Problem installing manjaro 18.0.4 using calamares in a LVM environment
I downloaded manjaro-kde-18.0.4-stable-x86_64.iso and used dd to write to a USB. I checked the sha1 of the USB which matched that of the ISO. I have the following structure of my HDD:
sda1 -> 500MB (esp, boot)
sda2 -> 118GB LVM2 (VG LinuxSystem)-> LV1 -> 8GB set aside for Linux swap
LV2 -> 50GB set aside for Linux system
LV2 -> 66.85GB set aside for Linux home
sda5 -> 170GB NTFS data partition
sda6 -> 170GB luks(ext4) data partition
I want to install Manjaro in this system and I do not have an internet connection (this ruled out architect).
When starting up calamares, everything runs fine and I first flag sda1 as /boot/efi. Then I flag the respective LVs with the correct mount points (swap, / and /home) (also format the partitions as it contains data from a previous installation). I set up the user and password. But when I proceed with the installation, calamares exits with the error message that it cannot format partition " /dev/LinuxSystem/LinuxBase on disk 'LinuxSystem'"
Detailed output from calamares:
[manjaro x86_64]# calamares -D8
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
20:52:08 [6]: Using log file: "/root/.cache/calamares/session.log"
20:52:08 [6]: Using Calamares QML directory "/usr/share/calamares/qml"
20:52:08 [6]: Using Calamares settings file at "/etc/calamares/settings.conf"
20:52:08 [2]: WARNING: Required settings.conf key disable-cancel is missing.
20:52:08 [6]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
20:52:08 [2]: WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
20:52:08 [6]: Loaded branding component "manjaro"
20:52:08 [6]: STARTUP: initQmlPath, initSettings, initBranding done
20:52:08 [6]: STARTUP: initModuleManager: module init started
20:52:08 [6]: STARTUP: initModuleManager: all modules init done
20:52:08 [6]: STARTUP: initJobQueue done
20:52:08 [6]: Available desktop QSize(1366, 723) minimum size QSize(1024, 520)
20:52:08 [6]:   Proposed window size: 1024 640
20:52:08 [6]: STARTUP: CalamaresWindow created; loadModules started
20:52:08 [6]: Loaded module configuration "/etc/calamares/modules/welcome.conf"
20:52:08 [6]: Matching exact locale QLocale(English, Latin, United States)
20:52:08 [6]:  .. Matched locale  "en_US"
20:52:08 [6]: Looking for translations for "en_US"
20:52:08 [6]:  .. Calamares using locale: "en_US"
20:52:08 [6]: Welcome string false "Manjaro Linux 18.0.4 \"Illyria\""
20:52:08 [6]: ViewModule "welcome@welcome" loading complete.
20:52:08 [6]: Loaded module configuration "/etc/calamares/modules/locale.conf"
20:52:08 [6]: ViewModule "locale@locale" loading complete.
20:52:08 [6]: Loaded module configuration "/usr/share/calamares/modules/keyboard.conf"
20:52:09 [6]: ViewModule "keyboard@keyboard" loading complete.
20:52:09 [6]: Loaded module configuration "/usr/share/calamares/modules/partition.conf"
20:52:09 [8]: Loaded backend plugin:  "pmlibpartedbackendplugin"
20:52:09 [6]: Setting firmwareType to "efi"
20:52:09 [2]: WARNING: Partition-module does not support *userSwapChoices* setting "file"
20:52:09 [2]: WARNING: Partition-module does not support *userSwapChoices* setting "reuse"
20:52:09 [6]: Found filesystem "ext4"
20:52:09 [6]: Partition-module setting *defaultFileSystemType* "ext4"
20:52:09 [6]: ViewModule "partition@partition" loading complete.
20:52:09 [6]: Loaded module configuration "/etc/calamares/modules/users.conf"
20:52:09 [6]: ViewModule "users@users" loading complete.
20:52:09 [6]: ViewModule "summary@summary" loading complete.
20:52:09 [6]: Module "partition@partition" already loaded.
20:52:09 [6]: QML import paths:
     "/usr/bin"
     "qrc:/qt-project.org/imports"
     "/usr/lib/qt/qml"
20:52:09 [6]: Loaded module configuration "/usr/share/calamares/modules/mount.conf"
20:52:09 [6]: Loaded module configuration "/etc/calamares/modules/unpackfs.conf"
20:52:09 [6]: Loaded module configuration "/etc/calamares/modules/machineid.conf"
20:52:09 [6]: Loaded module configuration "/usr/share/calamares/modules/fstab.conf"
20:52:09 [6]: Module "locale@locale" already loaded.
20:52:09 [6]: Module "keyboard@keyboard" already loaded.
20:52:09 [6]: Loaded module configuration "/usr/share/calamares/modules/luksopenswaphookcfg.conf"
20:52:09 [6]: Loaded module configuration "/etc/calamares/modules/initcpio.conf"
20:52:09 [6]: Module "users@users" already loaded.
