Printer not working
#1
I was hoping that cups would work again after today’s update, but still the same error.
Can anyone help me find the error in my system that prevents the printer to work properly?
 [18/Feb/2018:12:54:37 +0100] [Client 16] New state is HTTP_STATE_WAITING
D [18/Feb/2018:12:54:37 +0100] [Client 16] Waiting for request.
D [18/Feb/2018:12:54:37 +0100] cupsdSetBusyState: newbusy="Dirty files", busy="Active clients and dirty files"
D [18/Feb/2018:12:54:37 +0100] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Dirty files"
D [18/Feb/2018:12:54:37 +0100] [Client 17] Server address is "/run/cups/cups.sock".
D [18/Feb/2018:12:54:37 +0100] [Client 17] Accepted from localhost (Domain)
D [18/Feb/2018:12:54:37 +0100] [Client 17] Waiting for request.
D [18/Feb/2018:12:54:37 +0100] [Client 17] GET /printers/Brother_QL-570.ppd HTTP/1.1
D [18/Feb/2018:12:54:37 +0100] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files"
D [18/Feb/2018:12:54:37 +0100] [Client 17] Read: status=200, state=3
D [18/Feb/2018:12:54:37 +0100] [Client 17] No authentication data provided.
D [18/Feb/2018:12:54:37 +0100] [Client 17] Processing GET /printers/Brother_QL-570.ppd
D [18/Feb/2018:12:54:37 +0100] [Client 17] filename="/etc/cups/ppd/Brother_QL-570.ppd", type=application/vnd.cups-ppd
D [18/Feb/2018:12:54:37 +0100] [Client 17] cupsdSendHeader: code=200, type="application/vnd.cups-ppd", auth_type=0
D [18/Feb/2018:12:54:37 +0100] [Client 17] Sending file.
D [18/Feb/2018:12:54:37 +0100] [Client 17] con->http=0x55997631a880
In one of the lines above says “No authentication data provided”. Could be a permissions problem? I have applied this command many times with no error shown: sudo chgrp -R cups /etc/cups
Any suggestion?
[Stable Update] 2018-02-03 - Kernels, LibreOffice, Browsers, Thunderbird, PHP, Haskell
#2
Have you tried the drivers from the AUR? Worked for my MFC-J4625dw.
#3
Hi, I did a system upgrade two weeks ago and reboot the system I found that I lost connection with the network shared printers, where correctly printing last Friday.
Then, I run
sudo systemctl status org.cups.cupsd.service
org.cups.cupsd.service - CUPS Scheduler
   Loaded: loaded (/usr/lib/systemd/system/org.cups.cupsd.service; enabled; vendor preset: disabled)
   Active: active (running) since Mon 2018-02-19 11:00:26 -03; 6h ago
     Docs: man:cupsd(8)
 Main PID: 257 (cupsd)
   Status: "Scheduler is running..."
    Tasks: 3 (limit: 3893)
   CGroup: /system.slice/org.cups.cupsd.service
           ├─ 257 /usr/bin/cupsd -l
           ├─1067 /usr/lib/cups/notifier/dbus dbus://
           └─5238 smb://192.168.2.95/HP1006 25 jochoa Test Page 1 job-uuid=urn:uuid:571b3250-4cc7-3717-734c-3bda1482f571 job-origin
feb 19 11:00:20 pcjochoa systemd[1]: Starting CUPS Scheduler...
feb 19 11:00:26 pcjochoa systemd[1]: Started CUPS Scheduler.
