Huh, I thought it was called that but then when I got the Manjaro wiki link to post it says downgrade… ![]()
Try instead the newly released 6.6 kernel.
I don’t think this will necessarily solve the issue, however, it might help to further define the cause. Errors may still exist, but might appear differently.
Also, please provide output of:
inxi -v7azy
Thanks, though I would rather stick with the LTS than risk knocking this box out of service. The nuisance is only minor so I will buckle up and wait for the fix. Have a laptop backup and mint on another box. My main box is old but usually stable,
the inxi -v7azy output you requested just for your interest
inxi -v7azy ✔ base
Kernel: 6.1.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0aa1d17b-7f6e-49a4-bc8a-1ccbf9f37832 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: F2A85-V PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 6504
date: 11/27/2014
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter> charge: 65%
rechargeable: yes status: discharging
System RAM: total: 16 GiB note: est. available: 14.84 GiB
used: 3.26 GiB (22.0%)
Info: model: AMD A10-6800K APU with Radeon HD Graphics bits: 64 type: MT MCP
arch: Piledriver level: v2 built: 2012-13 process: GF 32nm family: 0x15 (21)
model-id: 0x13 (19) stepping: 1 microcode: 0x6001119
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 192 KiB
desc: d-4x16 KiB; i-2x64 KiB L2: 4 MiB desc: 2x2 MiB
Speed (MHz): avg: 2555 high: 4181 min/max: 2000/4100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2000 2: 4181
3: 2039 4: 2000 bogomips: 33465
Flags: 3dnowprefetch abm aes aperfmperf apic arat avx bmi1 clflush cmov
cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists
extapic extd_apicid f16c flushbyasid fma fma4 fpu fxsr fxsr_opt ht
hw_pstate ibs lahf_lm lbrv lm lwp mca mce misalignsse mmx mmxext monitor
msr mtrr nodeid_msr nonstop_tsc nopl npt nrip_save nx osvw pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdtscp rep_good sep skinit ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 svm svm_lock syscall tbm tce topoext tsc tsc_scale vmcb_clean
vme vmmcall wdt xop xsave
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: AMD Richland [Radeon HD 8670D] vendor: ASUSTeK driver: radeon
v: kernel alternate: amdgpu arch: TeraScale-3 code: Northern Islands
process: TSMC 32nm built: 2010-13 ports: active: none off: VGA-1
empty: DP-1,HDMI-A-1 bus-ID: 00:01.0 chip-ID: 1002:990c class-ID: 0300
Device-2: AMD Turks XT [Radeon HD 6670/7670] vendor: ASUSTeK driver: radeon
v: kernel alternate: amdgpu arch: TeraScale-2 code: Evergreen
process: TSMC 32-40nm built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: HDMI-A-2 empty: DVI-D-1,VGA-2 bus-ID: 01:00.0
chip-ID: 1002:6758 class-ID: 0300 temp: 37.0 C
Device-3: Huawei [] driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 12d1:4321
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
loaded: radeon unloaded: modesetting alternate: fbdev,vesa dri: r600
gpu: radeon display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: HDMI-A-2 mapped: HDMI-1 pos: primary model: Philips PHL 243V7
serial: <filter> built: 2020 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: VGA-1 mapped: VGA-1-0 note: disabled model: Philips PHL 243V7
serial: <filter> built: 2020 res: 1920x1080 dpi: 93 gamma: 1.2
API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
drv: r600 device: 2 drv: swrast gbm: drv: kms_swrast surfaceless: drv: r600
x11: drv: r600 inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 23.1.9-manjaro1.1 glx-v: 1.4
direct-render: yes renderer: AMD TURKS (DRM 2.50.0 / 6.1.60-1-MANJARO LLVM
16.0.6) device-ID: 1002:6758 memory: 1.95 GiB unified: no
Device-1: AMD Trinity HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
Device-3: AMD Turks HDMI Audio [Radeon HD 6500/6600 / 6700M Series]
vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa90 class-ID: 0403
Device-4: Huawei [] driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
Device-5: GN Netcom [] driver: jabra,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 0b0e:0301
class-ID: 0300 serial: <filter>
API: ALSA v: k6.1.60-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.83 status: off with: pipewire-media-session
status: active tools: pw-cli
Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v6: <filter> type: deprecated dynamic noprefixroute scope: global
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:4 chip-ID: 8087:07dc
class-ID: e001