20:52:09 [6]: Loaded module configuration "/etc/calamares/modules/displaymanager.conf"
20:52:09 [6]: Loaded module configuration "/etc/calamares/modules/mhwdcfg.conf"
20:52:09 [6]: Loaded module configuration "/etc/calamares/modules/services.conf"
20:52:09 [6]: Loaded module configuration "/usr/share/calamares/modules/grubcfg.conf"
20:52:09 [6]: Loaded module configuration "/etc/calamares/modules/bootloader.conf"
20:52:09 [6]: Loaded module configuration "/etc/calamares/modules/postcfg.conf"
20:52:09 [6]: Loaded module configuration "/usr/share/calamares/modules/umount.conf"
20:52:09 [6]: Loaded module configuration "/etc/calamares/modules/finished.conf"
20:52:09 [6]: ViewModule "finished@finished" loading complete.
20:52:09 [6]: STARTUP: loadModules for all modules done
20:52:09 [6]: Checking module requirements ..
20:52:09 [6]: STARTUP: Window now visible and ProgressTreeView populated
20:52:09 [6]: Need at least storage bytes: 8482560409
20:52:09 [6]: xkbmap selection changed to:  "us" - ""
20:52:09 [6]: Need at least ram bytes: 1073741824
20:52:09 [6]: A battery exists, checking for mains power.
20:52:09 [6]: GeneralRequirements output:
     enoughStorage :   true
     enoughRam :   true
     hasPower :   true
     hasInternet :   true
     isRoot :   true
20:52:09 [6]: Added 5 requirement results
20:52:10 [6]: Fetching GeoIP data from "https://get.geojs.io/v1/ip/geo.json"
20:52:10 [8]: QNetworkReplyHttpImplPrivate::_q_startOperation was called more than once QUrl("https://get.geojs.io/v1/ip/geo.json")
20:52:11 [6]: GeoIP reporting "will not tell/will not tell"
02:22:24 [8]: getting smart status failed for  "/dev/sdb" :  Operation not supported
02:22:26 [6]: Removing unsuitable devices: 3 candidates.
02:22:27 [6]:   .. Removing device with iso9660 filesystem (probably a CD) on it "/dev/sdb"
02:22:28 [6]: LIST OF DETECTED DEVICES:
02:22:28 [6]: node      capacity        name    prettyName
02:22:28 [6]: "/dev/sda" 500105249280 "ATA WDC WD5000BPKX-6" "ATA WDC WD5000BPKX-6 – 465.76 GiB (/dev/sda)"
02:22:28 [6]: "/dev/LinuxSystem" 134058344448 "LinuxSystem" "LinuxSystem – 124.85 GiB (/dev/LinuxSystem)"
02:22:28 [6]: .. 2 devices detected.
02:22:32 [6]: Running "env" ("blkid", "-s", "TYPE", "-o", "value", "/dev/mapper/LinuxSystem-LinuxBase")
02:22:32 [6]: Finished. Exit code: 0
02:22:32 [6]: Checking device "/dev/mapper/LinuxSystem-LinuxBase" for fstab (fs= "ext4" )
mount: /tmp/calamares-ltmUie: /dev/mapper/LinuxSystem-LinuxBase already mounted on /run/media/manjaro/c81b483d-dad0-4085-9537-fcf25194acb7.
02:22:32 [2]: WARNING: Could not mount existing fs
02:22:32 [6]: Checking if "/dev/mapper/LinuxSystem-LinuxBase" can be resized.
02:22:32 [6]:   .. no Partition* found for "/dev/mapper/LinuxSystem-LinuxBase"
02:22:32 [6]: Partition "/dev/mapper/LinuxSystem-LinuxBase" CANNOT BE RESIZED FOR AUTOINSTALL.
02:22:32 [6]: os-prober lines after cleanup:
     "/dev/mapper/LinuxSystem-LinuxBase:Manjaro Linux (18.0.4):ManjaroLinux:linux"
02:22:32 [6]: Ignoring device that is not Disk_Device to bootLoaderDevices list.
02:22:33 [6]: Check EFI bootable "/run/media/manjaro/c81b483d-dad0-4085-9537-fcf25194acb7" "/dev/LinuxSystem"
02:22:33 [6]:  .. flags QFlags<>()
02:22:33 [6]:  .. moved towards root 0x7f790c076ca0
02:22:33 [6]:   .. partition table 0x7f790c076ca0 type 12
02:22:33 [6]: Check EFI bootable "/dev/LinuxSystem/LinuxHome" "/dev/LinuxSystem"
02:22:33 [6]: Check EFI bootable "/dev/LinuxSystem/LinuxSwap" "/dev/LinuxSystem"
02:22:33 [6]: Check EFI bootable "/dev/sda1" "/dev/sda"
02:22:33 [6]: Check EFI bootable "LinuxSystem" "/dev/sda"
02:22:33 [6]:  .. moved towards root 0x7f790c081e60
02:22:33 [6]:   .. partition table 0x7f790c081e60 type 6
02:22:33 [6]: Check EFI bootable "/dev/sda5" "/dev/sda"
02:22:33 [6]: Check EFI bootable "/dev/sda" "/dev/sda"
02:22:33 [6]: Check EFI bootable "/dev/sda6" "/dev/sda"
02:22:33 [6]: Added 1 requirement results
02:22:33 [6]: Updating partitioning state widgets.
