Postfix package install fails: removing raptor breaks dependency 'raptor' required by liblrdf / Manjaro Settings Manager
#49643
How does it happen that you still have icu 67 version on your system since all branches have the 68.2 ?
Also all branches have the same postfix version, with the same dependencies versions … Same deal with raptor package. Make sure you fully update your system before installing packages:
sudo pacman-mirrors -f5 && sudo pacman -Syyu
Yes, “pacman -Syu” worked, thank You.
Somehow i thought that the pamac can recognize and handle these things automatically, but apparently not.