Local Storage: total: 566.38 GiB used: 197.08 GiB (34.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 66B5 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SDSSDP128G
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37240G
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 197.08 GiB (90.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 0aa1d17b-7f6e-49a4-bc8a-1ccbf9f37832
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 44DB-0EA5
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 119.24 GiB fs: exfat label: SPARE
uuid: 91B2-2E16
ID-2: /dev/sdc1 maj-min: 8:33 size: 223.57 GiB fs: btrfs label: Backup
uuid: 449d017a-7d2b-4dc5-b5b8-ea2dbd233efd
Hub-1: 1-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-2: 2-0:1 info: full speed or root hub ports: 5 rev: 2.0
Hub-3: 3-0:1 info: full speed or root hub ports: 5 rev: 1.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 1d6b:0001
Device-1: 3-2:2 info: Dell KB212-B Quiet Key Keyboard type: keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 413c:2107 class-ID: 0301
Device-2: 3-4:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-3: 3-5:4 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
Hub-4: 4-0:1 info: full speed or root hub ports: 5 rev: 1.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 5-1:2 info: Huawei [] type: video,audio
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
chip-ID: 12d1:4321 class-ID: 0102 serial: <filter>
Device-2: 5-2:3 info: GN Netcom [] type: audio,HID
driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
chip-ID: 0b0e:0301 class-ID: 0300 serial: <filter>
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-8: 8-0:1 info: super-speed hub ports: 2 rev: 3.0
Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-10: 10-0:1 info: super-speed hub ports: 2 rev: 3.0
System Temperatures: cpu: 13.4 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: radeon temp: 37.0 C device: radeon temp: 5.0 C
Processes: 219 Uptime: 37m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 alt: 12 clang: 16.0.6 Packages: 1571
pm: pacman pkgs: 1523 libs: 410 tools: pamac pm: flatpak pkgs: 48 Shell: Zsh
v: 5.9 default: Bash v: 5.2.15 running-in: yakuake inxi: 3.3.31
Has anybody a clue why this is not needed in Arch, at least on my parallel Arch installation there are no issues at all with the newer versions. ![]()
You could do that.
The cause is likely due to this KDE issue Powerdevil fails to start with ddcutil-2.0.0, spikes cpu usage to max every few seconds.
According to a comment in that report, ddcutil-1.4.1-1 and powerdevil-5.27.9-1 are the last known working combination.
So far, the only workaround has been to downgrade the two players ddcutil and powerdevil. See Downgrading Packages for more information.
There is also a convenient Manjaro-Downgrade script you could use:
pamac install manjaro-downgrade
I think its dependent on a number of other things.
I dont notice it either - but I use a custom kernel.
I also dont use power-profiles-daemon … maybe related to that?
Theres a KDE bug tracker going that might end up with more info.
Theres some ideas there:
The original report on the KDE bug tracker is from an Arch Linux user.
I don’t have any issue myself, but I also don’t have either a DDC capable monitor or power-profiles-daemon installed.
EDIT In the interest of science I installed power-profiles-daemon. Still no issue. So I suspect that the problem only happens if you have a DDC capable monitor (try ddcutil detect).
Going through the downgrade today and noticed that powerdevil-5.27.9-1 is not available on my system
5.27.9.r3021.gc299adfc located in remote and 5.27.9 in /var/cache/pacman/pkg
Where can I download 5.27.9.1? As Choosing 5.27.8 results in other issues :
Sudo downgrade powerdevil 1 ✘ 52s base
loading packages...
warning: downgrading package powerdevil (5.27.9-2 => 5.27.8.r2967.g4a72772a-1)
resolving dependencies...
warning: cannot resolve "bluez-qt", a dependency of "powerdevil"
warning: cannot resolve "networkmanager-qt", a dependency of "powerdevil"
:: The following package cannot be upgraded due to unresolvable dependencies:
powerdevil
:: Do you want to skip the above package for this upgrade? [y/N] N
:: unable to satisfy dependency 'bluez-qt' required by powerdevil
:: unable to satisfy dependency 'networkmanager-qt' required by powerdevil
Update: Rebooted fine & powerdevil is only consuming 1% of cpu time, the system stable and the network seems fine too. But Power management settings are still inaccessible. Thanks for all the help.