feb 19 12:08:20 pcjochoa foo2xqx-wrapper[989]: gs -sPAPERSIZE=a4 -g9920x7016 -r1200x600 -sDEVICE=pbmraw -dCOLORSCREEN -dMaxBitmap=5
feb 19 12:16:57 pcjochoa foo2zjs-wrapper[1225]: gs -sPAPERSIZE=a4 -g9920x7016 -r1200x600 -sDEVICE=pbmraw -dCOLORSCREEN -dMaxBitmap=
feb 19 12:16:57 pcjochoa foo2zjs-wrapper[1226]: foo2zjs -r1200x600 -g9920x7016 -p9 -m1 -n1 -d1 -s7 -z1  -u 192x96 -l 192x96 -L 0  -
feb 19 17:52:16 pcjochoa foo2xqx-wrapper[5188]: gs -sPAPERSIZE=a4 -g9920x7016 -r1200x600 -sDEVICE=pbmraw -dCOLORSCREEN -dMaxBitmap=
I looks okay but when I send jobs they are pending.
The message is Idle - Unable to connect to CIFS host, will retry in 60 seconds…
I also tried to add another network printer through windows samba share I cannot reach the printer. I restart cups service and nothing happened.
I also found in the journalctl this:
feb 19 09:26:13 pcjochoa systemd[1]: Started Samba NetBIOS name server.
feb 19 09:26:13 pcjochoa systemd[1]: Starting Samba SMB/CIFS server...
feb 19 09:26:13 pcjochoa nmbd[291]: [2018/02/19 09:26:13.012762,  0] ../lib/util/become_daemon.c:135(daemon_status)
feb 19 09:26:13 pcjochoa sddm[286]: Initializing...
feb 19 09:26:13 pcjochoa nmbd[291]:   STATUS=daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...NOTE: N
feb 19 09:26:13 pcjochoa sddm[286]: Logind interface found
feb 19 09:26:15 pcjochoa smbd[302]: [2018/02/19 09:26:15.932927,  0] ../lib/util/become_daemon.c:124(daemon_ready)
feb 19 09:26:13 pcjochoa sddm[286]: Starting...
feb 19 09:26:15 pcjochoa smbd[302]:   STATUS=daemon 'smbd' finished starting up and ready to serve connections
feb 19 09:26:13 pcjochoa sddm[286]: Adding new display on vt 1 ...
and this
feb 19 09:26:27 pcjochoa sddm-greeter[466]: Message received from daemon: HostName
feb 19 09:26:28 pcjochoa nmbd[291]: [2018/02/19 09:26:28.024248,  0] ../lib/util/become_daemon.c:124(daemon_ready)
feb 19 09:26:28 pcjochoa nmbd[291]:   STATUS=daemon 'nmbd' finished starting up and ready to serve connections
feb 19 09:26:32 pcjochoa mandb[263]: Purging old database entries in /usr/share/man...
feb 19 10:59:12 pcjochoa ksmserver[630]: ksmserver: KSMServer::completeKilling clients.count()= 5
feb 19 10:59:24 pcjochoa nmbd[291]: [2018/02/19 10:59:24.602497,  0] ../source3/nmbd/nmbd.c:58(terminate)
feb 19 10:59:12 pcjochoa kwin_x11[635]: QXcbConnection: XCB error: 3 (BadWindow), sequence: 32352, resource id: 56623108, major code: 18 (Chan
feb 19 10:59:24 pcjochoa nmbd[291]:   Got SIGTERM: going down...
eb 19 11:00:23 pcjochoa ModemManager[231]: <info>  Couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.0/0000:03:00.0': not
feb 19 11:00:20 pcjochoa systemd[1]: Starting Samba NetBIOS name server...
feb 19 11:00:24 pcjochoa avahi-daemon[230]: Joining mDNS multicast group on interface enp3s0.IPv4 with address 192.168.2.102.
feb 19 11:00:20 pcjochoa systemd[1]: Starting Permit User Sessions...
feb 19 11:00:24 pcjochoa avahi-daemon[230]: New relevant interface enp3s0.IPv4 for mDNS.
feb 19 11:00:20 pcjochoa systemd[1]: Starting Network Manager Script Dispatcher Service...
feb 19 11:00:24 pcjochoa avahi-daemon[230]: Registering new address record for 192.168.2.102 on enp3s0.IPv4.
feb 19 11:00:20 pcjochoa systemd[1]: Started Permit User Sessions.
feb 19 11:00:24 pcjochoa nmbd[273]: [2018/02/19 11:00:24.450993,  0] ../lib/util/become_daemon.c:124(daemon_ready)
feb 19 11:00:20 pcjochoa systemd[1]: Started Simple Desktop Display Manager.
feb 19 11:00:24 pcjochoa nmbd[273]:   STATUS=daemon 'nmbd' finished starting up and ready to serve connections
feb 19 11:02:43 pcjochoa nmbd[273]: [2018/02/19 11:02:43.312601,  0] ../source3/nmbd/nmbd_become_lmb.c:418(become_local_master_fail2)
feb 19 11:02:43 pcjochoa nmbd[273]:   become_local_master_fail2: failed to register name WORKGROUP<1d> on subnet 192.168.2.102. Failed to beco
feb 19 11:02:43 pcjochoa nmbd[273]: [2018/02/19 11:02:43.312896,  0] ../source3/nmbd/nmbd_namelistdb.c:320(standard_fail_register)
feb 19 11:02:43 pcjochoa nmbd[273]:   standard_fail_register: Failed to register/refresh name WORKGROUP<1d> on subnet 192.168.2.102
And this is the time when CUPS changed the attributes on the network printers
feb 19 12:09:17 pcjochoa plasmashell[618]: trying to show an empty dialog
feb 19 12:09:19 pcjochoa plasmashell[618]: libkcups: Get-Printer-Attributes last error: 0 successful-ok
feb 19 12:09:19 pcjochoa plasmashell[618]: libkcups: 4 "HP-LaserJet-P1006"
feb 19 12:09:19 pcjochoa plasmashell[618]: libkcups: "Printer \"HP-LaserJet-P1006\" state changed." "ipp://pcjochoa/printers/HP-LaserJet-P1006
feb 19 12:09:19 pcjochoa plasmashell[618]: libkcups: Get-Jobs last error: 0 successful-ok
feb 19 12:09:19 pcjochoa plasmashell[618]: libkcups: 1
lines 6610-6632
But I discovered a minutes ago in the forum that
Processing - Tree connect failed (NT_STATUS_ACCESS_DENIED)
can be reparied with
sudo systemctl status nmbd.service
● nmbd.service - Samba NetBIOS name server
   Loaded: loaded (/usr/lib/systemd/system/nmbd.service; enabled; vendor preset: disabled)
   Active: active (running) since Wed 2018-02-21 09:02:35 -03; 6h ago
  Process: 265 ExecStart=/usr/bin/nmbd -D (code=exited, status=0/SUCCESS)
 Main PID: 287 (nmbd)
    Tasks: 1 (limit: 3894)
   CGroup: /system.slice/nmbd.service
           └─287 /usr/bin/nmbd -D
feb 21 09:02:31 pcjochoa systemd[1]: Starting Samba NetBIOS name server...
feb 21 09:02:35 pcjochoa systemd[1]: Started Samba NetBIOS name server.
feb 21 09:02:35 pcjochoa nmbd[287]: [2018/02/21 09:02:35.825113,  0] ../lib/util/become_daemon.c:135(daemon_status)
feb 21 09:02:35 pcjochoa nmbd[287]:   STATUS=daemon 'nmbd' : No local IPv4 non-loopback interfaces available, waiting for interface ...NOTE: N
feb 21 09:02:40 pcjochoa nmbd[287]: [2018/02/21 09:02:40.826302,  0] ../lib/util/become_daemon.c:124(daemon_ready)
feb 21 09:02:40 pcjochoa nmbd[287]:   STATUS=daemon 'nmbd' finished starting up and ready to serve connections
I print a Test page and a page from an file I have opened and the problem was solved.
Could yo try this and confirm this procedure?
Best regards,
#4
