this is mesgd to start, working on your request
[ 8.790372] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 8.790401] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.790422] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.790440] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.790458] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.807581] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.939706] Console: switching to colour frame buffer device 240x67
[ 9.075234] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 9.095200] random: crng init done
[ 9.098668] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.680027] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 10.688961] bcmgenet fd580000.ethernet eth0: Link is Down
[ 12.735423] bcmgenet fd580000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
[ 12.744106] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 33.759232] cam-dummy-reg: disabling
[ 33.762860] cam1-reg: disabling
[ 148.086976] pcm512x 1-004c: No SCLK, using BCLK: -2
This is only audio (forced hwdec)
mpv --hwdec=v4l2m2m-copy 20\ Mediaset\ HD
[Possible RPi mpv –hwdec=v4l2m2m-copy solution - Pastebin.com](https://Only audio no video)
In this play, the cache grows unti crash:
AV: 00:00:32 / 00:00:43 (74%) A-V: 0.000 Cache: 11s/33MB
AV: 00:02:05 / 00:02:16 (91%) A-V: 0.000 Cache: 11s/108MB
and keep running:
AV: 00:02:44 / 00:02:56 (93%) A-V: 0.000 Cache: 11s/139MB
mpv --hwdec=v4l2m2m-copy Rai\ 1\ HD
This is ok:
cache also is ok:
mpv --hwdec=v4l2m2m-copy Rai\ 1\ HD > mpvlog2.txt
AV: 00:00:19 / 00:00:21 (93%) A-V: 0.000 Dropped: 4 Cache: 0.6s/287KB
playng mpv chan1 chan2 chan 3
example:
mpv --vd-lavc-check-hw-profile=no playlistMediaset
where playlist is a list of link to channels (im a spam for pastebin for the moment im sorry i give the log:
#EXTM3U
#EXTINF:-1 tvg-id=“1e7b743a2c732ac06379e534556a8049”,Rete4 HD
http://10.42.0.1:9981/stream/channelid/980712222?ticket=C2500DD78586115A2FFD1DD3ADC66AA40F16A208&profile=pass
#EXTINF:-1 tvg-id=“3d2ffe80f13e2156e11e010815dff595”,Canale5 HD
http://10.42.0.1:9981/stream/channelid/16658237?ticket=7C75371FE39707953FCE5494030F5ACCFC21977D&profile=pass
i get this log from ffmpeg:
[ffmpeg/video] h264: non-existing PPS 0 referenced
[ffmpeg/video] h264: decode_slice_header error
[ffmpeg/video] h264: no frame!
Not seekable, but enabling seeking on user request.
(+) Video --vid=1 (h264 1920x1080 50.000fps)
(+) Audio --aid=1 --alang=ita (ac3 2ch 48000Hz)
Audio --aid=2 --alang=eng (aac_latm 2ch 48000Hz)
[ffmpeg/video] h264: reference picture missing during reorder
[ffmpeg/video] h264: Missing reference picture, default is 2147483647
[ffmpeg/video] h264: mmco: unref short failure
[ffmpeg/video] h264: number of reference frames (0+5) exceeds max (4; probably corrupt input), discarding one
[ffmpeg/video] h264: Missing reference picture, default is 65618
!!! hwdec !!! --------------
AO: [alsa] 48000Hz stereo 2ch float
VO: [gpu] 1920x1080 yuv420p
[vaapi] libva: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
while on the Raiplaylist
here i posted a wrong file, now is right apologize sorry
Resuming playback. This behavior can be disabled with --no-resume-playback.
Playing: http://10.42.0.1:9981/stream/channelid/614691879?ticket=6F4DC4200C187623158AB495AA59BA295A3AD5CE&profile=pass
(+) Video --vid=1 (h264 1920x1080 25.000fps)
Saving state.
Not seekable, or time unknown - not saving position.
Exiting... (Quit)