02:22:33 [6]: Setting up actions for "/dev/LinuxSystem" with 0 entries.
02:22:33 [6]: Checking if "/run/media/manjaro/c81b483d-dad0-4085-9537-fcf25194acb7" can be resized.
02:22:33 [6]:   .. partition is mounted
02:22:33 [6]: .. contains mounted "/dev/LinuxSystem/LinuxBase"
02:22:33 [6]: Checking if "/dev/LinuxSystem/LinuxHome" can be resized.
02:22:33 [6]: Required  storage B: 11166914969 "(10.4GB)"
02:22:33 [6]: Available storage B: 69747081216 "(64GB)" for "/dev/LinuxSystem/LinuxHome"    length: 17114    sectorsUsed: 485    fsType: "ext4"
02:22:33 [6]: Partition "/dev/LinuxSystem/LinuxHome" authorized for resize + autopartition install.
02:22:33 [6]: .. contains resizable "/dev/LinuxSystem/LinuxHome"
02:22:33 [6]: Required  storage B: 9019431321 "(8GB)"
02:22:33 [6]: Storage capacity  B: 71781318656 "(66GB)" for "/dev/LinuxSystem/LinuxHome"    length: 17114
02:22:33 [6]: Partition "/dev/LinuxSystem/LinuxHome" authorized for replace install.
02:22:33 [6]: .. contains replaceable "/dev/LinuxSystem/LinuxHome"
02:22:33 [6]: Checking if "/dev/LinuxSystem/LinuxSwap" can be resized.
02:22:33 [6]: Available storage B: 8589934592 "(8GB)" for "/dev/LinuxSystem/LinuxSwap"    length: 2048    sectorsUsed: 0    fsType: "linuxswap"
02:22:33 [6]: Storage capacity  B: 8589934592 "(8GB)" for "/dev/LinuxSystem/LinuxSwap"    length: 2048
02:22:33 [6]: Setting texts for 0 osprober entries
02:22:33 [6]: Erase button suppressed mount? true raid? false
02:22:33 [6]: Updating partitioning preview widgets.
02:22:33 [6]: All requirements have been checked.
02:47:18 [6]: Got locale language "en_XX"
02:47:18 [6]:  .. extracted country "XXX" :: ("en", "XX")
02:47:18 [6]:    .. looking for locale part "XX"
02:47:18 [6]:    .. matched "XX"
02:47:18 [6]: Next level: "en"
02:47:19 [6]: xkbmap selection changed to:  "XX" - ""
02:47:19 [0]: no keyboard layouts with latin keys present
02:47:25 [6]: xkbmap selection changed to:  "us" - ""
02:47:31 [6]: Updating partitioning preview widgets.
02:47:41 [6]: Choice applied:  4
02:47:56 [6]: old boundaries: 0 12799 12800
02:47:56 [6]: new boundaries: 0 12799
02:47:56 [6]: dirty status: false
02:47:57 [6]: Check EFI bootable "/run/media/manjaro/c81b483d-dad0-4085-9537-fcf25194acb7" "/dev/LinuxSystem"
02:47:57 [6]:  .. flags QFlags<>()
02:47:57 [6]:  .. moved towards root 0x7f790c076ca0
02:47:57 [6]:   .. partition table 0x7f790c076ca0 type 12
02:47:57 [6]: Check EFI bootable "/dev/LinuxSystem/LinuxHome" "/dev/LinuxSystem"
02:47:57 [6]: Check EFI bootable "/dev/LinuxSystem/LinuxSwap" "/dev/LinuxSystem"
02:47:57 [6]: Check EFI bootable "/dev/sda1" "/dev/sda"
02:47:57 [6]: Check EFI bootable "LinuxSystem" "/dev/sda"
02:47:57 [6]:  .. moved towards root 0x7f790c081e60
02:47:57 [6]:   .. partition table 0x7f790c081e60 type 6
02:47:57 [6]: Check EFI bootable "/dev/sda5" "/dev/sda"
02:47:57 [6]: Check EFI bootable "/dev/sda" "/dev/sda"
02:47:57 [6]: Check EFI bootable "/dev/sda6" "/dev/sda"
02:48:19 [6]: old boundaries: 12800 29913 17114
02:48:19 [6]: new boundaries: 12800 29913
