Power-profiles-daemon not starting after latest stable update
I am having an issue where power-profiles-daemon is no longer starting via systemd after the latest stable updates. I confirmed that it was running prior to restarting after the update. I have tried uninstalling and reinstalling, and that didn’t help.
However, I also tried running sudo /usr/lib/power-profiles-daemon -vv which does work.
/usr/lib/systemd/system/power-profiles-daemon.service
[Unit]
Description=Power Profiles daemon
Conflicts=tuned.service tlp.service auto-cpufreq.service system76-power.service
After=multi-user.target display-manager.target
[Service]
Type=dbus
BusName=org.freedesktop.UPower.PowerProfiles
# To enable debugging add a -vv to the ExecStart line
ExecStart=/usr/lib/power-profiles-daemon -vv
Restart=on-failure
# This always corresponds to /var/lib/power-profiles-daemon
StateDirectory=power-profiles-daemon
# Lockdown
CapabilityBoundingSet=CAP_SYS_ADMIN
DevicePolicy=closed
IPAddressDeny=any
KeyringMode=private
LockPersonality=yes
MemoryDenyWriteExecute=yes
NoNewPrivileges=yes
PrivateDevices=yes
PrivateTmp=yes
PrivateNetwork=yes
PrivateUsers=yes
ProtectClock=yes
ProtectControlGroups=yes
ProtectHome=yes
ProtectHostname=yes
ProtectKernelLogs=yes
ProtectKernelModules=yes
ProtectProc=invisible
ProtectSystem=strict
RemoveIPC=yes
RestrictAddressFamilies=AF_UNIX AF_LOCAL AF_NETLINK
MemoryDenyWriteExecute=true
RestrictRealtime=true
RestrictNamespaces=yes
RestrictRealtime=yes
RestrictSUIDSGID=yes
SystemCallFilter=@system-service
SystemCallFilter=~@resources @privileged
SystemCallErrorNumber=EPERM
SystemCallArchitectures=native
[Install]
WantedBy=graphical.target
System info
KDE Plasma Version: 6.5.3
KDE Frameworks Version: 6.20.0
Qt Version: 6.10.1
Kernel Version: 6.12.61-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 12 × AMD Ryzen 5 7640U w/ Radeon 760M Graphics
Memory: 32 GiB of RAM (27.2 GiB usable)
Graphics Processor: AMD Radeon 760M Graphics
Manufacturer: Framework
Product Name: Laptop 13 (AMD Ryzen 7040Series)
System Version: A5
Please post the output of:
systemctl status power-profiles-daemon
Also, more detailed system information might be helpful:
inxi --filter --verbosity=8
inxi -zv8
○ power-profiles-daemon.service - Power Profiles daemon
     Loaded: loaded (/usr/lib/systemd/system/power-profiles-daemon.service; enabled; preset: disabled)
     Active: inactive (dead)
        Job: 172
> inxi -zv8         ✔
  Kernel: 6.12.61-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=74641cee-cd46-4f84-9c28-ebe57a92a537 rw quiet splash
    resume=UUID=076e59a2-2075-4c5a-ac4b-6a2cdede382c udev.log_priority=3
    amdgpu.sg_display=0
  Desktop: KDE Plasma v: 6.5.3 tk: Qt v: N/A info: frameworks v: 6.20.0
    wm: kwin_wayland vt: 3 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: Framework product: Laptop 13 (AMD Ryzen 7040Series)
    v: A5 serial: <superuser required>
  Mobo: Framework model: FRANMDCP05 v: A5 serial: <superuser required>
    part-nu: FRANDGCP05 uuid: <superuser required> Firmware: UEFI vendor: INSYDE
    v: 03.17 date: 11/14/2025
  ID-1: BAT1 charge: 44.7 Wh (90.1%) condition: 49.6/55 Wh (90.2%) volts: 16.9
    min: 15.4 model: NVT Framewo type: Li-ion serial: <filter> charging:
    status: not charging cycles: 209
  ID-2: hidpp_battery_0 charge: 52% condition: N/A volts: 3.82 min: N/A
    model: Logitech G Pro Wireless Gaming Mouse type: N/A serial: <filter>
    charging: status: discharging cycles: N/A
  System RAM: total: 32 GiB available: 27.21 GiB used: 4.58 GiB (16.8%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 5600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: CT16G56C46S5.M8G1 serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
    part-no: CT16G56C46S5.M8B2 serial: <filter>
  Info: model: AMD Ryzen 5 7640U w/ Radeon 760M Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x74 (116) stepping: 1 microcode: 0xA70410A
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB
    desc: 6x1024 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1397 min/max: 400/4971 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1397 2: 1397 3: 1397
    4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397
    bogomips: 83884
    apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
    avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero
    cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
    vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave
