I am using Unity3D software and I want to printscreen but the shortcut isn’t working. But when I use the printscreen in other software like Dolphin, it works fine.
How can I fix this?
Maybe, assign some other shortcut for printscreen, or, use another program like Flameshot with a custom shortcut.
[Just a suggestion, though, sine I haven’t personally used Unity3D]
this is not the answer I’m expecting but thank you for this software. I’ll definitely try this. I’m using spectacle now.