02:48:19 [6]: dirty status: false
02:48:20 [6]: Check EFI bootable "/run/media/manjaro/c81b483d-dad0-4085-9537-fcf25194acb7" "/dev/LinuxSystem"
02:48:20 [6]:  .. flags QFlags<>()
02:48:20 [6]:  .. moved towards root 0x7f790c076ca0
02:48:20 [6]:   .. partition table 0x7f790c076ca0 type 12
02:48:20 [6]: Check EFI bootable "/dev/LinuxSystem/LinuxHome" "/dev/LinuxSystem"
02:48:20 [6]: Check EFI bootable "/dev/LinuxSystem/LinuxSwap" "/dev/LinuxSystem"
02:48:20 [6]: Check EFI bootable "/dev/sda1" "/dev/sda"
02:48:20 [6]: Check EFI bootable "LinuxSystem" "/dev/sda"
02:48:20 [6]:  .. moved towards root 0x7f790c081e60
02:48:20 [6]:   .. partition table 0x7f790c081e60 type 6
02:48:20 [6]: Check EFI bootable "/dev/sda5" "/dev/sda"
02:48:20 [6]: Check EFI bootable "/dev/sda" "/dev/sda"
02:48:20 [6]: Check EFI bootable "/dev/sda6" "/dev/sda"
02:48:24 [6]: old boundaries: 29914 31961 2048
02:48:24 [6]: new boundaries: 29914 31961
02:48:24 [6]: dirty status: false
02:48:25 [6]: Check EFI bootable "/run/media/manjaro/c81b483d-dad0-4085-9537-fcf25194acb7" "/dev/LinuxSystem"
02:48:25 [6]:  .. flags QFlags<>()
02:48:25 [6]:  .. moved towards root 0x7f790c076ca0
02:48:25 [6]:   .. partition table 0x7f790c076ca0 type 12
02:48:25 [6]: Check EFI bootable "/dev/LinuxSystem/LinuxHome" "/dev/LinuxSystem"
02:48:25 [6]: Check EFI bootable "/dev/LinuxSystem/LinuxSwap" "/dev/LinuxSystem"
02:48:25 [6]: Check EFI bootable "/dev/sda1" "/dev/sda"
02:48:25 [6]: Check EFI bootable "LinuxSystem" "/dev/sda"
02:48:25 [6]:  .. moved towards root 0x7f790c081e60
02:48:25 [6]:   .. partition table 0x7f790c081e60 type 6
02:48:25 [6]: Check EFI bootable "/dev/sda5" "/dev/sda"
02:48:25 [6]: Check EFI bootable "/dev/sda" "/dev/sda"
02:48:25 [6]: Check EFI bootable "/dev/sda6" "/dev/sda"
02:48:40 [6]: old boundaries: 2048 1026047 1024000
02:48:40 [6]: new boundaries: 2048 1026047
02:48:40 [6]: dirty status: false
02:48:41 [6]: Check EFI bootable "/run/media/manjaro/c81b483d-dad0-4085-9537-fcf25194acb7" "/dev/LinuxSystem"
02:48:41 [6]:  .. flags QFlags<>()
02:48:41 [6]:  .. moved towards root 0x7f790c076ca0
02:48:41 [6]:   .. partition table 0x7f790c076ca0 type 12
02:48:41 [6]: Check EFI bootable "/dev/LinuxSystem/LinuxHome" "/dev/LinuxSystem"
02:48:41 [6]: Check EFI bootable "/dev/LinuxSystem/LinuxSwap" "/dev/LinuxSystem"
02:48:41 [6]: Check EFI bootable "/dev/sda1" "/dev/sda"
02:48:41 [6]: Check EFI bootable "LinuxSystem" "/dev/sda"
02:48:41 [6]:  .. moved towards root 0x7f790c081e60
02:48:41 [6]:   .. partition table 0x7f790c081e60 type 6
02:48:41 [6]: Check EFI bootable "/dev/sda5" "/dev/sda"
02:48:41 [6]: Check EFI bootable "/dev/sda" "/dev/sda"
02:48:41 [6]: Check EFI bootable "/dev/sda6" "/dev/sda"
02:48:43 [6]: Check EFI bootable "/dev/sda1" "/dev/sda"
02:48:43 [6]:  .. flags QFlags<>()
02:49:18 [0]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
02:49:18 [0]: QObject::setParent: Cannot set parent, new parent is in a different thread
02:49:18 [6]: Gathering UUIDs for partitions that exist now.