It is from the bug report thread. It was suggested that you use manjaro-downgrade
With that you don’t need to manually download it
With that you should have access to it via command line so logout and in tty:
sudo pacman -S manjaro-downgrade
#this remove the package "downgrade" for you also
sudo manjaro-downgrade powerdevil
#from there version .....9.1 should be offered, select that and confirm
reboot
EDIT
This was posted as a solution but I haven’t tried it
https://bugs.kde.org/show_bug.cgi?id=476375
[Altamush Nayyer Khan] in: 476375 – Powerdevil fails to start with ddcutil-2.0.0, spikes cpu usage to max every few seconds
For anyone who is still having issues with this, please read this post: [SOLVED] KDE plasma power management not working / starting / Applications & Desktop Environments / Arch Linux Forums
Although I released a solution, this one appears to be working better. Only the KDE devs can tell whether this solution or mine is safe or not for the people that are facing this issue. I hope this bug is pushed, and fixed quickly as some people that are using KDE might not even know why their system is hitching due to this.
You should edit the timeout after you have installed these latest versions of powerdevil & ddcutil, because the update resets it to 5s.
Hm, it is working fine as in you get screen brightness now that is working along Night Color.
For the 3 energy options Power Save / Balanced / Performance that do reappear too, the slider will not hold i. e. I don’t think it sets them while logged in. However drag that slider where you want it, maybe try a few times
then logout and login and the slider is set. Must be working that way, or how do you make sure the option is in fact in tact after the re-login?
If so, this is a workaround I can live with so a while, latest versions, 1 logo-logi required for changed things to come into effect.
No powerdevil cpu hassle or anything. Thanks for mentioning.
Still finding this issue today after the most recent Manjaro updates. The downgrade now throws dependency errors because of the renaming of KDE packages. I’m sure there’s a way to force it, but instead I tried this workaround:
https://bbs.archlinux.org/viewtopic.php?id=289979
Immediately after reboot, the problem is solved. I haven’t done any long-term testing though, as I just made the change 10 minutes ago.
And 5 days later?
Oh, sorry if I left you with the impression that I’d actually be doing that long-term testing. The only PC in my house that’s been affected so far is a rarely-used workshop PC. It spends most of its life turned off.
I can tell you though, after sitting a few hours it was still fine, and when I booted it up a couple of days later to check something it also was behaving itself. So as workarounds go this one seems safe.
Has this been fixed with the 2023-12-10 stable update?
EDIT: Is not fixed, I had to downgrade the ddcutil & powerdevil again.
Hint: if something isn’t mentioned in the respective Update announcement, then, it’s a fair guess that thing hasn’t been fixed.
Yeah, I’ve found the upstream bug report now so I’ll keep an eye on that.
It’s a fair question, since Powerdevil received an update. Will soon do the system update and post if it works without downgrading on either linux66, linux61 or linux515.
I haven’t tried if it’s kernel related yet.
Edit, so now I have. And it’s not kernel-related. Maybe their HDR thing?
Anyone affected having an HDR-capable display connected?
This worked for me as well, energy settings are back with these workarounds. I think this workaround should be implemented in the official package, if it takes weeks to get a proper fix in stable.
Here’s the latest on the bug… we’ve figured out how to get around it, but the next step seems like data collection so it can be fixed for real.
They said they fixed it, but it’s not (yet?) backported to 5.27.
It’s in Plasma 6 however. ![]()
It’s said to work with the complete list of affected monitors again, with current ddcutil 2.0. ![]()
(( There is however a new(?) issue with ddcutil 2.1 . ))
Unsure if we can mark this solved if it’s not backported, I’m on Stable so I don’t want to test.
