I just switched from windows to manjaro today. I downloaded and launched XAMPP sucessfully. I started the servers and localhost/ showed all my folders properly. However when i try to access one php project i get an HTTP 500 error. This project was shown properly in XAMPP on my windows. I try accessing another php project and it worked fine.
It is just a configuration of your PHP that is different. Probably a PHP module is not enabled.
You’ll need to set up “PHP error_reporting” so you can get useful errors on your development system.
Create this file phpinfo.php
& visit it on your win server & linux server - you can compare the setups.
<?php
phpinfo();
I think its working, you just need to do some server admin
Not really a Manjaro question, but good luck! Here is a useful link to get the errors showing up - https://stackoverflow.com/questions/2687730/how-can-i-make-php-display-the-error-instead-of-giving-me-500-internal-server-er
