Apps randomly not responding and visual problems
Hello everyone!
Let me catch up real quick, what happened:
I had Manjaro installed for over a year on laptop & desktop and now wanted to try EndeavourOS on my desktop. After installing, there were so many weird issues (will get into that later) and it was basically un-usable. Also after a few hours already I missed my Manjaro and wanted to just cleanly install it again, which I did (on a brand new nvme). Sadly now I have on my new Manjaro install the same dumb issues as previously with Endeavour (and only there). I never had these problems with any other Manjaro install I ever had.
So, to be honest, I don’t know if it has anything to do with that little distro switch, if I “forgot” anything during installing Manjaro or if the problem lays somewhere else? I never had any problems with the install process of Manjaro.
So, now to the issues I face:
I am able to normally boot my system, log in and mostly I am able to use my applications immediately and normally. After some time the program I’m using is not responding anymore and the content of the whole window visually “copies” the background/what was behind that window.
For example: I have Firefox open, watching a video, then I pause and replay the video, whole application freezes (but still in color), after some time the content of the browser window (firefox title bar, tabs, the video and so on) changes to the window/desktop behind the firefox window and I cannot click anywhere to close or minimize it. (sometimes, but not always it happens when i switch something that has audio, like a video on Firefox)
Some other times I boot my system and want to start Spotify as the first app without ANYTHING open, I can click as often as I want on the icon in the taskbar/app menu, but it won’t open - it shows the launch animation, but then just does not open :frowning: Also via terminal it is not responding and if I try to end or kill the process, it does not change something.
This issue occurs mostly on spotify and firefox, but already happened to Telegram, Software Manager, Konsole, Dolphin file manager, …
I honestly have no idea what the problem is, as I really thought that was an Endeavour problem.
What could I do to fix this issue?
sidenote: I still have my Endeavour installation on another SSD, but I never touched it after my new Manjaro install and it is planned to be deleted, but I guess it cannot affect my Manjaro boot on a whole other nvme?
my output for inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.6-x86_64
    root=UUID=18d1741f-b5c5-455b-832d-a0bb78498667 rw quiet splash
    resume=UUID=6455f873-ad0b-48df-820c-a037f2fe22d4 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 wm: kwin_x11 vt: 2
  Mobo: ASUSTeK model: ROG STRIX B550-A GAMING v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 1205
    date: 11/17/2020
  System RAM: total: 32 GiB available: 31.23 GiB used: 2.36 GiB (7.6%)
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
    desc: 1x32 MiB
  Speed (MHz): avg: 2312 high: 3700 min/max: 2200/4650 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
    3: 2200 4: 2200 5: 2200 6: 2052 7: 2200 8: 3700 9: 2200 10: 2200 11: 2200
    12: 2200 bogomips: 88668
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ZOTAC driver: nvidia
    v: 470.223.02 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
    (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-2022 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 07:00.0 chip-ID: 10de:1f08 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.10 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 81 s-size: 1204x343mm (47.40x13.50")
    s-diag: 1252mm (49.29") monitors: <missing: xrandr>
  Monitor-1: Unknown-1 size-res: N/A modes: 1920x1080
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: swrast x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 470.223.02
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
    memory: 5.86 GiB
  API: Vulkan v: 1.3.274 layers: 1 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 2060 driver: nvidia v: 470.223.02
    device-ID: 10de:1f08 surfaces: xcb,xlib
  Device-1: NVIDIA TU106 High Definition Audio vendor: ZOTAC
    bus-ID: 07:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Razer USA Kraken Tournament Edition
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 1532:0520 class-ID: 0300
    serial: <filter>
  API: ALSA v: k6.6.10-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: active with: 1: wireplumber
    status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 16.1 status: active with: pulseaudio-jack
    type: module tools: pacat,pactl,pavucontrol
  Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
    class-ID: 0200
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Microsoft Xbox Wireless Adapter for Windows driver: mt76x2u
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3
    chip-ID: 045e:02e6 class-ID: 0000 serial: <filter>
  IF: wlp2s0f0u3 state: down mac: <filter>
