Prevent to change mirrorlist
Hi.
I have a problem with make /etc/pacman.d/mirrorlist file pernamemt. Some process change it after some days, and I dont have idea which one can modify this file.
Can someone help me ?
Thanks.
This would be the pamac-mirrorlist timer.
sudo systemctl mask pamac-mirrorlist.timer
Another way is to create a custom mirror pool with only one mirror
sudo pacman-mirrors --continent -i
I have my own local weekly repo snapshot for updates.
so I masked this pamac-mirrorlist.timer so I hope it fix it :slight_smile:
Many thanks.
Just watch out for pamac updates - it may reenable the timer.
If you want to be sure nothing changes the mirrorlist - create a custom-mirrors.json with your own mirror.
$ cat /var/lib/pacman-mirrors/custom-mirrors.json
[{"country": "your_country", "protocols": ["http"], "url": "http://local.server/"}]
There is another low-level thing you can do
undocumented
:exclamation: Only do this if you understand the consequences.
:exclamation: These mods in combo are effectively blocking the Manjaro mirror pool.
:exclamation: Using these mods implies you are a power user or system admin
:exclamation: By using these mods you agree that your system is unsupported
:exclamation: YOU AGREE - THIS IS YOUR RESPONSIBILITY
:exclamation: NEVER CREATE TOPICS FOR A SYSTEM MODDED THIS WAY
  1. Modify pacman-mirrors script source
    sudo sed -i 's/^URL_STATUS_JSON.*/URL_STATUS_JSON=""/g' /usr/lib/python3.9/site-packages/pacman_mirrors/config/configuration.py
  2. Remove python cache files from pacman_mirrors package
    $ sudo find /usr/lib/python3.9/site-packages/pacman_mirrors -type f -name '*.pyc' -exec rm {} +
  3. Modify /usr/share/pacman-mirrors/mirrors.json to contain your one and only mirror
    [{"country": "your_country", "protocols": ["http,https"], "url": "http://local.server/"}]
  4. Edit pacman.conf and add pacman-mirrors to the ignore list
    IgnorePkg   = pacman-mirrors
pacman-mirrors will now fake all mirror operations and fake the status of your mirrorlist. Nothing changes and you won’t have to rely on the masking of pamac-mirrorlist.timer.
This effectively block the Manjaro mirror pool - of course you can use any official mirror as the only mirror as well - in which case the mirror will never - ever change.
Many thaks for detailed solutions.
Im impressed with Majaro forum quality. For me is far ahead before Opensuse or Arch.