02:49:18 [6]: .. added path= "/dev/sda1" UUID= "70F3-D360"
02:49:18 [6]: .. added path= "/dev/sda2" UUID= "PDjtaX-iM8d-UijL-bl8Y-a7DX-bbCl-wtyNKZ"
02:49:18 [6]: .. added path= "/dev/sda5" UUID= "4CE385C7633D076F"
02:49:18 [6]: .. added path= "" UUID= ""
02:49:18 [6]: .. added path= "/dev/sda6" UUID= "84453ae3-f4ed-49c0-9028-2220e0f39ffb"
02:49:18 [6]: .. added path= "/dev/LinuxSystem/LinuxBase" UUID= "c81b483d-dad0-4085-9537-fcf25194acb7"
02:49:18 [6]: .. added path= "/dev/LinuxSystem/LinuxHome" UUID= "92e41675-b61c-420b-a3e2-797b1319b64d"
02:49:18 [6]: .. added path= "/dev/LinuxSystem/LinuxSwap" UUID= "12cb5563-4ba3-4d08-bb66-cec6b9b094b1"
02:49:18 [6]: Writing to GlobalStorage["partitions"]
02:49:18 [6]: .. partitions on "/dev/sda"
02:49:18 [6]:   .. mapping for "/dev/sda1" "/dev/sda1"
     mtpoint: :   "/boot/efi"
     fs: :   "fat32"
     fsname :   "fat32"
     uuid :   "70F3-D360"
02:49:18 [6]:   .. mapping for "/dev/sda2" "/dev/sda2"
     mtpoint: :   ""
     fs: :   "lvm2 pv"
     fsname :   "lvm2 pv"
     uuid :   "PDjtaX-iM8d-UijL-bl8Y-a7DX-bbCl-wtyNKZ"
02:49:18 [6]:   .. mapping for "/dev/sda5" "/dev/sda5"
     mtpoint: :   ""
     fs: :   "ntfs"
     fsname :   "ntfs"
     uuid :   "4CE385C7633D076F"
02:49:18 [6]:   .. mapping for "" "unallocated"
     mtpoint: :   ""
     fs: :   "unknown"
     fsname :   "unknown"
     uuid :   ""
02:49:18 [6]:   .. mapping for "/dev/sda6" "/dev/sda6"
     mtpoint: :   ""
     fs: :   "luks"
     fsname :   "luks"
     uuid :   "84453ae3-f4ed-49c0-9028-2220e0f39ffb"
     luksMapperName: :   ""
     mtpoint: :   ""
     fs: :   "unknown"
     fsname :   "unknown"
     uuid :   ""
02:49:18 [6]: .. partitions on "/dev/LinuxSystem"
02:49:18 [6]:   .. mapping for "/dev/LinuxSystem/LinuxBase" "/dev/LinuxSystem/LinuxBase"
     mtpoint: :   "/"
     fs: :   "ext4"
     fsname :   "ext4"
     uuid :   "c81b483d-dad0-4085-9537-fcf25194acb7"
02:49:18 [6]:   .. mapping for "/dev/LinuxSystem/LinuxHome" "/dev/LinuxSystem/LinuxHome"
     mtpoint: :   "/home"
     fs: :   "ext4"
     fsname :   "ext4"
     uuid :   "92e41675-b61c-420b-a3e2-797b1319b64d"
02:49:18 [6]:   .. mapping for "/dev/LinuxSystem/LinuxSwap" "/dev/LinuxSystem/LinuxSwap"
     mtpoint: :   ""
     fs: :   "linuxswap"
     fsname :   "linuxswap"
     uuid :   "12cb5563-4ba3-4d08-bb66-cec6b9b094b1"
02:49:18 [8]: QVariant(QString, "70F3-D360") "/dev/sda1" "/boot/efi" "fat32"
02:49:18 [8]: QVariant(QString, "PDjtaX-iM8d-UijL-bl8Y-a7DX-bbCl-wtyNKZ") "/dev/sda2" "" "lvm2 pv"
02:49:18 [8]: QVariant(QString, "4CE385C7633D076F") "/dev/sda5" "" "ntfs"
02:49:18 [8]: QVariant(QString, "") "" "" "unknown"
02:49:18 [8]: QVariant(QString, "84453ae3-f4ed-49c0-9028-2220e0f39ffb") "/dev/sda6" "" "luks"
02:49:18 [8]: QVariant(QString, "c81b483d-dad0-4085-9537-fcf25194acb7") "/dev/LinuxSystem/LinuxBase" "/" "ext4"
02:49:18 [8]: QVariant(QString, "92e41675-b61c-420b-a3e2-797b1319b64d") "/dev/LinuxSystem/LinuxHome" "/home" "ext4"
02:49:18 [8]: QVariant(QString, "12cb5563-4ba3-4d08-bb66-cec6b9b094b1") "/dev/LinuxSystem/LinuxSwap" "" "linuxswap"
02:49:19 [6]: .. added path= "/dev/sda5" UUID= "4CE385C7633D076F"
02:49:19 [6]: .. added path= "" UUID= ""
02:49:19 [6]: .. added path= "/dev/sda6" UUID= "84453ae3-f4ed-49c0-9028-2220e0f39ffb"
02:49:19 [6]: .. added path= "/dev/LinuxSystem/LinuxBase" UUID= "c81b483d-dad0-4085-9537-fcf25194acb7"
02:49:19 [6]: .. added path= "/dev/LinuxSystem/LinuxHome" UUID= "92e41675-b61c-420b-a3e2-797b1319b64d"
02:49:19 [6]: .. added path= "/dev/LinuxSystem/LinuxSwap" UUID= "12cb5563-4ba3-4d08-bb66-cec6b9b094b1"
02:49:19 [6]: Writing to GlobalStorage["partitions"]
02:49:19 [6]: .. partitions on "/dev/sda"
02:49:19 [6]:   .. mapping for "/dev/sda1" "/dev/sda1"
     fs: :   "fat32"
     fsname :   "fat32"
     uuid :   "70F3-D360"
02:49:19 [6]:   .. mapping for "/dev/sda2" "/dev/sda2"
     mtpoint: :   ""
     fs: :   "lvm2 pv"