  Local Storage: total: 5.69 TiB used: 42.05 GiB (0.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QJXG7 temp: 31.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1500DL003-9VT16L
    size: 1.36 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CC32 scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 860 QVO 2TB
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  ID-1: / raw-size: 165.63 GiB size: 161.97 GiB (97.79%) used: 15.09 GiB (9.3%)
    fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8 label: root
    uuid: 18d1741f-b5c5-455b-832d-a0bb78498667
  ID-2: /boot raw-size: 512 MiB size: 487.2 MiB (95.16%)
    used: 127.9 MiB (26.2%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
    label: boot uuid: 02b2a2f4-adcb-473b-9c72-c18ea155141e
  ID-3: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%)
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7 maj-min: 259:7
    label: BOOTEFI uuid: FEBA-2866
  ID-4: /home raw-size: 400 GiB size: 392.64 GiB (98.16%)
    used: 26.83 GiB (6.8%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
    label: home uuid: c44fac07-8732-4ae7-ad40-44ca84e1b61b
  ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p5 maj-min: 259:5 label: swap
    uuid: 6455f873-ad0b-48df-820c-a037f2fe22d4
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: E8D1-880C
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 1.25 TiB fs: ntfs label: N/A
    uuid: 0ACCE0A2CCE088F1
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 562 MiB fs: ntfs label: N/A
    uuid: D08474088473EF7A
  ID-5: /dev/sda1 maj-min: 8:1 size: 50 GiB fs: ext4 label: root
    uuid: 1b4c69ce-c738-44e3-a407-81fd7c096cfd
  ID-6: /dev/sda2 maj-min: 8:2 size: 415.26 GiB fs: ext4 label: home
    uuid: 516c0ab8-e88b-43a7-91a3-63af222c54ef
  ID-7: /dev/sda3 maj-min: 8:3 size: 512 MiB fs: vfat label: BOOT
    uuid: 8E06-BB62
  ID-8: /dev/sdb1 maj-min: 8:17 size: 1.36 TiB fs: ntfs label: HDD
    uuid: 90307E7D307E69DC
  ID-9: /dev/sdb2 maj-min: 8:18 size: 449 MiB fs: ntfs label: N/A
    uuid: EA3E0B513E0B15EB
  ID-10: /dev/sdc1 maj-min: 8:33 size: 100 MiB fs: vfat label: N/A
    uuid: 745E-D2B9
  ID-11: /dev/sdc2 maj-min: 8:34 size: 16 MiB fs: <superuser required>
  ID-12: /dev/sdc3 maj-min: 8:35 size: 232.27 GiB fs: ntfs label: N/A
    uuid: B65C629C5C6256E1
  ID-13: /dev/sdc4 maj-min: 8:36 size: 515 MiB fs: ntfs label: N/A
    uuid: A08CFCC68CFC984C
  ID-14: /dev/sdd1 maj-min: 8:49 size: 1.82 TiB fs: ext4 label: SSD-X
    uuid: d24bb3d1-bfe8-4c85-89b5-25a87800816f
  Device-1: 1-1:2 info: Logitech Logi Bolt Receiver type: keyboard,mouse,HID
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c548 class-ID: 0300
  Device-2: 1-3:3 info: Microsoft Xbox Wireless Adapter for Windows
    type: Network driver: mt76x2u interfaces: 1 rev: 2.1
  Device-3: 1-4:4 info: Microsoft Xbox Controller type: <vendor specific>
    driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 045e:0b12 class-ID: ff00 serial: <filter>
  Device-4: 1-6:5 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
    serial: <filter>
  Hub-2: 1-7:6 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Razer USA Kraken Tournament Edition type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
    chip-ID: 1532:0520 class-ID: 0300 serial: <filter>
  Device-2: 5-4:3 info: Corsair K55 RGB PRO Gaming Keyboard
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
    chip-ID: 1b1c:1ba4 class-ID: 0300 serial: <filter>
  Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 46.4 C mobo: N/A gpu: nvidia temp: 30 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 68%
  Processes: 270 Uptime: 7m wakeups: 0 Init: systemd v: 255 default: graphical
  tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman
  pkgs: 1274 libs: 363 tools: pamac pm: flatpak pkgs: 0 Shell: Bash v: 5.2.21
  running-in: konsole inxi: 3.3.31
here my installed versions of the two main apps where the problem occurs (but not limited to)
Please tell me, if I can provide you with any other information and THANK YOU in advance for helping me get rid of this dumb issue :frowning:
PS: I tried to get a window to freeze and show the background, but now it’s not working :sweat_smile: - if I face the issue again, I’ll make sure to screenshot it and provide it, so it is easier to imagine.
So, it did not take long to face the issue again. I hope it is clear through the screenshots.
As you can see, the “new window” copies the desktop image and after some time it freezes and gets graycolor. You can see there that the “Warning - Window Manager” has the content as the window behind it, which is Spectacle for the screenshots. I really hope we can find the issue :frowning:
Is there a particular reason you’re using the 470 version rather than the current 545 driver? Changing it might make a difference.
I updated my driver to 545, but the issue persists :frowning:
sorry for the late reply, as I got sick :frowning:
see attached the issue, a few minutes after updating.
