There’s something wrong I think. Manjaro Hello does not run, though I uninstalled and re installed it several times.
Flatpak had stopped working but started working again after uninstall/reinstall.
Likewise for YAY. And Opera Browser. Started working after uninstall and reinstall using the GUI package manager built into Manjaro KDE.
This is the message generated each time I try to install Manjaro Hello, and Manjaro Hello does not work —>
Preparing...
Resolving dependencies...
Checking inter-conflicts...
Download of lsb-release (2.0.r53.a86f885-1) started
Download of lsb-release (2.0.r53.a86f885-1) finished
Download of python-manjaro-sdk (0.9-2) started
Download of python-manjaro-sdk (0.9-2) finished
Download of web-installer-url-handler (2.3-1) started
Download of web-installer-url-handler (2.3-1) finished
Download of manjaro-hello (0.7.1-2) started
Download of manjaro-hello (0.7.1-2) finished
Checking keyring...
Checking integrity...
Loading packages files...
Checking file conflicts...
Checking available disk space...
Installing lsb-release (2.0.r53.a86f885-1)...
Installing python-manjaro-sdk (0.9-2)...
Installing web-installer-url-handler (2.3-1)...
touch: cannot touch '/.config/mimeapps.list': No such file or directory
/usr/bin/xdg-mime: line 887: /.config/mimeapps.list.new: No such file or directory
Installing manjaro-hello (0.7.1-2)...
ldconfig: /usr/lib/libnetsnmp.so.40 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libQt5DesignerComponents.so is empty, not checked.
ldconfig: /usr/lib/libnetsnmptrapd.so.40.1.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libnetsnmpmibs.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libQt5Designer.so.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5Help.so.5 is empty, not checked.
ldconfig: File /usr/lib/libpyside6.abi3.so is empty, not checked.
ldconfig: File /usr/lib/libstd-3832a15f20d69b64.so is empty, not checked.
ldconfig: File /usr/lib/libQt5Designer.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libpyside6.abi3.so.6.5.2 is empty, not checked.
ldconfig: /usr/lib/libm17n-core.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libnetsnmptrapd.so.40 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libQt5DesignerComponents.so.5 is empty, not checked.
ldconfig: File /usr/lib/libpyside6qml.abi3.so.6.5.2 is empty, not checked.
ldconfig: /usr/lib/libnetsnmphelpers.so.40 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libshiboken6.abi3.so is empty, not checked.
ldconfig: /usr/lib/libnetsnmpagent.so.40.1.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libnetsnmp.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libm17n-flt.so.0.4.2 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libm17n.so.0.4.2 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libshiboken6.abi3.so.6.5.2 is empty, not checked.
ldconfig: File /usr/lib/libpyside6qml.abi3.so.6.5 is empty, not checked.
ldconfig: File /usr/lib/libpyside6.abi3.so.6.5 is empty, not checked.
ldconfig: File /usr/lib/libpyside6qml.abi3.so is empty, not checked.
ldconfig: /usr/lib/libm17n-gui.so.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libnetsnmp.so.40.1.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libnetsnmphelpers.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libtest-4267710c4664eb03.so is empty, not checked.
ldconfig: File /usr/lib/libqpdf.so.29 is empty, not checked.
ldconfig: /usr/lib/libsnmp.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libOkular5Core.so.11.0.0 is empty, not checked.
ldconfig: /usr/lib/libsnmp.so.40 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libQt5Help.so.5.15.10 is empty, not checked.
ldconfig: /usr/lib/libm17n-flt.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libnetsnmpmibs.so.40.1.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libQt5Designer.so is empty, not checked.
ldconfig: /usr/lib/libsnmp.so.40.1.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libnetsnmpmibs.so.40 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libnetsnmpagent.so.40 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libm17n-gui.so.0.4.2 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libnetsnmphelpers.so.40.1.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libre2.so.11.0.0 is empty, not checked.
ldconfig: /usr/lib/libm17n-core.so.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libm17n-gui.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libQt5DesignerComponents.so.5.15.10 is empty, not checked.
ldconfig: File /usr/lib/libre2.so.11 is empty, not checked.
ldconfig: /usr/lib/libnetsnmptrapd.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libQt5Help.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libqpdf.so.29.6.0 is empty, not checked.
ldconfig: File /usr/lib/libshiboken6.abi3.so.6.5 is empty, not checked.
ldconfig: File /usr/lib/libQt5Help.so is empty, not checked.
ldconfig: /usr/lib/libm17n.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libnetsnmpagent.so is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libqpdf.so is empty, not checked.
ldconfig: File /usr/lib/libQt5DesignerComponents.so.5.15 is empty, not checked.
ldconfig: File /usr/lib/libre2.so is empty, not checked.
ldconfig: File /usr/lib/libostree-1.so.1.0.0.old is empty, not checked.
ldconfig: File /usr/lib/libOkular5Core.so.11 is empty, not checked.
ldconfig: File /usr/lib/libOkular5Core.so is empty, not checked.
ldconfig: File /usr/lib/librustc_driver-392e30d67b5926f8.so is empty, not checked.
ldconfig: /usr/lib/libm17n-core.so.0.4.2 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: /usr/lib/libm17n-flt.so.0 is not an ELF file - it has the wrong magic bytes at the start.
ldconfig: File /usr/lib/libQt5Designer.so.5.15.10 is empty, not checked.
ldconfig: /usr/lib/libm17n.so.0 is not an ELF file - it has the wrong magic bytes at the start.
Arming ConditionNeedsUpdate...
Updating the desktop file MIME type cache...