    xsavec xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Framework
    driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
    built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-10,DP-11 off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6,
    DP-7, DP-8, DP-9, Writeback-1 bus-ID: c1:00.0 chip-ID: 1002:15bf
    class-ID: 0300 temp: 52.0 C
    compositor: kwin_wayland driver: X: loaded: amdgpu
    unloaded: modesetting,radeon,vesa alternate: fbdev dri: radeonsi
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-10 model: Dell P2317H serial: <filter> built: 2017 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 96 gamma: 1.2 chroma: red:
    x: 0.651 y: 0.337 green: x: 0.318 y: 0.612 blue: x: 0.149 y: 0.063 white:
    x: 0.314 y: 0.329 size: 509x286mm (20.04x11.26") diag: 584mm (23")
    ratio: 16:9 modes: 1920x1080, 1600x900, 1280x1024, 1152x864, 1024x768,
    800x600, 640x480, 720x400
  Monitor-2: DP-11 model: AOC Q27G2SG4B+ serial: <filter> built: 2020 res:
    mode: 2560x1440 hz: 155 scale: 120% (1.2) to: 2133x1200 dpi: 109 gamma: 1.2
    chroma: red: x: 0.678 y: 0.310 green: x: 0.267 y: 0.663 blue: x: 0.149
    y: 0.051 white: x: 0.314 y: 0.329 size: 597x336mm (23.5x13.23")
    diag: 685mm (27") ratio: 16:9 modes: 2560x1440, 1920x1080, 1280x1440,
    1280x1024, 1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480,
    640x480, 720x400
  Monitor-3: eDP-1 model: BOE Display 0x0bca built: 2022 res: 2256x1504
    dpi: 201 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
    blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 285x190mm (11.22x7.48") diag: 343mm (13.5") ratio: 3:2
    modes: 2256x1504, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1280x720, 1024x768, 800x600, 640x480
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 760M Graphics (radeonsi
    phoenix LLVM 21.1.6 DRM 3.61 6.12.61-1-MANJARO) device-ID: 1002:15bf
    memory: 3.91 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.328 layers: 6 device: 0 type: integrated-gpu name: AMD
    Radeon 760M Graphics (RADV PHOENIX) driver: mesa radv v: 25.3.1-arch1.2
    device-ID: 1002:15bf surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    [Rembrandt/Strix] vendor: Framework driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: c1:00.1 chip-ID: 1002:1640
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Framework
    driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
    snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: c1:00.5 chip-ID: 1022:15e2 class-ID: 0480
    vendor: Framework driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: c1:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.61-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: off with: pipewire-media-session
    status: active tools: pw-cat,pw-cli
  Server-3: PulseAudio v: 17.0-93-gbe2efb status: active
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
  Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
    driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 01:00.0 chip-ID: 14c3:0616 class-ID: 0280
  IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:4 chip-ID: 0e8d:e616
  Report: bt-adapter ID: hci0 rfk-id: 0 state: down
    bt-service: enabled,running rfk-block: hardware: no software: yes
    address: <filter> status: discoverable: no active: no pairing: yes
  Local Storage: total: 953.87 GiB used: 466.91 GiB (48.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000S1024G
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.6 temp: 34.9 C
    scheme: GPT
  ID-1: / raw-size: 400 GiB size: 392.65 GiB (98.16%) used: 97.08 GiB (24.7%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: root
    uuid: 74641cee-cd46-4f84-9c28-ebe57a92a537
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
    used: 420 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3 label: BOOT
    uuid: 640F-1665
  ID-3: /home raw-size: 535.86 GiB size: 526.38 GiB (98.23%)
    used: 369.82 GiB (70.3%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
    label: home uuid: c2eec4ab-4137-45fc-9de1-6abd68780d3b
  ID-1: swap-1 type: partition size: 17 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p4 maj-min: 259:4 label: swap
    uuid: 076e59a2-2075-4c5a-ac4b-6a2cdede382c
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Fresco Logic USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d5c:5801
  Hub-3: 1-1.4:3 info: HP USB4206 Smart Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 03f0:2488
