Random stuttering on video-intel-nvidia-prime
Every once and a while the entire screen freezes for a few seconds, accompanied with a two core spike in CPU usage. this only occurs with the integrated display and when not connected to an external display. The stuttering can occur even when no programs are open.
output of:
inxi --admin --verbosity=7 --filter --width
  Kernel: 6.3.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
    root=UUID=1218efae-cd90-4784-902e-eeb8d09fb2f3 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Micro-Star product: GF65 Thin 9SE v: REV:1.0
  Mobo: Micro-Star model: MS-16W1 v: REV:1.0 serial: <superuser required>
    UEFI: American Megatrends v: E16W1IMS.10C date: 10/21/2021
  ID-1: BAT1 charge: 45.5 Wh (97.8%) condition: 46.5/51.3 Wh (90.6%)
    volts: 12.8 min: 11.4 model: MSI Corp. MS-16W1 type: Li-ion serial: N/A
    status: not charging
  System RAM: available: 31.19 GiB used: 4.19 GiB (13.4%)
  Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
    L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 3 MiB desc: 12x256 KiB
    L3: 144 MiB desc: 12x12 MiB
  Speed (MHz): avg: 1988 high: 2002 min/max: 800/4500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1863 2: 2000 3: 2000
    4: 2000 5: 2000 6: 2000 7: 2000 8: 2000 9: 2002 10: 2000 11: 2002 12: 2000
    bogomips: 62431
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
    driver: nvidia v: 530.41.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
    status: current (as of 2023-05) arch: Turing code: TUxxx
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f11
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
    gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
    s-diag: 581mm (22.86")
  Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
    hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics 630 (CFL
    GT2) direct-render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9
    class-ID: 0403
  API: ALSA v: k6.3.0-1-MANJARO status: kernel-api with: aoss
  Server-1: EsounD v: 0.2.41 status: off tools: esdcat,esdctl,esddsp
  Server-3: PipeWire v: 0.3.70 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: Micro-Star MSI driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
  IF: enp4s0 state: down mac: <filter>
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3
  Report: hciconfig ID: hci0 rfk-id: 8 state: down
    bt-service: enabled,running rfk-block: hardware: no software: yes
    address: <filter>
  Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
    link-mode: peripheral accept
  Local Storage: total: 1.84 TiB used: 142.7 GiB (7.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Sabrent model: Rocket Q
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.1 temp: 25.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Sabrent model: N/A
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT343.4 temp: 33.9 C
    scheme: GPT
  ID-1: / raw-size: 476.93 GiB size: 468.38 GiB (98.21%)
    used: 142.65 GiB (30.5%) fs: ext4 dev: /dev/nvme1n1p1 maj-min: 259:1
    label: N/A uuid: 1218efae-cd90-4784-902e-eeb8d09fb2f3
  ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
    used: 50.7 MiB (17.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
    label: SYSTEM uuid: D824-7886
  ID-1: /dev/nvme0n1p2 maj-min: 259:5 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:6 size: 910.1 GiB fs: ntfs label: Windows
    uuid: 2E58250F5824D6FD
  ID-3: /dev/nvme0n1p4 maj-min: 259:7 size: 900 MiB fs: ntfs
    label: WinRE tools uuid: 6CC625A2C6256D90
  ID-4: /dev/nvme0n1p5 maj-min: 259:8 size: 20.12 GiB fs: ntfs
    label: BIOS_RVY uuid: EE9A27C59A2788E3
  ID-5: /dev/nvme1n1p2 maj-min: 259:2 size: 476.93 GiB fs: exfat label: Game
    uuid: A661-B716
  Device-1: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  System Temperatures: cpu: 67.0 C pch: 69.0 C mobo: N/A
  Processes: 291 Uptime: 2d 14h 28m wakeups: 51249 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: 5618 pm: pacman pkgs: 5611 libs: 519 tools: pamac,yay pm: rpm
  pkgs: 0 pm: flatpak pkgs: 7 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.27
Reading related questions on here, it appears that my
/etc/X11/mhwd.d/nvidia.conf
is important, however, it contains only:
## Generated by mhwd - Manjaro Hardware Detection
I have no /etc/X11/xorg.conf, but i do have a 0B file at /etc/X11/xorg.conf.nvidia-xconfig-original
the issue persists across linux419, linux61, linux62, and linux63
It might be swapping.
Or maybe baloo indexing your files.
Added 3G swap file, and killed all baloo processes, stuttering still present
output of sudo inxi --admin --verbosity=7 --filter --width
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
    serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Micro-Star model: MS-16W1 v: REV:1.0 serial: <filter>
  ID-1: BAT1 charge: 45.0 Wh (96.8%) condition: 46.5/51.3 Wh (90.6%)
  System RAM: available: 31.19 GiB used: 3.43 GiB (11.0%)
  Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
    note: est.
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2667 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits): data: 64
    total: 64 manufacturer: Patriot part-no: PSD416G26662S serial: N/A
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
  Info: model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64
    type: MT MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
    process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
    microcode: 0xF0
  Speed (MHz): avg: 800 min/max: 800/4500 base/boost: 2475/8300 scaling:
    driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
    cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800
    10: 800 11: 800 12: 800 bogomips: 62431
    vulnerable
    class-ID: 0300
    process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
    bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
  Server-3: PipeWire v: 0.3.70 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cli
  Server-4: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Report: hciconfig ID: hci0 rfk-id: 10 state: down
    address: <filter>
  Local Storage: total: 1.84 TiB used: 145.73 GiB (7.7%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT30Q.1 temp: 28.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 308d 12h cycles: 4,801
    read-units: 52,337,523 [26.7 TB] written-units: 57,960,435 [29.6 TB]
    lanes: 4 tech: SSD serial: <filter> fw-rev: RKT343.4 temp: 35.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 48d 3h cycles: 1,009
    read-units: 2,115,573 [1.08 TB] written-units: 5,436,959 [2.78 TB]
    used: 145.68 GiB (31.1%) fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p1
    maj-min: 259:1 label: N/A uuid: 1218efae-cd90-4784-902e-eeb8d09fb2f3
    used: 50.7 MiB (17.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:4 label: SYSTEM uuid: D824-7886
  ID-1: swap-1 type: file size: 3.02 GiB used: 0 KiB (0.0%) priority: -2
    file: /swap
  ID-1: /dev/nvme0n1p2 maj-min: 259:5 size: 128 MiB fs: N/A label: N/A
    uuid: N/A
    uuid: A661-B716
  System Temperatures: cpu: 63.0 C pch: 72.0 C mobo: N/A
  Processes: 291 Uptime: 2d 15h 53m wakeups: 26924 Init: systemd v: 252
  Packages: pm: pacman pkgs: 5612 libs: 519 tools: pamac,yay pm: rpm pkgs: 0
  pm: flatpak pkgs: 0 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
Additional, i notice a mention of two displays, Screen-1 and Monitor-1, and feel i should clarify that i only have one display attached at the moment, that being the integrated one.
In Ksystemlog, noticing repeated input event losses:
Information [ 26621.490] (II) event20 - CUST0001:00 04F3:30AA Touchpad: SYN_DROPPED event - some input events have been lost.
also happens with external mouse:
Information [ 26785.415] (II) event5 - Razer Razer DeathAdder V2 Pro: SYN_DROPPED event - some input events have been lost.
Perhaps this is not a graphics issue?
during freeze anything moving freezes as well.
tested with donut.c in Konsole
Maybe it might be like this??
I cannot use nvidia-drm.modeset=1 because the 2060 cannot render directly to my integrated display, so on boot i get black screen