     fsname :   "lvm2 pv"
02:49:19 [6]:   .. mapping for "/dev/sda5" "/dev/sda5"
     mtpoint: :   ""
     fs: :   "ntfs"
     fsname :   "ntfs"
02:49:19 [6]:   .. mapping for "" "unallocated"
     mtpoint: :   ""
     fs: :   "unknown"
     fsname :   "unknown"
     uuid :   ""
02:49:19 [6]:   .. mapping for "/dev/sda6" "/dev/sda6"
     mtpoint: :   ""
     fs: :   "luks"
     fsname :   "luks"
     mtpoint: :   ""
     fs: :   "unknown"
     fsname :   "unknown"
     uuid :   ""
02:49:19 [6]: .. partitions on "/dev/LinuxSystem"
02:49:19 [6]:   .. mapping for "/dev/LinuxSystem/LinuxBase" "/dev/LinuxSystem/LinuxBase"
     mtpoint: :   "/"
     fs: :   "ext4"
     fsname :   "ext4"
02:49:19 [6]:   .. mapping for "/dev/LinuxSystem/LinuxHome" "/dev/LinuxSystem/LinuxHome"
     mtpoint: :   "/home"
     fs: :   "ext4"
     fsname :   "ext4"
02:49:19 [6]:   .. mapping for "/dev/LinuxSystem/LinuxSwap" "/dev/LinuxSystem/LinuxSwap"
     mtpoint: :   ""
     fs: :   "linuxswap"
02:49:19 [8]: QVariant(QString, "70F3-D360") "/dev/sda1" "/boot/efi" "fat32"
02:49:19 [8]: QVariant(QString, "PDjtaX-iM8d-UijL-bl8Y-a7DX-bbCl-wtyNKZ") "/dev/sda2" "" "lvm2 pv"
02:49:19 [8]: QVariant(QString, "4CE385C7633D076F") "/dev/sda5" "" "ntfs"
02:49:19 [8]: QVariant(QString, "") "" "" "unknown"
02:49:19 [8]: QVariant(QString, "84453ae3-f4ed-49c0-9028-2220e0f39ffb") "/dev/sda6" "" "luks"
02:49:19 [8]: QVariant(QString, "c81b483d-dad0-4085-9537-fcf25194acb7") "/dev/LinuxSystem/LinuxBase" "/" "ext4"
02:49:19 [8]: QVariant(QString, "92e41675-b61c-420b-a3e2-797b1319b64d") "/dev/LinuxSystem/LinuxHome" "/home" "ext4"
02:49:19 [8]: QVariant(QString, "12cb5563-4ba3-4d08-bb66-cec6b9b094b1") "/dev/LinuxSystem/LinuxSwap" "" "linuxswap"
02:49:19 [6]: Summary widget is larger than viewport, enlarge by 269 to QSize(822, 857)
03:06:42 [6]: Starting job "Clear all temporary mounts."
03:06:42 [6]: Opened mtab. Lines:
03:06:42 [6]: "proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0"
03:06:42 [6]: "sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0"
03:06:42 [6]: "dev /dev devtmpfs rw,nosuid,relatime,size=3991364k,nr_inodes=997841,mode=755 0 0"
03:06:42 [6]: "run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0"
03:06:42 [6]: "efivarfs /sys/firmware/efi/efivars efivarfs rw,nosuid,nodev,noexec,relatime 0 0"
03:06:42 [6]: "/dev/sdb1 /run/miso/bootmnt iso9660 ro,relatime,nojoliet,check=s,map=n,blocksize=2048 0 0"
03:06:42 [6]: "cowspace /run/miso/cowspace tmpfs rw,relatime,size=262144k,mode=755 0 0"
03:06:42 [6]: "overlay_root /run/miso/overlay_root tmpfs rw,relatime,size=6021000k,mode=755 0 0"
03:06:42 [6]: "/dev/loop0 /run/miso/sfs/livefs squashfs ro,relatime 0 0"
03:06:42 [6]: "/dev/loop1 /run/miso/sfs/mhwdfs squashfs ro,relatime 0 0"
03:06:42 [6]: "/dev/loop2 /run/miso/sfs/desktopfs squashfs ro,relatime 0 0"
03:06:42 [6]: "/dev/loop3 /run/miso/sfs/rootfs squashfs ro,relatime 0 0"
03:06:42 [6]: "overlay / overlay rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off 0 0"
03:06:42 [6]: "securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0"
03:06:42 [6]: "tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0"
03:06:42 [6]: "devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0"
03:06:42 [6]: "tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0"
03:06:42 [6]: "cgroup2 /sys/fs/cgroup/unified cgroup2 rw,nosuid,nodev,noexec,relatime,nsdelegate 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,name=systemd 0 0"
03:06:42 [6]: "pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0"
03:06:42 [6]: "bpf /sys/fs/bpf bpf rw,nosuid,nodev,noexec,relatime,mode=700 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/hugetlb cgroup rw,nosuid,nodev,noexec,relatime,hugetlb 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/rdma cgroup rw,nosuid,nodev,noexec,relatime,rdma 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/net_cls,net_prio cgroup rw,nosuid,nodev,noexec,relatime,net_cls,net_prio 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/perf_event cgroup rw,nosuid,nodev,noexec,relatime,perf_event 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0"