  Hub-4: 1-1.4.2:4 info: HP USB2734 ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 03f0:4488
  Hub-5: 1-1.4.2.2:6 info: Terminus Hub ports: 4 rev: 2.0
    chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-1.4.2.2.2:7 info: Keychron V3 type: keyboard,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0330 class-ID: 0300
  Device-2: 1-1.4.2.2.4:8 info: Logitech Lightspeed Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c539 class-ID: 0300
  Device-3: 1-1.4.3:5 info: HP HP Thunderbolt Dock G4 type: billboard,HID
    lanes: 1 mode: 1.1 chip-ID: 03f0:0488 class-ID: 0300 serial: <filter>
  Hub-6: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 2-1:2 info: Intel USB3.0 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 8087:0b40
  Hub-8: 2-1.4:3 info: HP USB7206 Smart Hub ports: 5 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 03f0:3488
  Hub-9: 2-1.4.2:4 info: HP USB5734 ports: 3 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 03f0:5488
  Hub-10: 3-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
  Device-1: 3-1:2 info: Framework HDMI Expansion Card type: billboard,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 32ac:0002 class-ID: 0300
    serial: <filter>
  Device-2: 3-4:3 info: Shenzhen Goodix Fingerprint USB Device
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    chip-ID: 27c6:609c class-ID: ef00 serial: <filter>
  Device-3: 3-5:4 info: MediaTek Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0e8d:e616 class-ID: e001 serial: <filter>
  Hub-11: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-12: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-13: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-14: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-15: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-16: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-17: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 62.4 C mobo: 47.8 C gpu: amdgpu temp: 52.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1994 libs: 501 tools: pamac pm: flatpak pkgs: 0
    1: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 342
  1: cpu: 7.0% command: firefox pid: 6916 mem: 470.1 MiB (1.6%)
  2: cpu: 6.4% command: firefox pid: 6660 mem: 737.6 MiB (2.6%)
  3: cpu: 3.9% command: firefox pid: 3620 mem: 999.9 MiB (3.5%)
  4: cpu: 2.8% command: firefox pid: 6294 mem: 309.8 MiB (1.1%)
  5: cpu: 1.8% command: @lymouthd pid: 318 mem: 99.5 MiB (0.3%)
  Memory top: 5 of 342
  1: mem: 999.9 MiB (3.5%) command: firefox pid: 3620 cpu: 3.9%
  2: mem: 737.6 MiB (2.6%) command: firefox pid: 6660 cpu: 6.4%
  3: mem: 553.1 MiB (1.9%) command: plasmashell pid: 2822 cpu: 0.4%
  4: mem: 530.6 MiB (1.9%) command: firefox pid: 4393 cpu: 0.7%
  5: mem: 470.1 MiB (1.6%) command: firefox pid: 6916 cpu: 7.0%
  Processes: 342 Power: uptime: 39m states: freeze,mem,disk suspend: s2idle
    image: 10.87 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 258
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.8 running-in: konsole inxi: 3.3.40
Try to start the daemon:
systemctl start power-profiles-daemon
Then check the status again:
If the daemon is now running, enable it with:
systemctl enable power-profiles-daemon
You can reboot and check status again, if you like, but the service should now be enabled on boot.
If you ever need to disable the service:
systemctl disable power-profiles-daemon
I have tried this numerous times (I probably should have mentioned that), and it just hangs and never starts, but also provides no log output, even with the -vv (verbose) flag.
I see from your inxi output that you’re using the Stable branch – There is a new Stable Update (today):
You might apply that, to see if it brings with it any joy.
If the issue still persists, by all means return to this topic with any updated detail. Your system information will of course need to be updated.
I installed those updates, and sadly no improvement. Still does not start via systemd.
The following might have no effect, but try:
systemctl stop power-profiles-daemon
Uninstall and Install power-profiles-daemon (not reinstall):
sudo pacman -Rns power-profiles-daemon
sudo pacman -S power-profiles-daemon
Then see if it starts:
If OK, enable it again:
Beyond this, perhaps others might have a thought or two.
Thanks for all the support so far, it has been appreciated!
Unfortunately it is still not starting, just hanging with no output.
I’ll chime in again if anything else comes to mind.
