settings in the printer - print options dialog is not saved (paper size, print 2-sided).
After installation, I tried to set the paper size and two-sided printing in the basic settings. The options can be selected. But after clicking “Apply” the settings are gone again.
How can I fix this?
Have you tried in a browser:
http://localhost:631/admin/
choose Manage Printers- click on your printer-Administration-Set Default Options- make your changes and then click on “Set Default Options” radio button on bottom?
Hello
Thanks for the tip. Interestingly, it works like this. But I think that especially for a beginner like me, it is important that the Gui functions to set up a printer cleanly grip. It is difficult to understand why this should work via the browser but not via the printer configuration.
Thanks anyway for the valuable advice
Apropo: Is there any option, to send this entry to the buglist? I think it has to be fixed.