03:06:42 [6]: "cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0"
03:06:42 [6]: "systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=34,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=184 0 0"
03:06:42 [6]: "hugetlbfs /dev/hugepages hugetlbfs rw,relatime,pagesize=2M 0 0"
03:06:42 [6]: "debugfs /sys/kernel/debug debugfs rw,relatime 0 0"
03:06:42 [6]: "tmpfs /tmp tmpfs rw,nosuid,nodev 0 0"
03:06:42 [6]: "mqueue /dev/mqueue mqueue rw,relatime 0 0"
03:06:42 [6]: "binfmt_misc /proc/sys/fs/binfmt_misc binfmt_misc rw,relatime 0 0"
03:06:42 [6]: "configfs /sys/kernel/config configfs rw,relatime 0 0"
03:06:42 [6]: "tmpfs /etc/pacman.d/gnupg tmpfs rw,relatime,mode=755 0 0"
03:06:42 [6]: "tmpfs /run/user/1000 tmpfs rw,nosuid,nodev,relatime,size=802800k,mode=700,uid=1000,gid=1000 0 0"
03:06:42 [6]: "fusectl /sys/fs/fuse/connections fusectl rw,relatime 0 0"
03:06:42 [6]: "gvfsd-fuse /run/user/1000/gvfs fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000 0 0"
03:06:42 [6]: "/dev/mapper/LinuxSystem-LinuxBase /run/media/manjaro/c81b483d-dad0-4085-9537-fcf25194acb7 ext4 rw,nosuid,nodev,relatime 0 0"
03:06:42 [6]: ClearTempMountsJob finished. Here's what was done:
03:06:42 [6]: Starting job "Clear mounts for partitioning operations on /dev/sda"
03:06:44 [6]: ClearMountsJob finished. Here's what was done:
 "Successfully closed mapper device /dev/mapper/LinuxSystem-LinuxBase.\nSuccessfully closed mapper device /dev/mapper/LinuxSystem-LinuxHome.\nSuccessfully closed mapper device /dev/mapper/LinuxSystem-LinuxSwap.\nSuccessfully disabled volume group LinuxSystem."
03:06:44 [6]: Starting job "Clear mounts for partitioning operations on /dev/LinuxSystem"
03:06:44 [6]: Starting job "Format partition /dev/LinuxSystem/LinuxBase (file system: ext4, size: 51200 MB) on LinuxSystem."
03:06:44 [6]: Skipping non-emergency job "Format partition /dev/LinuxSystem/LinuxHome (file system: ext4, size: 68456 MB) on LinuxSystem."
03:06:44 [6]: Skipping non-emergency job "Format partition /dev/LinuxSystem/LinuxSwap (file system: linuxswap, size: 8192 MB) on LinuxSystem."
03:06:44 [6]: Skipping non-emergency job "Set partition information"
03:06:44 [6]: Skipping non-emergency job "mount"
03:06:44 [6]: Skipping non-emergency job "unpackfs"
03:06:44 [6]: Skipping non-emergency job "networkcfg"
03:06:44 [6]: Skipping non-emergency job "machineid"
03:06:44 [6]: Skipping non-emergency job "fstab"
03:06:44 [6]: Skipping non-emergency job "Set timezone to XXXXX/XXX"
03:06:44 [6]: Skipping non-emergency job "Set keyboard model to pc105, layout to us-"
03:06:44 [6]: Skipping non-emergency job "localecfg"
03:06:44 [6]: Skipping non-emergency job "luksopenswaphookcfg"
03:06:44 [6]: Skipping non-emergency job "luksbootkeyfile"
03:06:44 [6]: Skipping non-emergency job "initcpiocfg"
03:06:44 [6]: Skipping non-emergency job "initcpio"
03:06:44 [6]: Skipping non-emergency job "Create user newuser"
03:06:44 [6]: Skipping non-emergency job "Set password for user newuser"
03:06:44 [6]: Skipping non-emergency job "Set password for user root"
03:06:44 [6]: Skipping non-emergency job "Set hostname newuser-pc"
03:06:44 [6]: Skipping non-emergency job "displaymanager"
03:06:44 [6]: Skipping non-emergency job "mhwdcfg"
03:06:44 [6]: Skipping non-emergency job "hwclock"
03:06:44 [6]: Skipping non-emergency job "services"
03:06:44 [6]: Skipping non-emergency job "grubcfg"
03:06:44 [6]: Skipping non-emergency job "bootloader"
03:06:44 [6]: Skipping non-emergency job "postcfg"
03:06:44 [6]: Skipping non-emergency job "umount"
03:06:44 [1]: ERROR: Installation failed:
03:06:44 [6]: - message: "The installer failed to format partition /dev/LinuxSystem/LinuxBase on disk 'LinuxSystem'."
