installed all the filters from AUR. But now I have the same problem like before. Also again re-installed the printer. Printer is displayed, but printing is not working CUPS states: “Der Drucker existiert nicht oder ist zur Zeit nicht verfügbar.” Printer not existing or not available"
Now I installed and started Avahi ( mdns_minimal were like in the tutorial), disabled systemd-resolved, also disabled the firewall
Then I have deleted the printer and re-installed it via cups-web-interface.
(i am not a linux-computer guy and felt like a hacker)
same problem.
The printer works from other (windows, Android) Devices as a network printer … I have an old lubuntu netbook and will try to install it from there, maybe it can help? … getting frustrated … thinking about not re-using this former win-notebook
hi. was also not able to install it in my lubuntu machine. looks like the drivers are found and properly installed, but the printer is then not found in the network, thats why it is stuck. I unswuccsellfully tried to find out the ip of the printer to ping it… is this idea realistic?
ok, the problem is, that the printers hostname is not resolved to the ip of the printer and thats why the printer is not responding. now i must only change this. please help:
I gave to the printer a static IP-Adress. Removed the installed printer from manjaro, installed again: Now it found 3 different network printer from the same type. I have choosen the one with the static IP-Adress.
