Hi guys,
I have used Manjaro 3 years old and as everything was configured and working I didn’t update the system.
However, I had to reinstall system.
After the new fresh install of Manjaro, I have configured my HP printer/scanner and it works, but I’m confused that I don’t see “Print Settings” in XFCE neither a print icon in panel bottom/right?
Anyone knows why is that?
Thanks
Hello @mladen.adamovic
Do you mean this package?
pamac install system-config-printer
It is a optional dependency of:
$ LANG=C pamac info manjaro-printer
Version : 20200215-2
Description : Manjaro Printer support (Meta-PKG)
URL : https://gitlab.manjaro.org/packages/extra/manjaro-printer
Licenses : GPL
Repository : extra
Installed Size : 792 bytes
Depends On : cups cups-pdf cups-pk-helper ghostscript gsfonts gutenprint hplip foomatic-db foomatic-db-gutenprint-ppds python-gobject python-pyqt5
python-pysmbc python-reportlab splix colord-sane
Optional Dependencies : system-config-printer: A gtk cups printer configuration tool and status applet [Installed]
print-manager: A kde tool for managing print jobs and printers
xsane: gtk2 frontend for scanner
simple-scan: gtk3 frontend for scanner
skanlite: Image Scanning Application for KDE
Packager : Bernhard Landauer <oberon@manjaro.org>
Build Date : 15.02.2020
Signatures : Yes
I’ve just installed a fresh 21.1.1 and I noted that system-config-printer
is not installed by default (manjaro-printer
is installed, but to be honest I don’t understand how to launch that, I guess it’s just a metapackage). Without system-config-printer
printers are not installed by default (e.g., just connect a USB printer or connect to a network where a printer is available), moreover, using the standard Gnome Printers settings dialog always fails to add a new printer manually…