03:06:44 [6]: - details: "==========================================================================================\nCreate filesystem ext4 on partition ‘/dev/LinuxSystem/LinuxBase’\n==========================================================================================\n==========================================================================================\nJob: Delete file system on ‘/dev/LinuxSystem/LinuxBase’\n==========================================================================================\n==========================================================================================\nJob: Create file system ‘ext4’ on partition ‘/dev/LinuxSystem/LinuxBase’\n==========================================================================================\n==========================================================================================\nCommand: mkfs.ext4 -qF /dev/LinuxSystem/LinuxBase\n==========================================================================================\nThe file /dev/LinuxSystem/LinuxBase does not exist and no size was specified.\n\n"
03:06:44 [6]: Calamares will quit when the dialog closes.
03:06:44 [6]: FinishedPage::setUpRestart()
It seems that "ClearMountsJob" of calamares is closing the dev mapper so that the mkfs.ext4 has nothing to partition!!
Can anyone suggest how to get around this problem?
Also is there a way to install Manjaro from CLI but without the internet connection? I tried to use "setup" from CLI but it aborts since I have no internet connection.
Can anyone guide me to manually install Manjaro, such as by extracting the desktopfs.sfs and roootfs.sfs files in the LVs and then run the appropriate commands (mkinitcpio grub etc...)?
Sounds very familiar to me. I was able to install Illyria (Gnome version) in my Acer Spin 1 laptop using a workaround. This laptop requires UEFI boot, it doesn't support Legacy/BIOS mode.
My setup is as follows:
EMMC drive with Windows (not to be used at all)
USB 64GB thumb drive. Manjaro will be installed here using the following partitions:
  • sda1 = /boot/efi
  • sda2 = /boot
  • sda3 = Linux LVM
    • volgroup0
      • lv_rootmanjaro
      • lv_swap
Disclaimer: I have performed a Manjaro fresh install on my laptop. The steps I'm about to mention will erase the contents of the drive you use, so take them as an example and perhaps avoid the instructions/commands that format things that you want to keep :wink:
Once Manjaro live is running, open a terminal and become root with 'sudo -i'. If any of your drives/partitions are detected and mounted, unmount them.
Run 'fdisk /dev/sda' (your disk could be detected as a different device, sdb...)
  • Create a new GUID partition table on the Thumb drive where you want to install Manjaro (hit 'g' in fdisk)
  • Create a new partition for /boot/efi (n, 1, enter, +256M, t, 1)
  • Create a new partition for /boot (n, 2, enter, +512M)
  • Create a new partition for LVM (n, 3, enter, enter, t, 3, 31)
  • Write changes (w)
Format the /boot/efi and /boot partitions:
mkfs.fat -F32 /dev/sda1
mkfs.ext2 /dev/sda2
Create the LVM structure:
pvcreate /dev/sda3
lvcreate -L 40GB volgroup0 -n lv_rootmanjaro
lvcreate -L 2GB volgroup0 -n lv_swap
vgscan
vgchange -ay
Format the LVM volumes:
mkfs.ext4 /dev/volgroup0/lv_rootmanjaro
mkswap /dev/volgroup0/lv_swap
On the Manjaro graphical installer, format again the sda1 & sda2 partitions with their respective filesystems.
Select the appropriate mount points:
sda1 -> /boot/efi
sda2 -> /boot
/dev/volgroup0/lv_rootmanjaro -> /
(optional) If you are using EFI "Secure Boot" in your setup, add a new Secure entry: Look for , EFI, bootx64.efi and give it a name. In boot order preferences select as the first option “Manjaro”, GRUB is able to boot Manjaro and Windows.
In conclusion, I think there is a bug on how the graphical installer of Manjaro deals with LVM setups. There are some redundant steps (like formatting twice the /boot partitions) but it was the only way I found to workaround this issue.
It will be great if these problems are solved for next releases, if not at least hope this helps.
I have similar structure to the one above, except my LVM is encrypted with Luks. It's just a test environment, to see how Manjaro handles FDE. I have been using Ubuntu and Mint for years, because the Ubuntu installer has more or less the only installer that lets you properly select manually configured Luks/LVM volumes for your mount points. Most installers can't even find them during partitioning. Manjaro does, but screws everything up, by closing them before installation. So far my testing has brought me no further than to the installation process, before it crashes.
Hope this will get fixed at some point, so that I can finally take this distro for a proper test run. But so long as FDE attempts causes problems, it will have to be put on hold.
Maybe this is fixed in the new version (18.1.0) of Manjaro.
Sorry for replying so late. After the failed installation, I replaced Manjaro with Fedora 31 (when it came out). The installation system of Fedora is IMO better than that of Manjaro but I liked the installed system Manjaro better (Fedora has many bugs) and again moved back to Manjaro 18.1.2. I still was not able to install Manjaro in LVs. It would be nice if the same commands that Calamares runs can be run seperately from the command line...
For LVM installation, I have several times now successfully used Manjaro Architect instead of Calamares because Calamares would often fail. Architect works.
True, but it requires internet connection :cry:
