Printer not found
I have several computers and the printer function has always been included in the standard ISO, which automatically runs the printer.
I installed Plasma KDE Manjaro 26.1 minimal a few days ago, and didn’t realize the printer function was not included in the ISO. Therefore I looked up what I have on other computers and added the following packages:
print-manager, print settings, cups, cups filters.
My printer is is a Dell 235dn MPF laser printer, and all my 5 other computers picks up the printer automatically without any manual intervention. I should have used the full version instead!
What else am I missing?
manjaro-printer
is a metapackage that will pull several dependencies, in case you forgot some. Is it a network printer or a usb one?
It still says "printing service is not available. It’s a network printer, with an ip address.
I have a hp printer but it might work for your Dell 235dn MPF
sudo usermod -a -G lp,scanner $USER
pamac install --no-confirm manjaro-printer avahi
sudo gpasswd -a $USER sys
sudo systemctl enable --now cups.service;sudo systemctl enable --now cups.socket;sudo systemctl enable --now cups.path;sudo systemctl enable --now avahi-daemon.service
http://localhost:631
manjaro wiki printing
Thank you all for your help! I was able to make work with the help of chatgpt running the following script:
driverless ipp://192.168.1.50:631/ipp/print
sudo pacman -S cups-pk-helper system-config-printer avahi
sudo systemctl enable --now cups.service cups.socket cups.path
systemctl status cups --no-pager
pacman -Qs ‘cups|printer|avahi’
Avahi was probably your problem. That is why i asked if it a network printer.
Which is a bit strange since it is a dependency of cups. But maybe the service was not running, if you did not restart, and enable --now started it. I think the solution mark goes to Stormchip.
I am glad you got it working. When you choose to install the “minimal” version, lots of basic software tends to be absent.
