmm_tacos did create a partition, likely in a permissions-aware format such as ext4, but is not familiar with how to manage permissions.
Not a mounting problem.
We could start with something like
lsblk -f
to see information about the partition in question.
Can you show the picture, when you create a partition on that disc ?
Sorr for the delay, so far now i have followed This tutorial to try to solve my problem, but got stuck on the last step since after the
command the ssd has disappeared from the file manager and has become unable to use, this is how -f looks like
NAME FSTYPE FSVER LABEL     UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
nvme0n1
├─nvme0n1p1
│    vfat   FAT32           4BBE-DD14                             299.1M     0% /boot/efi
└─nvme0n1p2
     ext4   1.0             91cd6650-d370-4cc8-8e98-e912427a7761    377G    14% /
nvme1n1
└─nvme1n1p1
     ext4   1.0   GArchives d0fcf860-e39b-48be-96fe-0abbaeb22f35  869.2G     0% /srv/GArchives
something i have to say is that the ssd has a 1tb capacity so i don`t know why it shows 869.2G, even on GParted it showed the 1tb
Why mounting to
Better create a sub-folder in your ~ folder and mount the partition into it.
Sorry, i am new to linux so i still don`t know what is best for this, could you please elaborate?
The /srv directory is dedicated for data of services provided by the system.
How did you mount the partition, by command or via /etc/fstab?
via /etc/stab
so /srv is not recommended for this and i should instead use a folder in /home, for example?
Yes, that’s recommendable.
I would use a folder below /home/{your user}
{your user} to be replaced with your user name.
Also, it would be helpful if you share your /etc/fstab with us.
Yes of course
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=4BBE-DD14                            /boot/efi      vfat    defaults,umask=0077 0 2
UUID=91cd6650-d370-4cc8-8e98-e912427a7761 /              ext4    defaults   0 1
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
UUID=d0fcf860-e39b-48be-96fe-0abbaeb22f35 /srv/GArchives ext4 defaults,noatime 0 0
OK, just create the directory and replace the mount point in your /etc/fstab. Then reboot.
Very well, thanks a lot, i am going to reboot now so brb
I have rebooted, should i run
sudo chown
again?
First, I would try if it works without.
The folder ~ is already owned by you, so I would expect the new folder carries already the right ownership.
But it won’t hurt.
sudo mount -a would do.
You shouldn’t need to if mounted in your user /home. Only if e.g. /DATA or whatever.
You are absolutely right, it works now and i can already use it normally
Thanks a lot you are a life saver
Very nice to hear!
