I’m new to Manjaro and Xfce (just started using both in the last week) although not a newbie with Mint and Cinnamon.
I have a small problem in Xfce with the settings in Power Manager.:
Looking under the Display</.kbd> tab there are 2 settings that concern me:
- ‘Blank after’.
- ‘Put to sleep after’. . . .
If I enter ‘10 minutes’ for the former, then after that period of inactivity the screen blanks out, which is fine. However, if I enter say 15 minutes for ‘Sleep’ or any period for that matter, the computer never goes into Sleep.
In the end the only way I can get that to work correctly is to hit the ‘System’ tab and enter a period for ‘Suspend’ after inactivity. Then it works as required.
So what is the purpose of ‘Put To Sleep’ under the ‘Display’ tab?
