I wanted to ask if we could add an extra toggle to the GUI for the software installer “Add/Remove Software”
I recently found out you can have your flatpak applications stored in your home directory instead of your root folder. I have what I thought was a decently sized root partition at 150 gigs, but its being used by 20 gigs from just flatpak. If I had a way to make sure things were installed on my much larger home partition by just using Flatpaks built in switch “–user” instead of “–system” it would work correctly and not fill up my root partition with user apps.
Just an idea. Thoughts?
