Network connectivity check hiccups
On Network Manager connectivity check is configured to use http://ping.manjaro.org/check_network_status.txt, but that site is currently broken redirecting to https://ping.manjaro.org/mailman/listinfo that does not contain the required text for the connectivity check.
Just disable it, it’s useless anyway. If it tells you that you have no internet you still have to check, as the server may be down.
sudo touch /etc/NetworkManager/conf.d/20-connectivity.conf
and inside that file
[connectivity]
enabled=false
Not necessary, the empty file will do. :smiley:
I spoke with @codesardine and he told me he blocked browser access due to bots polling it and increasing server load. It was only down for 10 minutes while he was performing maintenance.
When something like that happens, one may see a :grey_question: on their Wi-Fi status icon. To verify NetworkManager connectivity, you can run this command:
❯ nmcli g
STATE      CONNECTIVITY  WIFI-HW  WIFI     WWAN-HW  WWAN
connected  full          enabled  enabled  missing  enabled
